Question about Readon Technology Readon TV Movie Radio Player
Engines 1 & 3 doesn't work
  • 242 Answers
The search engines for the Adult on Demand plugin in Readon have been difficult for some time now. This is an issue with Readon and not with your computer.
Posted on Dec 10, 2012
Engine dies at stop lights when air conditioning is in use
Lets use common sense on the Trans Flushing
Old Fluid out --- New Fluid in---WOULD THAT DO ANYTHING
TO CORRECT ANY PROBLEM------NO
Trans & Power Steering Fluids-- are done every 3 years
in my world
They are called Preventative Maintenance,just like spark plugs,
gas & air filters,nothing else,fixes nothing
Trans fluid breaks down over time from heat & then your
clutches burn up & your trans fails,no other reason to change
the fluid
If the Torque Converter Clutch Solenoid is bad & doesn't
release when you apply the brake,then it is like slowing down
with a standard shift car & not putting in the clutch when you
come to a stop
You need to ask more questions & understand what your
told or stay in the conversation & take it into the service bay
& not deal with a service writer who doesn't work on the
product.
Jul 24, 2012 | 2011 Kia Sorento
Sparkplug wiring for a straight six
Hi JT, The typical firing order for a straight six is 1-5-3-6-2-4. If this doesn't help let us know the specific engine your working on and we'll help you. Regards John
Feb 09, 2012 | 1990 Jeep Wrangler
I have a '97 cavalier and it won't fire after I changed the plugs. I believe the wires are on the correct plugs. however, if I take a plug out and leave it in the wire, set it on engine block, the...
1 coil pack is for cylinder 1 & 3 . The 1st & 3rd....moving back from the belts. 1 is on the top, three on the bottm of the coil. 2 & 4 should be the same, 2nd cylinder, 2nd back from the belts & top on the coil pack. 4 the last plug & lowest on the second coil pack. PLEASE NOTE: , A Handyman's Service manual, from an auto store can VERIFY THIS. My last experience was with the 1987- 1991 GM "Quad" 4 engines. One of the other experts on "FixYa" corrected a mistake I made on a newewr model. SO I WOULD CHECK this advise to A MANUAL. I was wrong on the other one I answewred, & do not want to add to your frustration. I have looked around my textbooks, I do not have one on that car, I have given it away.
Sep 22, 2011 | 1997 Chevrolet Cavalier
CHANNEL 1 DOESN'T. WORK. WHAT CAN IT BE?
Try changing your RCA leads, they may me faulty, if that doesn't work you probably Have a blown output amp
Aug 20, 2011 | Technical Pro TA-1250 Amplifier
3 year old side by side hotpoint. 3 months ago freezer frosted up & would not cool. Repair person replaced heater & mother board worked until about 1 month ago. Frosted up again. Repair person...
This is the part that is bad....it is cutting off the defrost too soon...
http://www.partselect.com/PS1017716-GE-WR50X10068-Defrost-Thermostat.htm?SourceCode=5&ModelNum=hss25gft
or Click here
heatman101
Aug 02, 2011 | Hotpoint HSS25GFT 25.0 Cu. Ft....
After engine is warm ( V 6 ) sometimes, but not always, hesitates when trying to speed up and sometimes backfires. Dealer replaced coils and plugs but can't find the problem. 2005 lincoln LS
The spark plugs get replaced around 60,000 miles
& the L/S requires a special spark plug,also
premium fuel or it will knock
If you change plugs every 3 years, then that isn't the issue
Did they remove the upper intake manifold to do the right side
spark plugs?
You never have more then 1 bad coil a year, or sometimes
2 ,but never at one time
A dealer can not work on an L/S for some reason
I own a 2004 V8 & have no issues diagnosing these problems
The front 2 O2 Sensors ,the ones in the front of exhaust converter,
get slow & get replaced at 100,000 miles
You clean the MAF Sensor with CRC MAF Cleaner
A back fire could be a lean condition from a vacuum leak
That could be around the engine or in the EVAP System
Hopefully they checked the TPS Sensor
When I refer to check, I don't mean replace,I mean test &
use an oscilloscope to back probe the sensors,not continually
make love to their scan tools,actually get involved & see what
does work & how well,then you will eventually find something
that doesn't.
The EGR Valves fail on ford products quite offten
Need to check/test fuel pressure at rail on engine,even
road test with gauge taped to the windshield & take scan
tool along to collect data.
You got sometimes & when warm,that is what they should
be working off of
You don't go after a problem ,you find out how things are
doing that do work & the drivability issue will surface.
Dealers sometimes never even road test a car or long enough
So there you go,they won't find anything
Keep in touch,I have all the manuals etc if you give me more
symptoms
Jun 22, 2011 | 2005 Lincoln LS
My web cam isn't working
1.try making changes in the webcam panel.and be sure the web cam can support your windows version.(old one's can't work in win7)
2.if it doesn't work REINSTALL the webcam driver .
3.if that to doesn't work webcam must have failed !!!
Jun 15, 2011 | Computers & Internet
Just had both o2 sensors replaced and now the truck won't shift from 2nd to 3rd gear. Evidently it had been slipping a bit before but now it won't shift into 3rd at all. The tranny is an E4OD......
O2 Sensors --- not related to shifting
New transmissions --- are only new once
When installed on the assy line
Has to be rebuilt if necessary
PO 147 ---O2 Sensor Heater (Bank 1 Sensor 3) don't have one of those
PO714 -- Trans Temp Sensor -heat for the slipping
PO 471 --- Exhaust Pressure Sensor -don't have that either
Need a new guy
Not very professional were they
Jun 13, 2011 | 1997 Ford Expedition
Hello, I installed a T104 timer switch following the directions on the manual. I connected supply lines to terminals 1 & 3 and the load wires going to the pool motor on terminals 2 & 4. The clock...
It doesn't sound like you are getting a true 230 volts to the timer. Measure from terminal 1 to terminal 3. You should read 230 volts. If you are getting 230 volts between 1 and 3, return the timer, it's defective. If you are not getting 230 between 1 and 3, then you'll have to have a look inside the electric panel to see what has been miswired. There should be a 2 pole breaker with a white and a black wire connected to it that goes out to the timer.
May 27, 2011 | Intermatic T104 24h 208-277v Mechanical...
My little cousin put me a lock code on my n97 and icant unlock it plzz help
1) ask them 2) if #1 doesn't work take something of your cousin's and hide it 3) if #2 doesn't work punch them 4) if all the above doesn't work repeat the process
May 02, 2011 | Nokia N97 Cell Phone
Computers & Internet Logo
813 people viewed this question
Top Readon Technology Computers & Internet Experts
David Payne
David Payne
Are you a Readon Technology Computer and Internet Expert? Answer questions, earn points and help others
