My samsung PS-WC450 sound bars sub woofer displays that it is powered up but I am not getting any sound?
hawkwatcher
  • 67 Answers
SOURCE: sr7200 LFE (sub woofer) output stopped working
Chances are if The Receiver only has sound in Stereo Direct Mode and all surround modes and Sub out are Inop the DSP (Digital Signal Processing) Card is most likey defective. These boards are not available from marantz (D&M Holdings) and must be Component level repaired which usually is not cheap. If Only the Sub out is not working check setup to be sure sub woofer is set for on. Also If On Screen setup menu does not appear on video monitor Unit may need to be Reset manually which entails discharging a Capaitor on main P.C.B Contact kstahl65@att.net for details
Posted on Jan 10, 2008
  • 120 Answers
SOURCE: sub woofer pioneer VSX-D412 5.1
you have a bad cable
Posted on Jan 17, 2009
mjjdesigns
  • 98 Answers
SOURCE: PROTECT DISPLAYED ON RECEIVER
This generally means you've got a short somewhere, and the received is trying to protect itself.
My suggestion is to disconnect all of your speakers at both ends, and reconnect them.
Most times this happens because a speaker wire is lose, and the positive and negative connections are touching each other, causing it to short out.
Posted on Mar 25, 2009
  • 3 Answers
SOURCE: I have a RX-v363 receiver all of the surround
The
  • RX-V363
has a special Sub-Woofer RCA jack located within the middle of the rear panel - look for the white rectangle area going from the top to halfway down the unit.
Posted on Jan 24, 2010
  • 46 Answers
SOURCE: How do I hook up a non powered sub woofer on my htr-5630?
You will need an amplifier or 2 channel receiver. Hook the sub out rca jack to the rca inputs on this new amp or receiver and hook the speaker terminals on sub to speaker terminals on same amp or receiver. Your Yamaha receiver doesn't have any power for a passive sub.Just pick up any old fairly high powered receiver for fifty dollars and you're good to go.I use old dolby pro logic receivers as they are a dime a dozen today. Good luck.
Posted on Mar 07, 2010
Samsung ps-we551 sound bar. no power at sub suspected lightning strike
Check and replace damaged component/s at its main power regulator [SMPS] section circuit. Contact any service technician. If you wish to get some details; check the site linked here. Pull up older posts.
Search the site by type in this keyword "sound bar"; in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jun 05, 2016 | Samsung Televison & Video
Samsung sub woofer # ps-wx810 will not connect to sound bar # ht-x810
Smash away. I don't think you can connect a wireless piece to a sound bar. This may be out of my wheelhouse, but I don't think so.
Feb 22, 2016 | Samsung HW-E450C 40" AirTrack Sound Bar...
Hooked up HW-D450 sound bar to Samsung UN40D6000SF TV with low output from sub woofer
Have you adjusted the subwoofer level? there should be buttons on the remote to adjust this level. Also, make sure you are not in a 'night' surround mode - this drops subwoofer levels a lot
Apr 08, 2015 | Samsung HW-D450 Sound Bar
How do i hook up my samsung hw-h450 wireless audio- sound bar to my pioneer pdp=4280hd
I think your set up is correct. The only other thing you may have to do is to set the sound on your TV to 'External Speaker' (or something similar) from your TV's remote accessing the menu.
Dec 21, 2014 | Pioneer Audio Players & Recorders
Trying to find out what type of sound bar that will work with my tv
any sound bar will work. i have a LG 50" with a Samsung sound bar with a optical audio wire going from my tv to the sound bar. it comes with a bluetooth sub woofer and it sounds great.
Feb 26, 2013 | Hisense Televison & Video
No I cant get my sub woffer to work woofer.There is power to the unit .I am trying to connest it to a sound bar which has a sub out.
If there is power to the woofer then a signal input must power the woofer to work. So feed a test signal or a audio siignal from a DVD and if there is no output then the AMPLIFIER section had faults.
Unless the sealed unit is opened it cannot be tested to confirm if the output , the input to the AMP or the power supply has failed.
Check if there is power to the output section to confirm.
Jul 29, 2011 | Proficient S12 Subwoofer
Hello! Pls, send diagram connector to sub-woofer Samsung HT-DS1000. I want to connect low signal(Sub woofer) direct to amplifier. If connect to AUX - sub woofer sound with delay, no good sound. Thank...
The speaker connections are documented in the manual.
Register and download the manual for free at retrevo.com
http://www.retrevo.com/support/Samsung-HT-DS1000-Home-Theater-Systems-manual/id/287ci764/t/2/
Are we talking about an external add-on sub not supplied with the HT-DS1000? If so, please identify it.
The interconnecting cable itself is a 13-pin DIN.
Mar 07, 2011 | Samsung HT-DS1000 System
546 people viewed this question
 Grubhead
Grubhead
