On norton pc check up when i try to run it it stops at 72 % and says a serious exception has occured pc checkup will exit try restarting program what do i do
  • Computers & ... Master
  • 27,725 Answers
If you want to know what this is the error code is related to
Click start control panel administrative tools computer management then select event viewer this may vary depending on what operating system you have extend the events there you will see errors in red you will no what exactly what the error was and at what time it occured or click start type in event viewer press ENTER you might be able work your way through the problem
Posted on Dec 13, 2012
2 Suggested Answers
fwadley
  • 482 Answers
SOURCE: Programs & applications are not opening.
http://free.avg.com/download-avg-anti-virus-free-edition
Uninstall norton
Posted on Apr 17, 2009
MY AUTOCAD PROGRAM OFTEN STOPS RESPONDING
Just do the following steps and your issue will be resolved.
1) Delete all unwanted data from Drive C.
2) Delete all data that you have copied from Drive C to External HDD
3) Open My computer and go to Tools---> Folder Options---->Click on View Tab----> Check 'Show hidden files and folders' and select OK.
4) Go to C:\Documents and Settings\Administrator\Local Settings\Temp and Delete everything that you see inside Temp Folder
5) Go to C:\WINDOWS\ here you will find folders like $hf_mig$, here you will have to Delete all the folders starting and ending with $ sign.
6) Empty Recycle bin and restart the PC and Login
Now, Go to 'Start' and then Run
write "msconfig" inside Run tab and press 'enter'
inside the 'System configuration utility' window click on 'startup' tab then uncheck all the applications except your current antivirus and press apply then 'ok' and then 'exit without restart' option.
Now right click My Computer and go to properties tab.
click 'Advanced' tab then under performance menu click on 'settings'
go to 'Advanced' click on 'change' and increase your virtual memory to 2048 in both spaces.
Now restart windows.
May 26, 2011 | Computers & Internet
Serial Number 129663400306 When Impurchased this model in April 2007 from Currys the package contained Norton Anti-virus software and I never subscribed to the service. I now run iolo professional...
Glad to help YOU!
I'd suggest you to download and to install REVO UNINSTALLER (it can be found HERE, scroll down and choose the FREE VERSION; or - if you want to buy it - you can choose REVO UNINSTALLER PRO...). It's a FREE software that does a great job!
After you will install it you double-click on the icon and on the main window you will see the applications currently installed on your machine; select Norton application and click on UNINSTALL (upper side of the window) and then select ADVANCED (the last option in the bottom). Let the REVO do its uninstall and click NEXT and SELECT ALL and when it's done select FINISH. That's it!
This software not that will uninstall the application(s) but will also clean the REGISTRY of the leftovers.
My best wishes!
Mar 16, 2011 | Computers & Internet
My computer was virus
1. Go to Start --> Control Panel --> Add/Remove Programs.
2. Scroll down to your Norton program
3. Click Change --> Remove All.
You will be asked to restart your PC. Do so.
4. Now go to Start --> My Computer --> Program Files. Right click on each Symantec folder and select Delete.
5. While you are in Program Files go to the Common Files folder at or near the top of the Program Files window. Delete every Symantec folder there. And, again, restart your PC.
6. Go to Start --> Search --> All Files and Folders --> More Advanced Options. Check each option except for "Case sensitive"
Now type in Norton and delete each Norton folder from the search results (Again, right click, choose "Delete"). One more time, restart your PC.
7. Repeat step 5 except type Symantec in the "Search" box.
Nov 16, 2010 | Symantec Norton AntiVirus 2008: Windows
I cannot uninstall antivir on my computer how do i do it!
Hi, you can remove Norton by following ways:
First: you can try to use the Norton Removal Tool provided by Symentec: http://service1.symantec.com/SUPPORT/tsgeninfo.nsf/docid/2007080716270339?Open&docid=2005033108162039&nsf=tsgeninfo.nsf&view=docid
Second: If you want to remove it manually try the below steps:
go to Start --> Control Panel --> Add/Remove Programs.
You will be asked to restart your PC. Please restart the computer.
After restart go to Start --> My Computer --> Program Files. Right click on each Symantec folder and select Delete.
Now type in Symantec and delete each Symantec folder from the search results (Again, right click, choose "Delete"). One more time, restart your PC.
Feb 25, 2010 | Norton AntiVirus 2004 (0003764823191)
My computer say that symantec framework has stopped working and the disk drawer keeps opening and closing. help please
Need to reinstall Norton program manually
1. remove the Norton program with Norton removal tool (www.norotn.com/nrt)
2. clear temp and prefetch ( to clear temp type %temp% in run and to clear prefetch type prefetch in run and delete all files)
3. restart the system
4. clear all the Norton files from registry
5. clear Norton or symantec folder from application data
6. install Norton program
If you get the same issue after we reinstall manually you need to create one administrator account and install Norton program
Feb 07, 2010 | Symantec Norton AntiVirus 2004 - (Open...
Unauthorized access blocked open process token
If you use another anti virus/spy program like Norton Antivirus which i suspect you are as you are using Norton Internet Security then you may not need Windows Defender running at all. If you think that Windows Defender is the culprit stopping your Canon application from running then why don't you stop Defender from running.
Open the Windows Defender program, click on Tools->Options, select Administrator Options, and uncheck the "Use Windows Defender box". Confirm that you do indeed want to do this, click Close.
Restart your computer and try running the Canon application to see if it has helped.
If it has then all's well, if you want to run Windows Defender again just follow the above steps and re-check the "Use Windows Defender" box again.
If this does not work please post back.
Good luck.
Sep 15, 2009 | Symantec Norton Internet Security 2009...
Symantec system framework stops working
Sir,
Try to reinstall them. If error occurs go to control panel. click firewal and go to exception tab add the program symantec antivirus. i think it may be solved, if not let me know
Thanks Good Luck
Appreciate to rate as "Fixya"
Mar 16, 2009 | Symantec Norton 360 Version 2.0 for PC
I have difficulty in uninstalling my nortan antivirus software
Here are the steps to Remove it Fully :
The next step is trickier: go into the Registry.
  1. First thing to do is Back up the Registry. I'll be saying more about the Registry later. But suffice it to say that the presence of uninstalled security software in the Registry can conflict with newly installed security software and cause system freezes. So can folders of "uninstalled" programs for that matter.
  2. Once again, go to Start, then click on "Run". Type in "regedit"
  3. Go to the top of the Regedit window. Click (+) next to HKEY_CURRENT_USER. Go down the thread until you see Software. Click on Software and scroll down the thread until you see Symantec. Right click on Symantec and choose "Delete".
  4. From there go down to HKEY_LOCAL_MACHINE and repeat step 3. Restart your PC.
  5. Click (+) next to HKEY_LOCAL_MACHINE, now: Click (+) next to Software, Click (+) next to Microsoft, Click (+) next to Windows and Click (+) next to CurrentVersion.
  6. Select the Run folder. Right-click and delete each Symantec entry you see (if present). Restart your PC.
That should completely eradicate Norton Antivirus from your system!
Dec 09, 2008 | Computers & Internet
WINDOWS- NO DISK
I'm not sure if this is the problem, there seems to be many different causes. Click on Start, Run, type msconfig, then click ok. select the startup tab, then scroll through the list to see if there is an entry for dit.exe. If you find it, uncheck the checkbox, click apply, then exit from the dialog box. Restart windows and see if the problem is resolved.
If this item is not in the list, then there may have been a problem with the uninstallation of norton antivirus software. For some reason, in the computers that the problem occurs, Norton was not able to uninstall fully. The problem also seems to occur after updates are installed from windows update.
May 25, 2008 | Computers & Internet
Computers & Internet Logo
1,146 people viewed this question
David Payne
David Payne
