Question about Refrigerators
Problem with my 2 brushless fans of my wine cooler, lot of noise and over heating, can i replace it, thank you for your help
The fans model are - dc brushless fan - model: TD9025LS - dc12v - 0.16a
3 Suggested Answers
SOURCE: Cuisinart wine cellar CWC-900 "Both fans are dead"
CONTACT COMPANY : DENVER BETA 303-431-7161 MODEL # YW06010012SL ONE MONTH LEAD TIME... THIS IS A SLEEVE BEARING MODEL THEY HAVE A BALL BEARING MODEL THAT SHOULD WORK ITS GIVEN MODEL IS YW06010012BL REPLACES DFC601012L
Posted on Nov 03, 2009
  • 55 Answers
SOURCE: Noise coming from upper back fan of my danby wine cooler
You'll need to take the defective fan out and take it to some type of hvac distributor in your area. Fan blades generally come off of the shaft of the motor by one or two allen screws.
What type of noise is it making?
You may also consider the motor. If the noise isn't caused by the fan blade hitting something when it spins the noise could be coming from the motor. For that type of unit, the motors are very small and only have two wires to connect them and usually a very small plug. If not you'd only need two wirenuts and some electrical tape. It's just very important when you replace the fan that you match the voltz, hertz, rotation, and hp.
Posted on Mar 18, 2013
Hi, I have a WCR524SDZD wine chiller and the fan has started to make noises, and also the temperatures seem to not drop to the temperatures we expect. Where can I get a new fan? or parts for this...
your unit uses a generic fan motor that a lot of refrigerators ect.. use. If you take the fan to a local shop that sells refigerators they will match up one for you. Avanti's phone number is 1 800 220 5570. good luck
Aug 11, 2010 | Avanti WCR524SDZD Wine Cooler
Our wine cooler is making a loud noise. We
i got the same model,the noise from the lower back,u can remove the fan out & determine the noise from easy,the bottom have two bolts,easy to remove it.gd luck for u
Jul 02, 2010 | Danby Silhouette DWC512BL Wine Cooler
Haier wine cellar HVTS18DABB top zone won't cool.
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be effective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
http://www.sidewindercomputers.com
Specific fan for my application was the model SY1225SL12SH. Although I did order a second fan that is similar in case the .5amps was too high and I popped a fuse. These fans are inexpensive folks, as long as you aren't afraid to get your hands dirty. Good luck.
http://www.sidewindercomputers.com/sc12slsy110c.html
Here are the details on my order:
Name Code Qty Each Options
Yate Loon 120x25mm D12SH-12 1 5.99
D12SH-12 High Speed -
Black (88 CFM, 40 dBA)
Scythe 120x25mm SY1225SL12SH 1 7.95 Add Black Sleeving = No
SlipStream SY1225SL12SH -
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
May 04, 2010 | Haier BC112G Wine Cooler
Wine cooler not cooling below 65 lights works but not fan any ideas
Brand and model number will help someone answer your question easier. But to guess the problem I would think the fan is the answer. Both interior and exterior fans must run while any cooler or refrigerator or it will cause the compressor to over heat and stop cooling. Running with a bad fan can also damage the compressor internal overload. f you unplug the fan wires and test for voltage you should get your local voltage unless the fans are DC. Thanks, Lit me know the model and make and I will help you further, Sea Breeze
Feb 11, 2010 | Refrigerators
Sep 04, 2009 | Cuisinart Private Reserve CWC-900 Wine...
NEED FAN FOR MODEL HVTS18DABB
Maybe not the answer for everyone, but I proved it was the fan by removing the back panel, removing the fan and finger guard, then placing a small desktop fan that was the same size as the top-rear fan on the wine fridge. Pumping air directly over the heat sink allowed the unit to attain the temperature set on the front panel. The old fan would either not turn at all, or too slowly to be affective. These fans are junk. Especially after finding articles such as this out in different forums for the same issue. I have the HVTS18DABB model unit and the replacement fan is a simple 120mm square, 25mm deep 12V DC fan. Similar or the same as you see in computer chassis. Found some inexpensive, high CFM, low noise fans from the following site:
110 CFM
Subtotal 13.94
Shipping 7.02
Tax 0.00
Jul 18, 2009 | Haier BC112G Wine Cooler
WINE COOLER NOISE
when the fan comes on so does the compressor,hold the fan with a rag and see which one is making the noise-mike
Nov 11, 2008 | Danby Silhouette DWC512BL Wine Cooler
Wine cooler noise
Had same problem. cooling fan was going out.Replaced fan about a year ago and now it is going out again. Am ordering another fan now
Mar 25, 2008 | Danby DWC513BLS Wine Cooler
Refrigerators Logo
57 people viewed this question
Top Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
