Question about Coleman powermate 3250
What kind of oil does a coleman powermate 3250 generator take?
It has a Briggs an Stratton engine
  • 10 Answers
SOURCE: misplaced User Manual for Coleman Powermate 6250
I would run a search on line for your model number. I will look and let you know.
Posted on Feb 03, 2009
  • 57 Answers
SOURCE: Generator with Briggs & Stratton,no gas is getting in carburetor
The needle valve may be stuck which would not let gas into the carb. I don;t think rebuild kits are too expensive. Pull the carb and take it to a lawnmower repair shop and they should have the parts. Before that though pull the bowl and make sure it has gas in it. If no then remove the fuel line and make sure gas flows from it. If no then could be the fuel shutoff valve is not operating properly or junk in the gas tank is obstructing the line.
Posted on Jul 31, 2009
SRF518
  • 232 Answers
SOURCE: what kind of oil do I use in a Coleman 6250
10w40
Posted on Oct 26, 2009
  • 197 Answers
SOURCE: I'm looking for the 2 cycle oil to gas dilution
20:1 that's 1/4 pint to a full tank of fuel.
Posted on Jan 17, 2010
  • 112 Answers
SOURCE: Coleman Powermate 7,000 Watt 13 Hp Portable
we need to know the make of the motor....most use a SAE30 four stroke oil....not sure of the plug without knowing the make of motor.
Posted on Jul 24, 2010
I have a Coleman Pro-Gen 5000 with a Briggs and Stratton motor in it, I was wondering what kind of oil to use in it and what size sparkplugs I need
30W OIL, take old plug to store customer service will match. Parts: http://www.ereplacementparts.com/powermate-generator-parts-c-117046_130613.html?gclid=COe1kb_yi80CFZGJaQodXvYMXg Info: look on valve cover "DOHC" marked. On the side is the model number for the engine. Search on that model number for engine parts.
Jun 02, 2016 | Coleman Electrical Supplies
Oil to used for a briggs and stratton genpower 305 10hp ohv engine
Hi Jim, sae 30 mineral oil for all Briggs engines. Regards Phil.
Sep 24, 2011 | Coleman Powermate Powermate 5000W...
PM052520 Coleman Powermate run and cur off
If it is a Briggs & Stratton engine it most likley has a fuel pump
Aug 31, 2011 | Coleman Powermate Powermate 5000W...
I don't know what kind of oil the powermate 1850 uses
As with most briggs engines if you are operating in an area where the temp is below 20 degrees...use 5w-20 or 30. Between 0 to 100 use 10w-30. above that 10w-40 can be used but be sure to check the oil and temp often.
Oct 22, 2010 | Coleman Powermate Powermate 5000W...
Where do i get a coil at?
Well, if Briggs and Stratton engine, then try briggs and stratton.
If Robin / Subaru engine, try there.
Write down the model type and serial numbers, then pay a visit to local small engine repair shop and have them order for you.
Dec 21, 2009 | Coleman Powermate Powermate 5000W...
Where is the oil drain plug for a briggs and stratton 11 hp engine?
ACCORDING TO POWERMATE, THIS GENERATOR IS EQUIPPED WITH A 10HP SUBARU ENGINE. WHAT MODEL IS YOURS? AND R U SURE IT'S A B&G ENGINE?
Dec 14, 2009 | Coleman Powermate Powermate 5000W...
9hp briggs and stratton engine has gasoline in the engine oil
Old gas, gone bad from sitting. Drain all gas out and use carb cleaner in unit to clean. Add fresh gas.
If you need further help, I’m available over the phone at https://www.6ya.com/expert/craig_3fa289bf857b1a3c
Oct 01, 2009 | Coleman Powermate Powermate 5000W...
Oil capacity and weight of oil
If it comes with a Briggs & Stratton 3.5 HP series 93400 engine, then the oil capacity is 20 fl oz (0.59 L). Hope this helps!
Sep 20, 2009 | Coleman Powermate Powermate 5000W...
Misplaced User Manual for Coleman Powermate 6250
Feb 02, 2009 | Coleman Powermate Premium Plus 6250W...
Electrical Supplies Logo
Top Coleman Electrical Supplies Experts
John Trevino
Craig Butler
Craig Butler
Phil Walker
Phil Walker
Are you a Coleman Electrical Supply Expert? Answer questions, earn points and help others
