Question about Homelite Mighty Lite 26Bv Leaf Blowers
How to adjust carborator on the homelite mighty lite 26b blower ?
Will not keep running
4 Suggested Answers
  • 86 Answers
SOURCE: gas leaf blower runs at half speed
First you will have to get a carburetor kit ,it consists of diaprams and inlet needle,you then remove the two srews that hold carburetor on the engine and remove gas lines,also the throttle cable remove screws that hold ends of carburetor on under these you will find the diaphrams and needle remove these be carefull not to loose the little spring under the needle lever.
!get you a can of carburetor cleaner and spray carburetor the blow it out with air you will notice little jets in carburetor that have to be clean use a wire from a bread tie to clean them out install new gaskets and diaprams in same position you took old ones off.you can also look at carburetor to see what kind it is walbor,zama,tilloson? type the name in google search and can get a diagram of carburetor if you loose your place,or just ask me.
Posted on May 16, 2009
  • 6 Answers
SOURCE: mighty lite 26b leaf blower will not go full
I took the carb off (easy- two screws), rebuilt and cleaned it, removed the black "H" & "L" needle jet screws (with no screwdriver slots) with a tiny pair of needle nose pliars, 1/8 turn at a time. They are very tight. Then I cut the slots with a fine hacksaw blade and re-installed them. BEFORE you begin, MARK where the "pointer" notch is on each screw so that you know where to reset them and count the turns coming out. Also, cutting the slot 90 degrees off of the pointer mark helps.
An option would be to hold the carb body in a vise and cut the screw slots thru the aluminum guard. Be very gentle, the screws are soft steel. If I had to do it again, that's what I'd do.
Get it running and adjust the "L" at idle until it runs smooth as rich (open) as it can. Then hold the throttle wide open and open the "H" (high speed needle jet) until it runs smooth, as rich as possible. This can be a CHORE.
Remember, richer (more fuel) is better than too lean. Too lean means less lubrication and running much hotter. 80% of the cooling in gasoline engines is from the evaporative effect of the charge coming into the engine. That's why carbs ice-up well above freezing. Ask any pilot.
Posted on Jan 01, 2010
2strokeguy
  • 183 Answers
SOURCE: My Homelite Mighty Lite 26b
Homelite wants to sell you a new carburetor assembly. Your blower came equipped with a RuiXing brand carb. RuiXing does not offer any repair parts for their carbs, only replacement units.
Now for the good news....a Zama brand primer bulb fits perfectly on the RuiXing carbs. Check with your local small engine repair shop for a Zama primer bulb. The blower requires removal af the carb to get at both of the screws that hold on the bulb. It is not difficult, just one nut holds on the outer airbox cover...don't lose the little washers. Then one long stud and one short screw will take the carb off. Replace the primer bulb and reinstall everything the same way it came off.
Posted on Dec 21, 2010
How to adjust a home lite mighty lite blower vac carburator "?"
Hi. This link,
http://manuals.homelite.com/documents?page=5
is to the homelite page where the manuals are, however, there are 4 different models of the handheld blower you have. Either way, if this is a really new model, there may be no way to adjust the carburetor, as due to emissions standards, there may not even be any idle screws, but if they do exist, the head ma be whats called "pacman", as it looks like a little....yeah...pacman.
Apr 25, 2014 | Homelite Mighty Lite Blowervac
Homelite mighty lite 26bv gas Blower won't run full speed or only in Full Choke
Sounds like a lean condition. Rebuild carb, replace fuel lines and fuel filter and you should be ready to blow the leaves.
Nov 10, 2012 | Homelite Mighty Lite Blowervac
How much oil do you use? in the mighty lite
Homelite Mighty Lite engines require the gas/oil ratio to be mixed at 50:1. That is 2.6 ounces of oil per gallon or 1.3 ounces of 2 stroke oil per half gallon of gas. I recommend using synthetic oil. It lubricates much better, allows the engine to run cooler and smokes less.
Apr 05, 2011 | Homelite Mighty Lite Blowervac
My Homelite Mighty Lite 26b Leaf blower has a punctured primer bulb. Homelite doesn't list the part number. Model number UT08520A Can you help? Thanks, Ed Mckinney,Tx
Dec 21, 2010 | Homelite Garden
My homelite might lite 26b will run in the choke position but cuts off in the run position. I have drained the gas and put in fresh gas, new plug and opened the carburetor and cleaned it.
if it seems low on power,remove the muffler and clean out all carbon build-up,if it has power as in full throttle,then the carb is still dirty and needs to be rebuilt
Mar 12, 2010 | Homelite Consumer Products MightyLite...
Homelite Mighty Lite 26Bv Leaf Blowers Logo
98 people viewed this question
Top Homelite Garden Experts
roeb
Roland W VanLue
Roland W VanLue
Mike Squire
Are you a Homelite Garden Expert? Answer questions, earn points and help others
