Question about Toshiba 42HL196 42 in. LCD HDTV
Same as others no answers black screen blinks three times red clicks once pause then two more clicks looked at cap look ok what next fuse ok
Nothing is plugged in could itbe asleep on timer have another remote not the regza where next just didn't start one day could it be because of power failure on grid if I freeze it out in cold could that help it start? Think help
  • Jims Dec 09, 2012
    Obvious toshiba made a lot of the same mistakes and don't have any answers
    Top Expert:
  • Toshiba Master
  • 74,634 Answers
Visit the site named 'Electro-help' for more details. Click this link. View it in "Timeslide" or "Flipcard" option, which can be selected from the drop down box menu by the [Sidebar] tag, at the top left corner of the display window. You can also click the [Home] tab to see the latest updates. It will make search easy. There are more than 1350 posts to different brand TVs now. Pull up older posts there or do a search by type in the Brand Name of your device in the Search Box, at the top right of the display window.
Posted on Dec 09, 2012
djchillsnyc
  • 152 Answers
SOURCE: Toshiba Regza with red LED blinking
hello the red blinking lights is a service code when this happens it means theres a power problem or a fualty circut. it happens alot with these new plasma and lcd tv's its very common since these units have built in protection and power loss a fualt or short will cuase this.
the tv needs service the tech will know what to look for according to the number of blinks.
hope this helps.
Posted on Dec 18, 2008
  • 7 Answers
SOURCE: tv will not turn on. timer light constantly blinks
If you can get into the main menu go to load factory default and reboot, This will reload factory settings and this operation will erase all unwanted settings and load back to factory default. so you can load your own settings and take back control of your tv.
Posted on Feb 23, 2010
  • 732 Answers
SOURCE: Toshiba regza went black, then the northen lights appered!
prosit, If unit can be opened, I recommend you visually inspect the main power supply printed circuit board for "bad" electrolytic filter capacitors that may be faulty and failed prematurely! Lots of DIY videos at YOUTUBE that you should view before doing a "teardown" !!! Remember THIS!!! You MUST document your teardown with video or digital stills so before disconnecting any connectors to the board so you can put unit back together exactly as it was before you started any board repair work!! e.g. replacement of filter capacitors, fuses, resistors, and solder joint inspection of through-hole and or surface mounted active and passive components. DO YOUR WEB RESEARCH OF YOUTUBE VIDEOS FIRST!!!! Good luck guy. Keep us tech's informed of your progress by doing additional posts (comments) here on fixya. 12fixlouie
Posted on May 25, 2010
SOURCE: Our Toshiba Regza won't turn on.
Down load this firmware file p/n 2007SEN069 from this address http://www.tacp.toshiba.com/customersupport/model_firmware.asp?model=26hl67. The instructions are here also. Un zip to a blank sd card. I'm not sure if the set will boot to the card or not.
I finally got the tv to boot by constantly plugging in the a/c power and unplugging the power until it filally booted and was able to turn the set on.
Remove the sd slot cover from the lower right rear of the set, and insert the sd card with the unzipped firmware. Monitor the screen and follow instructions. Do not remove the card until the set powers off.
This fixed mine, hope others benefit from this repair.
David
Posted on Jun 28, 2010
  • 339 Answers
SOURCE: 42" Regza #42RV530U won't turn on. Was working
not being funny but have tried changing the fuse or the mains lead if it plugs in the t.v
Posted on Jan 24, 2011
How do i fix a flatscreen with no sound or no picture
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
If blinks continue without any pause, the main board is faulty.
Search the site by type in the "brand name" to your device, in the "Search box at the top right of the display window of the Homepage" to get gathered related posts.
Jul 26, 2016 | Televison & Video
Red flashes 6 times and pause for three secs
Using the remote, open the system menu and reset the tv.
Mar 07, 2015 | Sony Bravia Kdl-55ex500 55 Tv, Series Lcd...
What may cause screen to turn green and then black out.? power LED is blinking three times then pause and repeat. unplugging tv did not resolve problem. single click can be heard from center of tv wh
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. Viewing it in "Mosaic" or "Magazine" will make surf easy.
Blinking codes details to many popular brand TVs are given. Surf the site with patience. Do a search by type in the brand name of the device to the search box.
Counting of number of blinks to Philips TVs is entirely different to that of other brand TVs. It is not a direct count procedure. The site have details about how to count the number of LED blinks [Fault Codes] to Philips brand TVs are given; along with details of the faulty circuit location.
Jul 05, 2014 | Toshiba Regza 55SV670U LCD TV
I’m having a problem with my Toshiba 42HL196. Once or twice the red LED was flashing and I held the power button in for a bit and it started working again. Today I was having cable installed and after a...
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://homenol.blogspot.com/
Mar 13, 2017 | Toshiba 42HL196 42 in. LCD HDTV
When i go to turn on the tv the red power light turns on and then starts flashing, with an all blank tv screen. I cant get anything but a black screen. The light will flash for a lil while, then the tv...
BLINKING RED LIGHT IS ERROR CODE.
1. Unplug set for a few minutes.
2. Plug back in and turn on.
3. When red power light starts blinking--COUNT THE BLINKS.
4. THREE BLINKS, pause, THREE BLINKS (ETC) IS SHORT PROTECTION AND A DO IT YOURSELF repair for some people. I have complete instructions for this repair.
5. 5 blinks, pause and 5 blinks etc is short on 140 volt line and while not as easy as 3 blink error code it points to places to look at.
If this told you something you did not know, rate this solution as very helpful as I do this here for free.
Post a comment here when you know what error code is and I will help.
REGARDS, SD TECH
Aug 16, 2010 | Panasonic PT-47WX53 47" Rear Projection...
Have a hd52w56 when power up lcd blinks 3 times and then goes off... I have replaced the green tube(was cracked) and then was working . then the screen went green and the fuses popped, change the fuses and...
On your Deflection board it is the one on bottom to the left CK capacitors cp150 2200uf 16v if it is puffed up ont op it is Bad replace 2 more caps in same circuit cp114 cp120 220uf 35v resolder all pins on FBT flyback transfomer.
Nov 10, 2009 | RCA HD52W56 52" Rear Projection HDTV
Black screen and no sound on TV
what is the brand, model? try to be specific if you want be helped!!!
Sep 11, 2009 | Televison & Video
Screen went black no sound no picture when i turn the power on power light comes on green i hear a click and then it goes blinking red
How many times red light blinks? It is error code of problem in TV.
There would be pause of 3 seconds between blinks so count from pause to pause and let me know to find out solution.
Aug 14, 2009 | Sony KDF-E55A20 55 in. LCD Television
Toshiba 42HL196 42 in. LCD HDTV Logo
43 people viewed this question
Top Toshiba Televison & Video Experts
Jaime Hernandez
Are you a Toshiba Televison and Video Expert? Answer questions, earn points and help others
