Question about Dell PowerEdge 2600 Server
I need to add more hard drives to my poweredge 2600
  • FLB09 May 11, 2010
    What type of drive do you want to add (SCSI? SATA? IDE?), also, how many drives are already in it?
    Novelist:
  • 159 Answers
The prices charged by Dell for spares (or 'upgrading') these ancient boxe's makes it cheaper to throw them away (and replace them with half a dozen NAS boxes ..)
However, after making the 'chuck it' decision (and taking it off Dell Support) I successfully replaced one set of ancient SCSI drives with a 2Tb SATA RAID set by removing the useless Take Drive and fitting 3 SATA's in the space thus vacated.
I used a 3 bay hot-swap enclosure SNT-2131 (I believe Icy dock MB453SPF is also possible). I took the power off theTape Drive 4pin supply cable.
There are any number of RAID cards that wil do the job (since I had zero budget, I used the Si3124)
The whole cost was LESS than what Dell wanted for ONE replacement SCSI drive (about £250).
Posted on Feb 09, 2009
    Teacher:
    An expert who has written 2 tips or uploaded 1 video tip.
  • 33 Answers
You'll probably need to get caddies for the drives. You can get them from Dell by plugging in your service tag at http://support.dell.com.
Posted on Feb 03, 2009
I'm trying to start Microsoft Windows Server2003 from USB Hard Drive on Dell PowerEdge 2600 Server.
Dell provides lifetime tech support for all PE servers. Call them at 800-945-3355 and give them the service tag or express service code from the server. If it can be done, they will tell you how.
Feb 29, 2012 | Dell PowerEdge 2600 Server
I want to install windos 2003 server on dell poweredge 2600 but the server is very slow i want help
I am not sure what you mean by "slow" so I will anwer in general terms. I would recommend 1st that you make sure the PowerEdge meets the recommended hardware specs for Windows Swerver 2003. (Memory, CPU speed, Hard drive capacity, etc.) 2nd- I would run two Xeon processors instead of one and add as much memory as you can put in your system.
I run MS Server 2003 on one of my servers and here is the configuration that I am using:
2 Xeon 2.8GHz processors
6GB ECC Memory
120GB hard drive for the server operating system (Nothing else is on this drive)
750GB hard drive for all other applications
External NAS storage for files, data, etc. (connected to my netword via Ethernet 5e)
With this setup, my server has been running very well for 6 years now. I do maintanance every week on it to keep it up to par. (Simple dusting, checking cables, etc.)
Good Luck.
C2Solutions
Sep 11, 2011 | Dell PowerEdge 2600 Server
Can I install Windows home sever 2003 on a dell poweredge 2600
I would say yes so long as your server meets theses requirements
Minimum system requirements The following minimum specs are needed:[24]
Additionally, the following are required for installation of the operating system only:
Apr 16, 2010 | Dell PowerEdge 2600 Server
Dell poweredge 2600 wont load anything from hard-drives what do i do?
Go into CTRL-M, go to Configure>View/Add, accept and save Disk View if prompted, and check the status of each drive. What is your RAID configuration (F3) and the drive statuses? If you are in the States, call Dell support 8008228965 - it is free whether in or out of warranty. It will be much easier to explain what you see.
Mar 14, 2010 | Dell PowerEdge 2600 Server
What type of nic to add
Cannot be PCIe, as they are not supported - PCI or PCI-X. Check the slots, you may only be able to use 3.3/5V cards.
And as a sidenote ... the PowerEdge 2600 does not support x64 Operating Systems and does not support hardware-assisted virtualization (VT on Intel processors), so you will be limited on which VM solutions you can use.
Mar 06, 2010 | Dell PowerEdge 2600 Server
I'm trying to install Microsoft Server2003 on a Dell PowerEdge 2600 Server. I belive that the CD ROM is faulty since it doesn't boot off it even though I have the right settings in BIOS. I try to connect a...
Another common way around installation is to copy the whole contents of the CD / DVD to a hard drive.
There are a few methods.
My proffered is to make a bootable flash drive on another machine with known working capabilities that will bot into either an XP-pre installation scenario or a Dos based one.
From there it is often possible to start the installation or even copy the required files to a drive on a machine.
Advantage of copying the files is that the CD / DVD would never be needed to add additional component as they are stored on the machine itself.
That also speeds up installation dramatically.
Bios consideration mus be taken into account when booting from flash drives.
Proper external Hard drives are another viable option
Sep 08, 2009 | Dell PowerEdge 2600 Server
CAN YOU TELL ME HOW TO GET WINDOWS XP TO LOAD ON THE DELL 2600 POWEREDGE SERVER IT ONLY OFFERS SERVER 2000 AND SERVER 2003 AND I CANT USE EITHER OF THEM THANKS MIKE
Hi tham01,
First off, if the server has raid already setup, you will need to go into lsi logic to format the drives so you can install XP. Once the drives have been initiated from the server bios, just place XP in the CDROM, and shouldn't have a problem loading on the 2600 POWEREDGE SERVER. If your trying to install it with the Dell quick install disk, you can't!!! Install it on it's own without the Dell Disk.
Good Luck!
Mark
Jan 13, 2009 | Computers & Internet
Adding DVD to Poweredge 2600
PE2600 has lots of spare power (unless you are already using all 6 SCSI drive bays) ..
You can fit 3 x SATA drives in the space where the (useless) tape backup unit is sitting [you can even buy a 'proper' enclosure = Icy Dock MB453SPF or I think the SNT-2131 will fit ] .. and you can split the power off the Tape drive (4pin) power socket ..
I've not found a DVD burner (only a combined DVD reader / CD burner = TS-L462C) .. however if you have a spare IDE port you should be able to use an external unit [you will need an e-ide cable & enclosure for the drive]
Dec 11, 2008 | Dell PowerEdge 2600 Server
Can i add 142GB of hard disk on Dell PE 2600 motherboard
You can always add more storage to a server, as long as you have enough internal connectors in the server. You can also purchase another scsi or sata backplane to add more ports if you're out of internal connectors.
You may also want to look into a SAN or NAS device to offload some of your not too frequently used data. Many SAN devices give incredible performance with pretty good scalability.
Steven
Sep 16, 2008 | Dell PowerEdge 2600 Server
New HD in PowerEdge 2600
Put the hard disk in, allow the OS to identify it, format the drive and you'll be all set.
Jul 19, 2008 | Dell PowerEdge 2600 Server
Dell PowerEdge 2600 Server Logo
291 people viewed this question
Alun Cox
