Question about Canon Cameras
Cleaning dust out of SX230 lens
There is dust inside the lens. Can I clean it? Camera out of warranty.
SOURCE: How To Remove The Fixed Lens From The Olympus E-10 For Cleaning
The easy fix is to buy a new camera. Or trade up to Canon equipment that is easier to clean.
-BLL63
Posted on Sep 16, 2008
chironjilal
  • 40 Answers
SOURCE: How can I clean the INSIDE of a Panasonic Lumix DMC-LZ7 lens?
you can clean that with paint brush..
Posted on Feb 22, 2010
  • 11967 Answers
SOURCE: dust inside the lens - how to disassemble and
You can't take the lens apart. Even if you could, you don't have the tools or expertise to get it back together and properly align the lens elements.
Posted on Jun 04, 2010
Obertelli
  • 3006 Answers
SOURCE: How can I take apart and clean inside lens? There
Sensor cleaning on your model is a job for professional technicians only and therefore not cheap. Dismantling your camera to get at the sensor requires specialist skills and knowledge and due to the small sensor size it must ideally be done in a sealed room with high levels of dust extraction if you want to avoid making the problem worse.
Any attempt at unauthorised disassembly will also invalidate any warranty you may still enjoy; even if the original warranty has expired there are sometimes camera faults which later arise that manufacturers have been known to retrospectively extend the warranty for so you potentially lose those rights as well.
A safer alternative is to use a supersonic vibration cleaner on the camera. These are sold to the public and to jewellers/opticians as a means of cleaning without chemicals and are usually filled with water, but you can find one with a large enough bed to sit your camera in and then it can be used dry. Your camera must be switched off when you try this, and must sit on it's base. The latter allows the dust to fall downwards and get trapped on the internal sticky dust trap built into your camera. If the camera is oriented any other way then you may dislodge trapped dust which may then fall onto the sensor. If you cannot find a suitable supersonic cleaning bath then you may even find that a ******** (yes, I DO mean the adult toy) set on it's fastest setting will achieve the same result. You need one that vibrates, not one that resembles an industrial jack-hammer...
Failing all that your only remaining option is to just accept that you're going to have to process out the artefact on every shot until it eventually falls off the sensor of it's own accord (no guarantee that it will though).
Good luck, and please take a moment to rate my reply.
Posted on Sep 14, 2010
SOURCE: Lumix DMC TZ10 Dust in lens.
It is so discouraging to hear NO! Panasonic's core design may be similar to all in its family. TRY..
http://www.youtube.com/watch?v=1B_tHmkRfJk
Posted on Jul 26, 2012
How do I clean inside a Ricoh rikenon 70mm to 200mm zoom lens.
Unless you have a lens collimator and other equipment to ensure proper alignment when you reassemble the lens, don't even think about taking the lens apart. Take the lens to a reputable camera shop and let a qualified and properly equipped tech handle the cleaning.
Aug 30, 2016 | Ricoh Cameras
How can I clean the inside lens of my Ricoh cx5 camera?
Once you start blowing air from aircan (duster) it will move the dust sitting on the barrels' surfaces of the lens. The dust specs will end up on the interior of the lens glass even in larger quantities. The only way to clean it correctly is to take apart the lens and blow the dust out and assemble it back. If the same camera is listed on ebay under $50 buy another one with a clean lens. Sell yours on ebay for parts the difference will be around 15-20 dollars. Not a bad price for getting a cleaner version of your camera. You may even make money by buying a better camera cheaper than you can sell yours. If you camera is still valued at 100-200 range find a cleaning service on ebay for $30.
Jul 15, 2014 | Ricoh CX5 Digital Camera
Tamron AF 18-200MM XR Di II LD dust inside; how do I clean?
Dust and other small debris is drawn into the lens due to the vacuum created when zooming in. You can reduce the chances of drawing in dust and debris by slowly zooming in as opposed to rapidly zooming in.
Now that you how it gets in and how to help prevent it from getting in again, comes the bad news. There's really no way to disassemble the lens to clean it up at home. These are precision optics with many small moving parts that really need to be serviced in a dust free environment. You best bet it to contact Tamron (or authorized servicer) to learn how much it will cost to be cleaned by them. This will keep the warranty (if any) intact, too.
Feb 14, 2012 | Tamron Cameras
Cleaning the lens from the inside
Cleaning the lens from the inside is not possible from a practical point of view. However, if you don't care that your camera won't work after you've taken it apart but you just want to see what's inside, then go ahead. If you see dust inside the lens and this is what is concerning you, please know that all lenses have dust inside...it can't be totally eliminated. In 99.999% of cases, the dust doesn't show up on the actual pictures.
Oct 17, 2011 | Casio EXILIM Card EX-S770 Digital Camera
Error 99 on canon 300d
Canon's error 99 is a catch all for several things the short answer is an electronic connection. Something isn't making contact and the first place to go is to the "gold" contacts between the lens and the camera body. Make sure the camera is off and remove the lens, place the camera lens side down on a clean dust/lint free surface or put a body cap on. Take the lens and holding as vertical as possible with the gold contact points down use a soft rubber red pencil eraser to lightly clean the contacts. You can remove any rubber dust and partials with a lens cleaning cloth NOT TISSUE. Make sure the area is clean of lint and dust, place the rear lens cap on or stand the lens up on a clean dust and lint free surface. the camera is a bit more tricky as you need to clean the contacts inside the mirror box. Hold the camera as best you can face down and again use the pencil eraser to lightly clean the contacts. Holding the camera as mus as possible lens side down. This will minimize any dust, dirt or lint getting into the camera body and eventually ending up on the sensor. Remove any rubber dust with a lens cloth not tissue and don't use any liquid, don't use a puffer either all that will do is drive dust partials into the camera. Once that's done install the lens, next remove the battery and do the same cleaning trick with the battery contacts, if you have a battery grip do the same thing. Okay now check out the camera if everything is go and works then you are good to go. If not then I would suggest doing a camera firmware update, all updates can be found on the Canon web site they are free and will correct any issues your camera has with the internal programming which may also be the cause of your error 99.
Jan 11, 2011 | Canon Digital Rebel / EOS-300D Digital...
How to dismantle the lens front element. My reason is to clean the dust inside. Thanks.
I strongly recommend you do not try this unless you are trained in camera/lens repairs and have the correct tools and solutions. Too many things that can go wrong, not the least of which is introducing more dust into the lens than you manage to clean off. Also, most lenses have a lesser or greater amount of sealant which may potentially be ruined. Lens elements are carefully aligned, and any misalignment on re-assembly will negatively affect focus in any lens, more so in a zoom. If the dust is affecting your photos, I suggest you have a local Sigma authorized camera repair shop clean it. And, most will have a limited warranty of 30 or 90 days. I speak from experience ... ::--))
Oct 07, 2010 | Sigma 18200mm f3563 DC OS for Canon
How do I clean dust inside the camera? I noticed some splotches on my photos, then looked closely at the lens and it appears there is dust on the inside of the lens.
You can't clean inside the camera. Dust inside the lens would be so out of focus, it wouldn't register on your pics unless the particle was huge. Do these splotches only happen in your flash pictures?
May 30, 2010 | Olympus Stylus 710 Digital Camera
Unscrew the entire lens assembly from the body. The inner lens cannot get debris inside it but the outside of it and the inside of the protector lens can. It's a good idea to do this cleaning in your bathroom with the shower on hot but not visibly steamy as this will cut the airborne dust by 90%.
Feb 22, 2010 | Panasonic Lumix DMC-LZ7 Digital Camera
See dust or drop of water on my pic canon sx10 is
You have to disassembly your camera for it, including the lens assembly.
Even if you have experience and skills in fixing electronic devices, I don't recommend it, since any particle of dust will get inside the lens and your camera, and will affect it.
The recommended place to perfom such cleaning activity is a Clean room (class 3 or higher), and have handy the proper cleaning tools.
Disassembling the lens is tricky and also needs a lot of patience and technique skills to do it properly.
Imagine that by accident a spring pops up a tiny metal ball (1.5 mm diameter) and you lose it in your home, then because of it, your lens will not work properly.
If it has warranty, I do recommend you to send it to cleainig to a professional repair and cleaning service.
If still you have questions or doubts, or need a cheaper quote for it (after get some quotes from local repair centers for comparison), you can contact the ebay seller Great_items_2004
Best regards,
May 28, 2009 | Canon PowerShot SX10 IS Digital Camera
-BLL63
Mar 08, 2008 | Olympus Camedia E-10 Digital Camera
Cameras Logo
200 people viewed this question
Top Canon Cameras Experts
TC CAMERA REPAIR.Com...
old marine
old marine
Are you a Canon Camera Expert? Answer questions, earn points and help others
