Question about Evenflo Jenny Lind Crib
Jan 25, 2005 delta luv crib model 4750-1 replacement parts
Need side rail parts 4 X 1 rail guide
2 Suggested Answers
reyjoshua07
  • 1157 Answers
SOURCE: i have a delta crib
Hi earlyriser37,
You have two options where you can get replacement parts for your Jenny Lind crib:
1. You may write or call this company:
Simmons Juvenile Products Company
P.O. Box 287
613 East Beacon Avenue
New London, WI 54961
(920) 982-2140 ext 296
2. Or call Products America at 1-800-205-9642 or check their website at www.productsamerica.com. They have the Jenny Lind by Evenflo crib parts.
Hope this helps.
Thank you for using FixYa.
Posted on Aug 03, 2011
Roller coming off guid rail while in use
This is a known problem with these machines. We ended up returning ours. Sorry!
Mar 20, 2014 | Sole Fitness Sole E20 Elliptical
Cable system on passenger door power window, 1999 dodge Caravan, has slipped off track. Need exploded diagram to restore to original.
REMOVAL
1. Remove the watershield. (Refer to 23 - BODY/DOOR - FRONT/WATERSHIELD - REMOVAL)
2. Remove door glass retaining clips and secure the window in the up position using masking tape or equivalent(FRONT DOOR GLASS CLIPS).
3. Disconnect wire connector from power window motor, if equipped.
4. Loosen screws attaching front and rear window guide rails to inner door panel (FRONT DOOR MANUAL WINDOW REGULATOR - TYPICAL).
5. Remove screw heads on guide rails from key hole slots in inner door panel.
6. Loosen screws attaching regulator to inner door panel.
7. Remove regulator from inner door panel.
8. Extract rear guide rail through inner door panel rear access hole (FRONT DOOR POWER WINDOW - TYPICAL).
9. Extract front guide rail through front access hole.
INSTALLATION
1. Insert front guide rail through front access hole.
2. Insert rear guide rail through rear access hole.
3. Place window regulator in position on inner door panel.
4. Place screw heads on guide rails in position through key hole slots in inner door panel.
5. Tighten screws to attach front and rear guide rails to inner door panel.
6. Connect wire connector into power window motor, if equipped.
7. Install door glass.
8. Verify door glass alignment and operation.
9. Install sound shield and door trim panel
DIAGRAMS CAN BE FOUND ON JUSTANSWER,COM
Sep 02, 2012 | 1997 Dodge Grand Caravan
Show assembly for Bassett crib model 5918-505
I have a 5918-505 mI put it togehter for the first time since 1980 I had no problems once I located all of the parts: 4 metal guide rails, 2 wooden ends with 2 wheels in each, 2 wooden drop sides (or front and back that go up and down.) 2 metal toe kick rails that hold the sides up, 1 mattress springs, 4 metal mattress spring supports. attached to the inside of the wooden ends are 4 hanger pieces for the mattress spring support to hang on.
I could supply photos if needed.
Oct 23, 2011 | Bassett Mission Crib
Was the crib model number 47504 recalled? If not how would I be able to get a new coaster wheel 4 x j ?
Cribs with model numbers 4750 (production dates 01/95 thru 12/00) are on the list.
http://www.cpsc.gov/cpscpub/prerel/prhtml09/09017.html
As far as parts go, you could call Delta at 1-800-377-3777 with you model information (found on bottom of crib) and they should have most replacement parts.
Jun 07, 2011 | Delta Luv Delta - Baby Products 5-in-1...
I have a Delta Luv drop side crib model #4750-1, I understand that all drop side cribs have been recalled. Are there any replacement parts to fix this problem or does the crib just need to be trashed?
You dont have to trash the crib. Delta will send you a part that makes the drop side a stationary side. It is free. Here is the site to file for your free replacement parts. http://www.cribrecallcenter.com/
Jan 02, 2011 | Toys
I have a MieleG2142. One of the racks is not sliding smoothly which I believe I have narrowed down to one of the wheels in the rail guides not turning. How are the rail guides removed?
Hi dear.Try this.Pull the top basket towards you.Check on the side (if you can) back of the basket two of the wheels on top row should be on rail guide & third one just under the rail guide to support the basket.It should be even on both side of basket to run smoothly.If not pull the basket all the way towards you & lift up the basket you are holding.Basket will be free to come out of rail guide.(Please check,are the rail guides running in & out freely without basket?If not there are two plastic wheel inside of the each rail guide one or two of it must be damaged.That needs to be replaced.Please also check side wheels on the basket,they sould be freely turning.If not needs to be replaced.) If that did not work out,try to put back the basket even way to rail guide the way took it off.Contact Miele for assitants.Thanks.Goodluck.
Aug 07, 2010 | Miele G2142 24 in Builtin Dishwasher
Is there a crib recall for the Delta Luv Crib, model 4750-1, 1-17-06?
Yes, please follow the link below for the replacement part order form.
http://www.cribrecallcenter.com/cinfo.asp?recall=2&co=1&m=4750-1&p=90002
If this information was helpful, please take a moment to provide a "thumbs up" rating. Thank you!
Jun 08, 2010 | Delta Luv Delta - Baby Products 5-in-1...
Where do I find 2 stabilizer bars for a Delta Luv Model 4750-1 crib?
You can order parts for you Delta crib through the following Web form:
http://www.deltaenterprise.com/parts.asp
You will need to provide the complete model # and LOT number for your crib. The LOT # may be listed as the Order #.
Jan 09, 2010 | Delta Luv Delta - Baby Products 5-in-1...
Need stabilizing bars for a delta crib model 4750-1 order #S765165
Since this model has been recalled, please follow the link below to the replacement part order form.
Oct 25, 2009 | Delta Luv Delta - Baby Products 5-in-1...
Need Replacement Part # 4 X H Crib Lock for Delta Lov Crib Model 4720
OUR DELTA 5 IN 1 IS MISSING THE RAIL GUIDE 4 X H CRIV LOCK AND #10 DOWELS AND NO INSTRUCTIONAL GUIDE HELP??
MZ Q
Oct 16, 2009 | Delta Luv Delta - Baby Products 5-in-1...
Evenflo Jenny Lind Crib Logo
142 people viewed this question
Top Evenflo Baby Gear Experts
Joyce Nokleby
Shehu Pro
Shehu Pro
Rick Moore
Rick Moore
Are you an Evenflo Baby Gear Expert? Answer questions, earn points and help others
