Question about Mastercool 67471 Evaporative Cooler Air Conditioner
Evap Cooler motor not cutting in
Hi there, I have a Summer Breeze evap cooler by Vulcan. I have turned it on this am and for the past hour it has run water over the pads but the motor / fan has not cut in. we had it working 4 days ago. no probs..any suggestions.
    Problem Solver:
  • 11 Answers
Look for a reset switch on the unit, press it and try again.
If there is no reset switch, unplug the unit entirely if possible, wait a minute and plug it back in.
Sometimes electronics get confused and need to start over. Let us know if that works.
Posted on May 31, 2009
New fan motor gets hot and stops after an hour have new computer
Sounds wired wrong, possibly wrong wires on capacitor.(if there is one of course) need to have wuring schematics and make sure its wired right. Hopefully its the right motor!!
Dec 22, 2016 | Heating & Cooling
2001 NISSAN SENTRA GXE HAVE CODES WITH INNOVA OBD2 SCANNER P0455, P1448, P1441. I CLEANED EVAP CANISTER LINES SENSORS AND ALL THAT BUT CHECK ENGINE LIGHT STILL COMING ON AFTER I DRIVE A WHILE WHAT IS...
I check the result of the three DTCs for you
P1441 - NissanTypePowertrain - Manufacturer Controlled DTC - Manufacturer ControlledDescriptionEvaporative emission (EVAP) canister purge system - bypass vacuum cut valve malfunction
CauseWiring, EVAP bypass vacuum cut valve, EVAP cut valve/pressure sensor, hose leak/blockage, ECM
P0455 - NissanTypePowertrain - Auxiliary Emission Controls - ISO/SAE ControlledDescriptionEvaporative emission (EVAP) canister purge system - gross leak
CauseWiring, fuel tank/cap, hose leak/ blockage, EVAP valve/canister, EVAP vent valve, BARO sensor, MAP/BARO switching valve, ECM
P1448 - NissanTypePowertrain - Manufacturer Controlled DTC - Manufacturer ControlledDescriptionEvaporative emission (EVAP) canister purge system - vent control valve malfunction
CauseWiring, EVAP vent valve, EVAP pressure sensor, hose leak/blockage, EVAP canister contaminated, EVAP vacuum cut valve, ECM
hope these can help you, or you can ask the 24 hrs live technical support vas5054a, they will like to help you, good luck
Sep 10, 2013 | Mastercool 67680 Evaporative Cooler Air...
Have a CVKG581 Wine Cooler and it is not getting cold. Light goes on so I know power is getting to the cooler
HI,CHECK THE COOLER TEMP CONTRL ,CHECK THE COMPRESSOR AND CHECK THE EVAP MOTOR ,,ANY OF THIS COMPONENTS MAY BE BAD..GOOD LUCK..
Feb 21, 2011 | U-Line Wine Captain (2015WC) Wine Cooler
Our Bonaire Evap Cooler stopped after power failure
Turn the power of to both the heater and the cooler. Turn the power back on to the heater and the cooler at the same time then reset codes on controller.
Feb 07, 2010 | Mastercool 67471 Evaporative Cooler Air...
Need a wiring diagram for mastercool evap 2 stage unit
I have the wiring diagram in the cooler. I can photograph and send it to you. Do you still need it?
May 12, 2009 | Heating & Cooling
Vulcan-Bonaire : summer breeze
This unit is a cooling unit only. I don't know what switch you are looking at but I don't think it's for the evap. cooler(swamp cooler). I am in the Phoenix, Arizona area and it's very common to have a evap. cooler and a seperate heat/cool system as on the hottest days the evap. cooler doesn't cool enough. I hope this helps. Please give me a positive rating. Thank you.
Jan 27, 2009 | Mastercool 67471 Evaporative Cooler Air...
Danby wine cooler repair
call Danby at 800 263 2629, you can order parts from them
May 10, 2008 | Danby DWC283BLS Wine Cooler
Mastercool 67471 Evaporative Cooler Air Conditioner Logo
270 people viewed this question
Top Mastercool Heating & Cooling Experts
Bill Long
Dan Webster
Dan Webster
acrman404a
Level 1 Expert
Are you a Mastercool Heating and Cooling Expert? Answer questions, earn points and help others
