Question about Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television
How to set default channel sony bravia av1 to hdmi ?
welcomejee
  • 10594 Answers
SOURCE: after power on my Sony bravia it goes to Digital
While tv in On position, select AV1, push power button to standy, then unplug tv for 5 minuts. check the out come.
Posted on Aug 03, 2008
SOURCE: Sony Bravia television hdmi stopped working
Installing a new software update will this issue. All you need is a compatible USB flash drive. Go to support on Sony.com. Look up your tv model and if there is an update, just follow the instructions to install it yourself. I have a KDL-46S5100 and this worked great. The download and instructions page I used was : http://esupport.sony.com/US/perl/swu-download.pl?upd_id=4769#install
Posted on Oct 10, 2009
vinnyq
  • 157 Answers
SOURCE: My Bravia KDL-40S4100 lost all 3 of it's HDMI
There is a problem with the processor. The only way to resolve this issue is to replace the main board. It is called the A board in your TV.
There are two for this model and the correct one will depend on what your serial number is.
Part numbers are as follows:
part # 185709211 for Serial #
1,000,001 - 1,350,000
1,700,001 - 1,750,000
1,800,001 - 1,804,270
1,804,271 - 1,818,372
1,818,373 - 1,830,000
list price: $504.87 core charge: $680.00
part # 185709231 for all other serial numbers
list price: $505.87 core charge: $600.00
Posted on Nov 09, 2009
Testimonial: "Thanks, Now I wonder who all shares the same problem and if Sony is willing to do something about their defective products..."
BElectric
  • 1140 Answers
SOURCE: How do I switch to
All you need to do is press the TV/VIDEO button in the top left corner of your remote. Each time you press, it will cycle through the connected external inputs, e.g. AV1, AV2, etc.
Hope this helps.
BElectric
Posted on Nov 23, 2010
SOURCE: TV will not remember settings Sony Bravia KDL 40S4011
Probably you are in "shop" mode of TV. Try to reset your TV and go through initial setup. Most important - choose "home" instead of "shop" when asked during initial setup. Resetting - keep up arrow pressed and switch of TV. Keep the button pressed when TV automatically switch back on. This will reset TV to factory defaults.
Posted on Jan 09, 2011
I have a Sony Bravia TV and the screen seems to be locked on AV1 I can here the cable channel but can't see the picture. Is there any way for me to unlock the setting so I can see the picture?
Please try this:
With your remote set on AV1, push the input button and try to change the input using the up and down arrows. You want to set it on cable or whatever your TV input normally says. I have Satellite TV and mine says satellite. You should be able to easily change it with the input button. If you can't do it, change the setting on your remote to TV and then try the same procedure. The Sony Bravia has manual controls on top of the set as well. If you are unable to change your input using the remote, try the manual controls, however, your remote does need to be reset for the correct setting as well. Using the manual controls will just help you check to see if there is actually a problem with your TV. Is this a new TV, new problem?Have you changed batteries in your remote recently?
I hope this helps you. If not get back to me, and let me know.
Thank you for using FixYa.
Dec 26, 2010 | Sony Bravia KDL-32V4000 32 in. LCD TV
Ghosting on hdmi channel on my sony bravia
With HDMI there should be no ghosting. And being a Sony Bravia it should be no ghosting. My 52" Sony is great.
You've got connection issues.
Nov 25, 2009 | Sony Televison & Video
No image at menu 'digital'
you connected the converter to AV1 that is the ONLY place you will recieve any signal leave the tv in av1 and run setup on the converter ONLY you should be all set
Nov 20, 2009 | Sony BRAVIA KDL-40S2010 40 in. LCD...
How do you connect bt vision to a sony bravia kdl 37v4000.I have it working ok on freeview only but the bt vision appears on analogue channel 6 and the vision remote changes the tele channel not the vision...
Sounds like you cant have set up the scart cables properly. Im unimpressed with BT for not setting it up for you, why didn't they?
Plus you will not need the freeview box if you have BT Vision, so i would take out the freeview box and just connect one end of the Scart lead into the back of the BT Vison box then put the other side of the lead to the Back of the TVs scart socket. Then all you need to do now if change the channel to AV1 OR AV2 or whatever channel you have.
Jul 23, 2009 | Sony Bravia KDL-37L4000 37 in. LCD HDTV
Ps3 starts and the green light is on but no image omes up on my
Try connecting the PS3 to your TV with a scart cable first and go to the appropriate channel. The problem you are facing is probably because the default output is not HD. So you must change it to HD you can do this by going on your PS3 display settings, whilst your operating on standard definition, AV1 or something like that. When the you are on display settings plug the HD cable in the PS3 while still being on AV1 and then plug the cable in, this may prompt a message saying that a HDMI device has been detected and you can change to HD, if this message appears switch to the HDMI output and then select yes and automatic on the PS3 for optimal settings in HD. If the message does not appear then select the HD output yourself after plugging the HDMI cable in and then change to the channel and do the same.
Jul 20, 2009 | Sony Playstation 3 (PS3) Console
I just got cable and I cant get the channels to come in as cable channels. I lost my manual and have a universal remote?
Hi gail dahl,
I am happy to help.
From the Video Menu the Tuning Band must be set to Cable and not to AIR or Antenna. You will nee to run Auto Scan for channels from the Menu also.
I have provided a link to download the manual. http://esupport.sony.com/US/perl/model-documents.pl?mdl=KDL40XBR2&LOC=3
Let me know if you need further assistance and please rate this solution. FixYa.
Lone99star
Jan 31, 2009 | Sony BRAVIA KDL-40XBR2 40 in. LCD HDTV
Sony bravia kdl40l4000 hdmi issue
i have sony bravia. i couldn't connect to my ps3 with hdmi cable. but i get only audio. i think it is with the tv settings. can you help
Dec 08, 2008 | Sony BRAVIA KDL-40S2000 40 in. LCD HDTV
PS3 to sony bravia
If you have an HDMI cable hooked up to the PS3 and the TV, you have to set the TV to the HDMI channel.
Oct 26, 2008 | Philips 19PFL5622D/37 19 in. LCD...
On Timer - channel selection
The on timer will only work for a channel on this model not for any other inputs
Mar 04, 2008 | Sony BRAVIA KDL-40V3000 Television
Sony BRAVIA KLV-S40A10 40 in. HD-Ready LCD Television Logo
364 people viewed this question
Top Sony Televison & Video Experts
Are you a Sony Televison and Video Expert? Answer questions, earn points and help others
