I have a Toshiba DVD player connected to my TV. It has worked perfectly but it is now spitting out my DVDs and not reading them. Is this a problem with the laser? Power is still there not when asking to read the discs, the player just pushes the discs out again. Please advise. The player is ourt of warranrty period.
  • janraymondha Jan 13, 2009
    How does one do that? Take it to a Toshiba dealer?
  • 3 Answers
100% there is problem with the optical pickup unit (LENS) only.... change it ...
-Bharat
Posted on Jan 13, 2009
Cannot read dvds. Display says incorrect disk
If the dvd player is doing this on all disks then there is something wrong with the laser assembly. Cost to repair for what it is, is prohibitive. If tv has audio video input, connect external player to that for viewing disks OR buy another combo.
Aug 31, 2015 | Toshiba MD13N3 13 in. TV/DVD Combo
Toshiba Regza 32LV67U DVD player won't play DVD. put dvd in, it makes 3 attempts to read then spits it out. Can I fix this or is this a take-it-in for service issue?
dvd player will only play movies for the COUNTRY in which you purchased it. There is no way to purchase a system or configure a system to play ALL MEDIA FOR ALL COUNTRIES. The country codes are specific and each country wants to prevent any other country from playing their dvds music, etc.
Jan 27, 2011 | Toshiba Regza 32LV67U 32 in. LCD HDTV
Dvd player not reading dvds
si reviso bin las conecciones prueve el dvd en otro tv
Aug 24, 2009 | Cyberhome CH-DVD 300 DVD Player
Dvd won't send picture/audio to tv
for video, 3ways and any of this should work.
Step1, video out of dvd to video in on top at video1 section on tv. or
Step2, svideo out of dvd to svideo in at video1 section on tv. or
Step3. using component video DVD unit component video out to TV unit component video in at video2 Y to Y input of TV Pb to Pb input of TV Pr to Pr input of TV
for audio, connect left/right audio of dvd to left/right input of tv. Input section of TV is in the middle. on tv back panel from left to right is antenna input, IN section - this is it, use this for all your connections. let us know if you have any issues. thanks.
May 02, 2009 | Panasonic DVD-S27 DVD Player
DVDs are playing with green tinge
Greetings and Salutations,
If your using the component outputs from your DVD player I would first check to make sure that the cables for the Red and Blue channels are connected properly. If the cable is connected correctly then try replacing both the Red and Blue channel cable. If this fails to fix the problem try connecting to another component input on your TV if you have one available.
You might also want to check to see if you switched on the progressive scan switch on the back of the VCR/DVD unit. If you know someone with another DVD player have them bring it over and see if the problem is still exists.
If the green picture is still present then the problem is and internal problem with the TV and you will need to find a repair center for it. If the problem goes away then the problem is with the VCR/DVD combo unit. You can at this point also try using just the Video Out from the DVD player.
Hope these suggestions will help you with your problem.
Jan 06, 2009 | Toshiba SD-37VSR Player
Toshiba 26AV502U (new) video dropout if VHS tapeis not perfect
Had problem checked by local outfit called "Circuit Pro"; their analysis was compatibility.
Actual answer was that the Toshiba required a better quality input from "any" VHS source.
I finally took a "less than perfect" VHS tape with me when I returned the Toshiba TV to the store and demonstrated the problem to one of the TV sales people. He played the VHS tape through a display VHS/DVD player to three different brands of TV. The picture was often "black screen" on a Toshiba, but was merely poor quality on the other two brands. I upgraded to a Sony KDL26M4000 from the Toshiba 26AV502U.
Dec 03, 2008 | Toshiba 26HF84 26" TV
I purchased a new Zenith Tv and have hooked up my dvd player which is about four years old (Toshiba). The connections are all right but when I put in any disk (I have tried many) it registers no disk so...
try to use player on old tv again does it still work 4 yrs old dvd player is to old for new days dvs on new tv u def wann upgrade to 108p upscaling player samsung makes with hdmi cable to new tv flat screen or reg coneection will look 10 times better also older toshibia cant play read new dvds its terrible
Oct 07, 2008 | Televison & Video
Some DVDs fade in and out
If you have it hooked up through your VCR this will happen. Try hooking it directly to your TV.
Jun 09, 2007 | Toshiba SD-K620 DVD Player
Televison & Video Logo
Top Televison & Video Experts
Electro Med Services...
