Question about Canon NP 6551 Black and White Copier
E212 message Normally w
  • Canon Expert
  • 1,326 Answers
Error code means something is wrong with the scanner of the copier, it could be the lens is not moving or the scanner is not finding HP. Also, are you getting blank copies? If so you have a blown scanning lamp.
Posted on Jan 23, 2009
"E212" Lens problem (sensor, motor)
You have a very old copier..... Try taking the copy board glass off and the lens cover (black box) off. Try to move the lens with your hand, will it move? Move it out of HP and turn the power ON. Will the lens move, if so look where it stops.... I believe there is a drive gear that may of cracked... You have to watch were it stop moving....Good Luck
Jan 15, 2013 | Canon NP 6050 Copier
Error E212
vaya y baje el manual de instrucciones para ver errores:
www.servicemanuals.net o www.angefirecom or www.schematicx.com or www.2manuals.com or www.copierrepair.net or www. retrevo.com or www. eserviceinfo.com
Dios le bendiga
May 09, 2012 | Canon NP 6230 Copier
What's the mining of error 212?
E212 : fault in lens Y direction drive system check the sensor clean it or replace the motor:
Dec 05, 2010 | Canon NP 6230 Copier
Code error E212, with 3 options: Command card Initial detector Moving device somethig like that
E212: problem with the optical section
  1. Home position sensor is defective
  2. Motor Lens move iis defective
  3. Control board is defective
Oct 16, 2010 | Canon NP 6551 Black and White Copier
Canon NP6050 E212 -lense problem
change the small gear located (inside in lens drive assambly motor)
Feb 02, 2009 | Canon NP 6551 Black and White Copier
E212 Error code
"E212" Lens problem (sensor, motor)lift document feeder and look inside. is the lens stuck? when turned on it goes back and forth to check where it is
Aug 11, 2008 | Canon NP 6545 Copier
Error code E212
sorry I have'it only in italian
Jul 11, 2008 | Canon NP 6035 Copier
CANNON NP6025
E212 is scanner home position error.remove the platen glass. Check the scanner and lense assembly.
Sep 01, 2007 | Gestetner DSc224 Copier
Problem with my copier
Mesin Saya 6035 Error 224 gimana atasinya
Jun 27, 2007 | Canon NP 6035 Copier
Canon NP 6551 Black and White Copier Logo
91 people viewed this question
old marine
old marine
