Question about Husqvarna Chain Saw 20" Bar
Chain is not moving, with engine running; it was working fine but then stopped. The chain oil tank was empty or thereabouts when I looked into it although when I opened the chain guard cover oil, was flowing out. Would the chain have overheated and seized?
  • Anonymous Mar 23, 2014
    Chain moves at idle
Take a look down the bar at the cluch.to see that the chain is running strate between the bar and cluch. I had a problem on a homelite. The cluch moved over and put the chain in a bind. had the cluch replaced to fix the problem.
Posted on Jun 22, 2009
    Sergeant:
  • 359 Answers
ARE YOU SURE THE KICK BACK BAR IS NOT ENGAGED , IF YOU HAVE PULLED IT BACK VIGOROUSLY AND STILL HAVE PROBLEM IT IS PROBABLY NOT ENGAGED , THEN THE NEXT BEST CK IS TO REMOVE THE BAR AND COVER ,LAY DOWN AS IT CAME OFF SO NO MIX UP IN RE-INSTALL WITH IT OFF SEE IF THE DRIVE GEAR IS TURNING IF SO PROBLEM COULD BE IN BAR , YOU MIGHT ALSO TRY TO LOOSEN THE CHAIN UP A WEE BIT AND SEE IF THIS HELPS , REMEMBER WEAR SAFETY GLASSES AND GLOVES AND STAY CLEAR OF ALL MOVING PARTS
Posted on Jan 13, 2009
What are usual suspects that stops a car while driving?
broken timing belt/chain is a good one
no fuel ( tank empty , fuel pump not working, problem pressure regulator )
crank/cam shaft position sensors failing --wiring
immobilizer activating
ignition control module failure
failing ECM
engine seized form over heat / lack of oil
Oct 04, 2016 | Cars & Trucks
Chain oil is not flowing through to lube the chain
Remove the side case on the chain clutch, remove the bar and chain, clean then oil ports thoroughly, clean the chain bar completely. Empty the chain oil tank and flush it with gasoline, there's a filter in the tank the gas will clean it, put it all back together and it should work fine. I've used Stihl for 25 years and never had any other problems with the chanin oil system.
Aug 20, 2014 | Stihl Garden
What would make my nissan truck stop running
The fuel tank being empty, bad fuel in the tank, the fuel filter is clogged, the fuel pump stopped working, the ecm malfunctioned, engine overheated, the ignition switch malfunctioned, charging system failure, a broken timing belt/chain, hitting something really hard at 60mph...etc...etc.
Jul 20, 2013 | Cars & Trucks
My craftsman chain saw starts and runs good until I turn it on its side to make a flush cut then it stalls.
Check to see if there is a fuel filter on the fuel line in the tank or some kind of weight to move the fuel line into the fuel when you tip it.If you run the saw with the bar vertical will it empty the tank? If it does not empty the tank look for a cracked line inside the tank. Also check to see if the line in the tank is very flexable so it can move to the fuel.
Apr 09, 2013 | Craftsman Garden
Chain oil leaks out quickly a rancher 55
Remove the bar and chain. Clean the engine side case where the bar fits. Does the oil port itself leak or is it coming from the engine case? If from the case, it may be a loose or split line from the tank or it could be a cracked oil tank. If the tank is cracked, replace it as there is no glue or epoxy that can permanently repair it. If the leakage seems to have stopped, clean the drive end of the bar including the two small oil passages that run out to the chain groove. Re-assemble the bar and chain, then run the bar tip at speed near some cardboard for a few moments--it should throw off a thin line of oil. This saw should have an oil volume adjustment screw located near the chain return area on the back or underneath the case. Adjust CW to reduce the oil volume. Hope some of this helps!
Jul 11, 2010 | Husqvarna Chain Saw 20" Bar
Tunning specification for a stihl 028 chainsaw?
I'm not sure there are any "endorsed" tuning specs from Stihl as weather, temperature, fuel quality etc all contribute to engine performance.
Pictures of all types are all over the web.
As for the carb tuning procedure, maybe I can help?
Start with fresh fuel, all filters clean, and bar and chain installed. Also, fill the chain oil tank with bar/chain oil and VERIFY that the chain oiler works properly.
Initial fuel mixture settings (the H and L screws) should be 1.5 - 2 complete revolutions counter clockwise from lightly seated. Sight the carb's throttle plate and adjust idle screw counter clockwise until the plate stops moving.(Throttle closed completely.) Then go back clockwise 3 complete revolutions. This will produce an acceptable startup condition on a HEALTHY saw.
Clamp the bar in a STURDY bench vise and roll the chain with the shank of a screwdriver to verify it is clear. BE SAFE!
Choke the saw and pull the starter rope until the engine "burps".
NOTE: If no burp after 6 pulls, stop! Something is wrong.
After the burp, set choke to half and pull starter until it runs. The settings I gave should produce a slightly rich condition and a slightly high idle. (Chain will be in motion!)
Blip the throttle trigger and idle it down just enough to keep it running during the tune procedure.
Step 1) Using the "L" screw (closest to the engine), turn it clockwise until the engine smooths out or possibly increases RPM. Back it out slightly until the engine has a slight "LOPE" sound to it. (Like a drag car on nitro).
Step 2) Accelerate the engine to full throttle and go to the "H" screw (closest to the air filter) and slowly turn it clockwise and note the RPM increase. There will come a point when the saw will "Top-Out" and loose power. Not even enough power to turn an maintain empty chain's RPM! Go back counter clockwise to the edge of that point, and counter clockwise another fourth (1/4) revolution.
Step 3) Idle the saw back down. Again go to the "L" screw and repeat Step 1.
Step 4) Repeat Step 2.
Step 5) Idle the saw down until the chain stops moving completely. NOTE: Don't settle for a "crawling chain" condition. If the steps above are performed well and all else is healthy, you should be able to idle the engine down to a ridiculously low RPM and it will not shut off.
Hope this helps,
Dolf-
Oct 13, 2009 | RTO Spur Sprocket For Stihl 017, 021...
Makes high pitch humming sound, chain and bar heats up. Saw doesnt' cut
The bar and chain are running without oil. Take the side cover off where the chain is driven from and remove the bar and chain. Use compressed air to blow all debris from the area. Start the engine and watch for oil coming out of a small port near the clutch assembly. If oil passes (good!), then clean ( at the drive end of the bar) the two smaller holes and their passages into the track which the chain runs in. They are likely to be filled with sawdust and other debris. Clean the entire chain track around the whole bar. Use engine oil in the two small holes at the bar tip to lubricate the sprocket bearing. Back off the chain adjuster screw somewhat and reassemble everything--put the bar on first and then work the chain on, then the side cover--work the bar fore and aft to allow the small tang of the adjuster to drop into it's hole at the bar rear. Make sure that the cutting side of the teeth are pointing toward the engine on the bar bottom. With the cover on and mounting nuts slightly loose, adjust the chain tightness so that the chain doesn't droop away from the bar bottom, but still allows the chain to be moved by hand--remember to lightly oil the chain first with engine oil. Tighten the bar mounting nut(s) and recheck the chain for droop. Make sure that you have bar oil in the tank, then start the engine and hold the bar tip near a piece of paper or cardboard. After running for a little while, the tip should throw off a very thin line of oil. Next, if you have a vise, put the bar center into the vise so that the chain is free to turn. At this point you need to file each tooth to sharpness at 30 degrees from perpendicular to the bar and 10 degrees below chain horizontal. Make sure you use the correct size file for your chain. Work your way through one side, then work the other side--be consistent with cutting angles during filing as uneven filing will result in the chain trying to cut at unintended angles.
If no oil came out of the engine when running the bar-off test, make sure there is ample oil in the tank, then you have either a plugged inlet filter in the tank, tubing kink/breakage, or a defective oil pump. You must be sure that oil is being pumped from the chain drive area before putting things together. Hope this helps!
Aug 14, 2009 | Husqvarna Craftsman 36cc, 16 In. Gas Chain...
Loss of power
Don't continue to try for high speed operation until the problem is rectified. Look for loss of chain oil or the chain is too tight. If it is equipped with a chain brake, make sure that it isn't dragging on the clutch rim. (It would be very hot or blue colored.) If no oil, remove the bar and chain--run the engine and watch for oil coming out of a port near the sprocket end. If it does so, clean the holes in the drive end of the bar, especially the small holes that connect to the chain track slot. Adjust the bar to tighten the chain enough that the chain doesn't begin to droop from the bar, yet turn freely by hand. If no oil comes out of the port, then the oil lines or the oil pump are/is faulty. Be sure to use bar oil only in the tank?
Aug 11, 2009 | Husqvarna , No.455 Rancher, 20" Gas -...
Mccullough chain saw pm610 chain slips -- maybe clutch issue
have you greased your clutch bearing ever.some times they get dirty and tighten up after running a while.pull your clutch off and clean and grease bearing with a little alex grease,and I mean just a few drops.not meant to have a lot of it,too much will burn the crank shaft and you will have more problems then you started with
Jan 01, 2009 | Garden
Ryobi 40cc chain saw oiler not working correctly
Hi
Check and clean the oil filter from oil tank.Check the worm gear wich engages with the oil piston pump(under the clutch).Near the hole where the oil comes out from oil tank there is an oil tank valve(see if it is clogged),it equalises the presure between interior and exterior of the oil tank.
best reagards savumihai71
Dec 23, 2008 | Husqvarna Chain Saw 20" Bar
Husqvarna Chain Saw 20" Bar Logo
190 people viewed this question
Top Husqvarna Garden Experts
Phil Walker
Phil Walker
Roland W VanLue
Roland W VanLue
Are you a Husqvarna Garden Expert? Answer questions, earn points and help others
