Question about Miele Washing Machines
Miele 1926 rinse 1-2 flashing
Rinse 1-2 light flashing
  • 13 Answers
SOURCE: Miele W864 Fault
I have a W844 and the exact same fault occured. I traced it to badly worn brushes on the motor.
Posted on Sep 21, 2008
SOURCE: rinse light flashing on miele
Check the motor for worn brushes and or noisy bearings while it is removed for service. Any auto mechanic should have experience replacing brushes and bearings. Much cheaper than ordering a new motor. New brushes and bearings should cost around $30. The shop time should not exceed one hour. Miele charges about $50 for brushes if you can not find a local supplier. The W1930 motor that I rebuilt used a 6202Z and a 6201Z bearing set.
Posted on Mar 14, 2009
SOURCE: Miele w828
Hey you! I want to Miele w828 Final Spin Cycle 1100rpm Part 1/3 of 3/3 Part 1of3/3 of 3. Do you understand? Great Now let get to work.
Posted on Apr 25, 2009
  • 14 Answers
SOURCE: rinses light flashes miele w864
this usualy indicates a problem with the motor not turning, it can have many causes
Posted on Aug 26, 2009
Gallois
SOURCE: Hi, i have a miele novotronic w 916 and it's not spinning
I mean this is not a filter error and i think the power main board inside on front bottom EL110 has an defekt and must change.
Or you can post the problem on my board www.avpc.de with photos for solving together and find another cheap used power board for it ...
Posted on Sep 09, 2009
Miele w1918
Link to user manual. Code listed on page 32 indicates internal error Call service department.
Miele 1918 Operating Instructions Manual Page 32
Aug 03, 2014 | Miele Novotronic W1918A Front Load Washer
Flashing rinse light miele novotronic w828
Broken electronic as a result of worn shock absorbers. See www.youfixit.eu
Aug 27, 2012 | Miele Novotronic Premier 500 Front Load...
Rinse light flashes on miele w828
1) the water must be preheated, test the heating element if is defective
2)drain line is clogged proceed to fix it see the diagram
3)some sock must be removed, use plier
4)pump defective, inside with the propeler, replace
5)frozen pulley pump, replace
6)improve the drain, if about 4 inches cut of the diference.
b) if lower , install air/gap siphon break assembly.
God bless you
Jun 25, 2012 | Miele Novotronic Premier 500 Front Load...
Premier w500 the rinse light flashes rapidly and the cycle stops. Any thoughts?
Hi just wondering if you got your problem with your miele sorted out yet as mine has done the exact same thing. Rinse light flashing rapidly and cycle stoped. Have cleaned the filter and re started but no joy.Any luck?
Jan 09, 2011 | Miele Novotronic Premier 500 Front Load...
Miele W1926 check inlet light flashes at he end of rinse fill
Hi Yugin.That indicates your machines water inlet valve is faulty.(Means it's taking less water then normal)Please check this steps & do it fast before water inlet is finishes:1-Turn your machine on & run empty with pre-wash cycle first.2-Please ajar the detergent drawer & check runing water on compartment one 3-Please press pre-wash button & compare the running water volume on compartment two.If the running water volume 1 is less then 2 or vs.water valve needs to be replace.That's causing problem.I hope that helps.Thanks.
Jul 26, 2010 | Miele W1926A Front Load Washer
Intake/drain light is flashing
When this happens with my dishwasher it usually means that the drain is clogged with food/debris.  To fix 1) remove bottom dish rack from machine 2) using a small cup, scoop out as much water as possible 3) remove inlet drain cover and unsnap the plastic insert and remove 4) rinse the plastic part and reinstall 5) start machine 6) if light still flashes, repeat steps 3 4 and 5 and restart
Jul 18, 2009 | Miele G892SC SS Dishwasher
Miele w828
May 24, 2008 | Washing Machines
Miele Premier novo washing machine
Flashing rinse light is a drive fault. No motor action. If it's an earlier model it would be the motor brushes. Later model will be the electronic which controls the motor.
Aug 10, 2007 | Miele Novotronic Premier 500 Front Load...
Washing Machines Logo
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
