Question about Lands Phones
Comdial DX 80 Voice Mail
How can I reset the supervisors password for mail box 70? Also, is Keylink software required and available to adaquately maintain a Comdial system?
  • 6 more comments
  • allencommuni Jan 12, 2009
    I can not log into the Supervisors mailbox because someone had changed the default password. How do I reset that?
    I do not have a current password. Where do I purchase Keylink?
    When I attempt to log into mailbox 70 with the default password "70" it gives me an invalid password message
  • allencommuni Jan 13, 2009
    I never get to the main menu because I can not get into the supervisors mailbox. I do not have the password and the default password does not work.
    If I can not get into the supervisor mailbox because I do not have the password and I do not have Keylink, Is there a method to restore the system to default?
    I know I am probably overlooking the solution to this problem. I have not identified in any of the publications how to get into the supervisors mailbox without the password. Is there a reset button on the VM card that will restore the system to default passwords?
    Thank you machine83. Can that task be accomplished without a PC?
    The administration password is good. It is only the password for the supervisors mailbox that will not work.
    Thanks
  • 19,396 Answers
Check the user manual here: SYSTEM NSTALLATION AND AINTENANCE
Posted on Jan 12, 2009
  • 685 Answers
To reset it dial *58 this will restore it to factory settings also you can try pressing the number 8 eight times
try this and let me know how it works
Posted on Jan 13, 2009
    Sergeant:
  • 378 Answers
You can reset the supervisor password by connecting device  to the pc  just  edit your Windows registry. To do this, follow these steps:
  1. Make sure Internet Explorer is closed. Click Start, and then Run...
  2. Type regedit , and click OK
  3. In the window that appears, double-click HKEY_LOCAL_MACHINE
  4. Find and double-click Software. In the list of software types, double-click Microsoft
  5. Double-click Windows, and then Current version
  6. Double-click Policies, and then Ratings
  7. In the column on the right, click Key to select it, and then either press Del or right-click the selected Key and selectdelete from the drop-down menu.
  8. Confirm the deletion when prompted, and exit the window.
    Brigadier General:
  • 8,619 Answers
Hi!
You can reset it by following the steps---
1. Enter Database Administration using the feature code Feature # * and then enter the DB Admin
password. The default set at the factory is ########.
2. Press show. The DB Item Select screen displays.
3. Enter 04-01 and press save. The system advances to the System Resources – DB PSWD screen
and displays the current password. The default is all spaces (blanks).
4. Press chg to change the password. Enter the new eight-character, alphanumeric password.
5. Press save.
6. Exit the programming mode.
  • 3 more comments
  • Rylee Smith
    Rylee Smith Jan 12, 2009
    Attendant Administration Feature # 0 Password: 9999 (x101)
    0000 (all other extensions)
  • Rylee Smith
    PROGRAMMING USING PC-DBA
    Before changing the database administrator password, you must first connect your laptop to the
    system. For details on connecting, see Section 2.1.4.5, F5 – Connect.
    1. Select Programming from the PC-DBA menu and press Enter. The system displays the Database
    Programming menu.
    2. Use the arrow keys to highlight KSU DB Password and press Enter. The system prompts you to
    enter the old password.
  • Rylee Smith
    3. Enter the existing password and press Enter. Note: The default PC-DBA password when the
    system is shipped is “ “ (eight spaces).
    4. After you enter the eighth digit of the old password, the system prompts you to enter the new
    password.
    New Password:
    Key in the eight alphanumeric characters you want to use for your new password.
    5. After you enter the eighth character of the new password, the system asks you to confirm the
    new password.
    Confirm:
    Key in the same eight alphanumeric characters you entered in the previous step.
    6. After you confirm the eighth character of the new password, the system asks if you want to
    send the new password to the switch to be saved.
    Save New DB PSWD to KSU? (Y/N)
    7. Press Y to save your new password. The system responds as follows.
    Password Change Succeed!!
  • Rylee Smith
    Rylee Smith Jan 13, 2009
  • Rylee Smith
    It consists of all the instructions to restore the system to default and also the installation instructions...
    Sergeant:
    Novelist:
  • 326 Answers
1. From a telephone, call into voice mail and log into the supervisor mailbox 70. The system responds with the Main menu:
"To listen to your messages press 1. To send a message press 2. To change your options press 3."
2. To access the Supervisor menu, press 6 (this option is not voiced). The system responds with the Supervisor menu options:
For Mailbox Administration Press 1 For Routing Box Administration Press 2 For Question Box Administration Press 3 For Port Administration Press 4 To Change the System Broadcast Message Press 5 To Change the Voice Mail Day/Night Service Press 6 To Change the System Time Press 7 To Change the System Date Press 8 To Modify System Parameters Press 9 To Perform First-Time Setup Press 0 To Exit Press #
3. From the Supervisors menu, press 1 for Mailbox Administration.
4. When prompted, enter the number of the mailbox you want to add, modify, or delete. The system repeats the number back to you.
5. When prompted, press 1 to confirm the number you entered or press # if the number you entered was incorrect. Once you press 1 to confirm, the system responds with the Mailbox menu options:
and for kelink software click the link to download
http://wareseeker.com/free-keylink/
thanks.
  • 818 Answers
    Genius:
  • 1,847 Answers
Want you to go through this link...
http://www.acctelecom.com/support/Manuals/Comdial/DX-80%20Attendant%20Guide.pdf
this will help you ... Kevin
    Genius:
  • 2,920 Answers
You have to enter the current password and go to where it asks you to reset new password. there u can put in the new password of your choice.keylink isnt required but is adaptable to this usage
    Sergeant:
  • 221 Answers
Http://www.hometowntelephone.com/userguide.pdf just click the link and follow the directions
DX-80 7260-00 changing the password
Well if there is a way you need to call tech support of the manufacturer of the phone to find out..
Aug 18, 2016 | Comdial Dx-80 7260-00 Digital Executive...
How do I get into the supervisor menu on a Comdial 7260?
Option 6 is Supervisor Menu. The system will not announce it because it is a hidden option.
Jan 20, 2015 | Comdial Dx-80 7260-00 Digital Executive...
Where can I get the keylink softare for vmII for dx 80?
Good luck acquiring the software. Comdial filed for Chapter 11 bankruptcy back in 2005 so their website and support no longer exist. They got acquired by Vertical Communications.
I was able to get the software from them, but you would need credentials to download the software and that I do not have. I would recommend contacting their support to see if they still have the old software.
Nov 14, 2014 | Comdial 7271C DX-80 DX-120 7271C Flash...
How do i change message
From the Supervisor menu you can record greetings for all boxes. Check & listen to messages for all boxes. Change options & password for all boxes.
To Access Supervisor Options:
-Access your voicemail box
-From main menu, press 6 for Supervisor Menu
At this point, voice mail will walk you through changing what ever you need to change or check. **See the Supervisor Guide for more detailed information & instructions**
Aug 13, 2014 | Comdial Lands Phones
How do I record the Main Message people hear when they call my company?
Note: Voicemail may ask for mailbox and password. Please consult your owner's manual for the credentials.
To change Main Greeting messages, here are the following steps:
-Go into the Supervisor Options
- To Access Supervisor Options:
- From main menu, press 6 for Supervisor Menu
-Press 2 for Routing Box Administration
-Enter Box Number that you are changing / recording
(Main Day Greeting is box 800, Main Night greeting is box 801)
-It will repeat the number you entered and prompt you to press 1 if its correct
-Press 3 to Modify
-Press 1 for Greetings
-Press 2 to Record Greeting
-Press 1 to replay current greeting or Press 2 to record greeting
-Press * (star) for current greeting
-Record greeting.
Jul 17, 2014 | Comdial Dx-80 7260-00 Digital Executive...
How do you change the voice mail message?
Do a web search for "Comdial Dx-80 7260-00 Digital Executive Phone manual", and you will see several links to PDFs of the manual.
May 14, 2014 | Comdial Dx-80 7260-00 Digital Executive...
Unlock Nortel t7316e voice mail. when i try to get into my voice mail and after entering my password, th ephone displays "mail box locked contact admin. i am admin and do not how to unlock. I have...
Feature 983 log in is 120000 (if 2 digit extension, 1020000 if 3 digit, 10020000 if 4 digit extensions)
Select Mbox, enter that locked extensions mail box number, You will see password RESET. Select RESET. Release out. This will reset that mail box password to 0000. Use feature 981 on that phone and enter the new default password of 0000. you will then be prompted to change the password.
Feature 985 will show you the extension of the phone you are using.
Mar 15, 2011 | Nortel T7316E 2-Line Corded Phone
Voice mail not working
So is the voicemail hardware/software inside of the system or an external device? All of the evidence here seems to point to a power surge, but I just want to make sure.
Jun 15, 2009 | Comdial SmallOffice Lite Voice Mail Server
Changing message on Comdial Impact Telephone
Sounds like you are trying to change a voice mail recording. Your Comdial phone can be used on several different Comdial phone systems and with several different voice mail systems that all program and set up differently. Do you have any manuals or instructions for your voice mail system? If not, you will need to find out which voice mail you have and try to locate manuals.
To change main greetings, etc.. you would need administrative rights to the voice mail. There will probably be a password, hopefully you know it or it's still at default.
Nov 28, 2007 | Comdial 8324S-PT Corded Phone
Lands Phones Logo
3,200 people viewed this question
Top Lands Phones Experts
Are you a Lands Phone Expert? Answer questions, earn points and help others
