Question about McCulloch 13HP 338 Cc Portable Generator # FG6000MK
Need a part from McCullom model 5700 generator?
The part consist of the pull string and handle in one piece. The part goes on the pulley to start the engine. Can you assist me to were to order a quality part for this McCullom model 5700 generator.
2 Suggested Answers
  • 31 Answers
SOURCE: Where can I buy a mcculloch 5700 generator carburator
if you can not find a carburator you may need to find a re-built kit on the internet.
Posted on Aug 28, 2012
Replace Cord
Take the cover off the top of the motor witch I think it is like 5 or 6 10 mm bolts take them out and u should have pull starter in that. So wind the the spring till its pretty tight and the cord u should have already put the handle on feed the other end of the rope thru the wound tight spring and put it thru the hole on the plastic piece in the center that u wound up and tie a double knot and then slowly let it wind it back in. if it stops before all the string goes in there is either to much string or u didnt wind it enough before u put the string in it. It should take like three foot of rope if the handle is at the motor but if the handgrip is up the handle u will need like 9 feet of rope
May 04, 2013 | Mtd 22" Yard Machine Push Mower
Replace the pull rope
That is the fun part! You have to leave the handle end free, as in no handle on it, put a good knot in one end of your new pull cord, feed it through the hole in the pulley, feeding it out so you can pull it back into the space where the pulley is. Should be a slot on the pulley to bring it up in. Wind pulley against spring, same direction as normally pulled when starting, will need three to six rounds, can't tell how many cause it varies. Stick cord out hole to where handle should be while keeping tension on spring so you don't lose it. Tie handle on and try it. You may have to adjust rounds against spring and length of cord until you get it right. Good luck!
Aug 27, 2012 | Buffalo Tools 4,000 Watt 6.5 Hp Portable...
I have a craftsman walk behind lawnmower and my pull string will not start the motor and it doesn't lock
The small metal peice is the engagment pawl, it sits into the plastic pulley, if it has come out the pulley will probably be damaged as well, you will need to remove the pulley securing screw and big washer, you should now see the slot in the pulley where the pawl sits.
May 12, 2012 | Yard Machines 158cc Push Lawn Mower #11a...
The pull starter on my Morrison BC260B S2 won't
hello sir, i'm guessing the rope is broken , first you'll need a c-clamp large enough to clamp the spooler, needle-nose pliers,a small tipped screwdriver and a new length of rope.the safest way is to remove the rewind assembly cover leaving the spooler in place in its housing. try to remove the old rope with neddle nose pliers ans small tipped screwdriver.next hand spin the spooler to achieve spring tension until stops back off enough to line holes up, place c-clamp to hold it in place,now try to fish the new rope into the hole in the knot recess,trying to guide it to the exit hole in the cover, ( it's easier to feed the rope if you singe the end of the rope with a bic lighter and form to a point )and with a small knot at the other end,pull the rope all the way until you can seat the knot into the knot recess.next tie a loop knot into the other end of the rope,so the end wont be recoiled all the way into the housing.with tesion on the rope gently remove the c-clamp and let the rope be drawed in.if it draws all the way to the loop knot, check to see if the spooler is full if so,( not too full where rope is binding ) pull the rope about a foot and re clamp the spooler and install the pull handle, if rope is too long you may have to cut to length. if it doesn't draw all the way to the loop knot and the spooler is not full than you may need to add anoyher revolution to the spring tension in the same fashion as described above.there are eisier ways but that evolves removal of the spooler and repacking the reciol spring.( not for the novice ). hope this helps,thank you.
Feb 18, 2012 | Garden
Need to relace starter rope
Remove the cover from the side of the blower that contains the pull start. This usually involves removing the self-tapping screws that join the two halves of the blower housing together.
  • 2
  • Remove the broken rope from the starter pulley. Usually the rope is attached to the pulley with a simple overhand knot; just grab the knot and pull the rope back through the hole in the pulley. Sometimes the rope is attached to the pulley with a staple or some other fastener, which you'll have to remove first.
  • 3 Remove the handle from the replacement rope, if it's already attached.
  • 4 Thread the end of the rope opposite the handle through the hole in the starter pulley, working from the inside of the pulley (the side facing in toward the engine).
  • 5 Fasten the rope to the pulley. If it attaches with a knot, simply tie an overhand knot, pull it tight and trim off any excess rope sticking out of the knot. If it attaches with a fastener, replace the fastener.
  • 6 Wrap the rope counterclockwise around the pulley until the pulley is full; this usually involves one or two wraps.
  • 7 Thread the free end of the rope through the hole in the blower housing.
  • 8 Replace the blower housing and screw it in place.
  • 9 Trim off excess rope, leaving about 6 inches of rope protruding from the blower housing.
  • 10 Attach the handle to the starter rope. This typically involves threading the rope through one or two holes in the handle and securing with an overhand knot.
  • Read more: How Do I Replace a Pull String on a Hand Held Blower? ' eHow.com http://www.ehow.com/how_6920861_do-string-hand-held-blower_.html#ixzz1DKqEmA1w
    Feb 07, 2011 | Homelite Garden
    Replacing start rope of the b&s model # 120600
    Take off the three-four bolts holding on the starter cover and lift it off the engine. Make sure you dont leave the oil dipper attached too.
    Remove its bolt at the cover so it doesnt come out of the engine block and make a mess.
    Flip the cover over and you should see the pulley the rope rides in. Pull out the broken end piece of the rope from the inside-center of this pulley. Get a new piece of rope from a power equipment store. Make sure you get enough to cover the length needed to make it all the way out to the handle! Snake into the recoil cover from the outside hole into the pulley *(you align the pulley with the hole in the cover) with small needle nose pliers you can pick the rope through the pulley hole and then tie a knot to secure this end of things. A butane lighter is good to use on the frayed end to "melt lock" it. Nothing crazy now...just melt the tip where you see the frayed material.
    Then put the t handle on the other end and tie it off too. Also melt the frayed end before pulling the rope into the t handle.
    Now that the rope is in place all you need to do is prewind the pulley. This is done by using a small section of the rope near the pulley to turn it in the direction of starting about 6-8 turns and then carefully release the pulley so it winds the rope onto it. You can do this slowly by keeping tension on the T handle and slowly walking it into the starter cover. Be careful. You dont want to get your fingers caught on anything spinning or pulling here. The rope will be twisted so the person holding tension on the rope can help by untwisting the rope so it can rewind smoothly.
    That is about it. You can then pull the rope a few times to make sure you put enough prewind on it so the rope doesnt stop pulling even though you have more rope to pull *(this is to prevent causing the recoil spring binding from insufficient prewinding)
    Put the recoil cover back on. Put the t handle back into the fixture on the mower handle. Thats it! Start her up and go cut some grass!
    Good luck and be careful!
    Oct 12, 2010 | Yard Machines 11A54MC006 21Inch 139cc MTD...
    Homelite 25cc model UT20002A. How to repalce starter string?
    Remove the shaft assembly at the motor, there should be one or two screws on the boom clamp. Remove the four screws holding the starter housing on. Inside the front of the housing is an air baffle you don't have to remove and the starter pulley. Remove it carefully, you don't want the spring to come out of its container. Remove any vestiges of the old starter rope and install the new one with no more than three or four windings depending on the thickness of the rope you bought. Install the pulley in the housing with the rope through the slot in the pulley so you can wind it a couple times to catch the spring and start the tension. It should be tight enough to just pull the string back into the housing. Feed the rope through the hole in the housing then through the t-handle and tie a knot so it won't pull back through the handle. Put the housing on the motor, no screws yet, and pull the rope out to make sure nothing is binding and the rope retracts fully into the housing. If it's too tight use the slot in the pulley to take one winding out. If the t-handle dangles, add a turn to the pulley. Reassemble housing and boom and you're ready to go.
    Aug 23, 2010 | Homelite Mighty Lite Lawn Trimmer
    Want to remove the starter recoil from my powermate generator
    I got one of these pieces of junk, and had same problem you described.
    You will need to remove the end panel to get to the blower housing. You will have to thread the rope through the handle until you have enough slack to remove the rope from the handle. The end panel should now be free to remove entirely.
    Find the 3 bolts that hold the blower housing on, and remove them. Once you get it off, make sure that the rope has a knot in it so it won't get retracted into the pulley recoil assembly. Take a screwdriver and push the rope back down into the pulley (that was my problem). Assembly is opposite of taking apart.
    May 23, 2010 | Coleman Powermate Premium Plus 6250W...
    I have a white wire - approx. 5' with no home that I can see
    please connect it to earth(chassis) and look if it is stil sparking. i think it is the wire to stop the gen. it used to be fit behind the handle to start and stop please let me know, thanks.
    Feb 05, 2010 | Briggs & Stratton Power Products 5,550...
    Replace pull cord Big Wheeled weed EaterString
    First, remove the recoil assembly but dont disassemble!
    You'll need about 3 1/2 ft. of the same size rope. Tie a knot into one end of the rope. While holding the pulley in place observe the direction the pulley moves when rope is pulled. Release pulley and cut and remove old rope. Continue winding pulley in direction rope would pull it. Do no wind too tight. Line up holes in recoil housing and pulley then push rope through pulley and out housing. Tie on handle and install recall in reverse order.
    Jul 02, 2009 | Garden
    McCulloch 13HP 338 Cc Portable Generator # FG6000MK Logo
    231 people viewed this question
    Top McCulloch Electrical Supplies Experts
    John Trevino
    Craig Butler
    Craig Butler
    Are you a McCulloch Electrical Supply Expert? Answer questions, earn points and help others
