Question about YouTube Videos
Change rear axle bearing 1990 mazda b2600i pick up truck
How to change rear wheel bearing 2005 mazda tribute
by look of the size of the vehicle
and the rear bearing shows up as a solid
if into a lower control arm
a special tool to press out the solid bearing with control arm on the vehicle
or
rear stub axle off the vehicle and press out the old bearing
press in the new
Mar 05, 2017 | Mazda Cars & Trucks
1990 mazda b2600i. The fuel injection 30amp fuse blows every time I turn the key to the on position. What's could be the problem
Faulty fuel pump or fuel pump relay. Locate the fuel pump relay. Remove it. And turn the key on again. Check if fuse is holding.
Jan 30, 2017 | Mazda Cars & Trucks
Locating the rpm sensor on a 1993 mazda two wheel pick-up B2600i 2.6L 4cyl
I suggest you get a Chilton or Haynes Repair manual, if you don't have one already. I have an Odd ball Isuzu & they make a manual for it. Also if you have a good relationship w/ a local Mazda dealer the repair shop might let you take a peek at their factory manual.
Nov 28, 2016 | Mazda Cars & Trucks
How to take out rear axle bearings in a 1990 camaro?
support rear of car, remove wheels and brake drums, put a drain pan under differential, remove diff cover, turn gears until you see the lock pin bolt, remove bolt and push the lock pin out. when you do this do NOT turn the differential. push the axle in and remove the C clip that locks the axle in place and pull out axle, repeat for other axle. remember DO NOT turn the differential with out the axles in place.
Mar 26, 2015 | 1990 Chevrolet Camaro
Rear diff noises
check the axle bearing on the side . jack up the car and try and pull the axle in and out of the diff housing. If it moves then it will be a bad bearing.
Jan 20, 2014 | 2007 Mazda CX-7 Grand Touring
I cant find the fuel pump relay an my 1990 b2600i 4x4
its in the drivers side kick panel on the left corner... single relay by itself
Feb 21, 2012 | 1990 Mazda B-Series
Is it hard to change the rear whell bearings on 05
You are probably looking at about an hour per side. Brakes and backing plate must be removed. then the mounting bolts for the axle itself must be removed. this operation should be performed one side at a time in order to save the fluid inside the differential casing. It will become imperative that both oil seals are changed with the bearings. P.S. depending on the graciousness of the engineers, you may not have to remove the backing plates. Thank you, Dana
Mar 05, 2010 | 2005 Mazda Tribute
Front end of b2600i 4x4
hub or wheel bearing failure.
Apr 23, 2009 | 1990 Mazda B-Series
Wheel bearing problem
easy remove wheel ,brakes .disc.and axle
Apr 20, 2009 | 1990 Mazda MX-5
YouTube Videos Logo
52 people viewed this question
Top YouTube Computers & Internet Experts
Michael Terence...
Michael Terence...
Mike
Are you a YouTube Computer and Internet Expert? Answer questions, earn points and help others
