Question about Tasco Optics
Reset adjustments on tasco pronghorn scope - Tasco Optics
5 Suggested Answers
SOURCE: zeroing scope adjustment
First, adjust wind-age and elevation to center or zero position. Remove your scope from the gun and make sure that the scope mounts are aligned, this is critical. Purchase an alignment tool is necessary. Then remount the scope. The scope should seat in the mounts without binding. If it does bind, the mounts are not aligned.
Start sighting in at close range,10 to 30 yards, then move out to 100 yards.
Posted on Jan 25, 2009
agent91
  • 2100 Answers
SOURCE: not a problem but need operation instruction for
I believe the second cross hair in your scope relates to an 18 inch dimension, or that of a deer. When you adj the wire to the body of a deer, it will be the distance, I'm not sure if you have to do the math, or the scope does it for you. Some scopes, you had to figure the hold over by the distance in the scope. others would be set to shoot at that distance. I would ave to look that one for you to be sure, but that is the idea. Hope this helps.
Posted on Mar 21, 2010
SOURCE: i have a tasco 4x32 pronghorn scope for about 10
why my scope, has change it sights in after firing?
Posted on Sep 06, 2010
  • 243 Answers
SOURCE: HAVE A PRONGHORN TASCO MOUNTED
No, this is not a scope issue. The scope is raised above the centerline of the barrel, thus at 10 yards, the barrell is actually slightly raised in relation to the centerline of the scope in order to hit your point of aim. Since the front of the barrel is slightly inclined, at 25 yards the bullet is still rising in relation to the scope alignment. Backing up to 50 yards you will begin to see the bullet start to drop back down, at 100 yards it may drop as much as 8-10 inches, and at 200 yards, it may drop as much as 52 inches. This is assuming that you are shooting a standard velocity .22 long rifle cartridge (1050 feet per second or so).
Posted on Sep 23, 2010
HAVE A PRONGHORN TASCO MOUNTED ON SAVAGE 22 BOLT. SIGHTS IN OKAY AT 10 YARDS AND THEN IS HIGH AT 25. IS THERE AN ADJUSTMENT INTERNALLY IN SCOPE TO FIX THIS?
Sep 10, 2010 | Tasco Pronghorn 3-9x50mm 30/30 Riflescope...
Why does my scope has changed it sights in every after firing
this sounds like one of two faults,,,
the scope mounts are loose or
the scope has a fault inside it ,,,ie the recoial is to much for the scope to handel
Sep 06, 2010 | Tasco Pronghorn® 4 x 32 mm Black Matte...
Tasco Silver Antler .22 3-9X32 while shooting rifle, scope jumped off, remounted scope, now can not adjust cross hairs, can I fix this myself?
if the scope tok a hard smck when it jumped off the rail i would say its broke the adjusters in the scope,,they can jump off there mountings if hit hard getting it fixed will cost more that the scope is worth,, if it was my scope i would just bin it and but a new scope,,and not a tasco one!
Aug 26, 2010 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
How to reset to zero a Tasco RF3- 7X20 Scope? I am having prblems centering this scope Thank You
Making sure it is correctly fitted to the rifle, you Bore sight it. Best to put it into a vice using a thick piece of blanket to protect the rifle. Looking through the bore you line it up on an object about 10 to 20 meters away. Then you adjust the scope to fix the crosshairs on that same object. This will get you approximately on target. Depending on what a where you are going to shoot, assuming you are using a rimfire rifle, You then set up a target about 30 to 35 meters away. And adjust your scope to center on this target. That will give you dead aim at 30 meters and again at 90 meters, with only a slight variation in height in the middle.
Feb 04, 2010 | Tasco RF37X20D 3-7x20 Rimfire Riflescope -...
I have a 3-12 by 40 rifle scope made by tasco i dont have thewaranty paper work any more and the cross hairs wont adjust any more what do i do
i dont realy understand what you mean by "the cross hairs wont adjust" is it you have ran out of adjustment on the turrets? if so try packing the scope out with 35mm film under the body of the scope and reclamping it,,,or do you mean it just wont adjust?
the tesco rifle scope is a realy cheep scope its a throw away kind of thing if it brakes,,,,there only £50 or so,,,,if it was a £1500 scope its worth fixing
Nov 16, 2009 | Tasco 3-9x32 .22 Riflescope W/ Rings,...
Not a problem but need operation instruction for my scope.Its a tasco pronghorn 3x9x40 with adjustable yardage and has two elavation cross hairs,I have had it for many years and it works perfect,but I have...
Nov 11, 2009 | Tasco PH39X40D 3-9x40 Pronghorn Riflescope...
Zeroing scope adjustment
Jan 03, 2009 | Tasco 3-9x40 World Class Riflescope 30/30...
PARTS FOR A TASCO RIFLE SCOPE
Hi, I think they can be found on amazon. here: Amazon com tasco rifle scope parts I hope this was helpful. cheers
Dec 07, 2008 | Tasco ® Silver Antler® 3-9x40 mm Scope...
Optics Logo
32 people viewed this question
Top Tasco Optics Experts
Joe Lalumia aka...
Joe Lalumia aka...
Mark Campeau
Level 1 Expert
Are you a Tasco Optic Expert? Answer questions, earn points and help others
