Question about Troy Bilt 5.5hp Self Propelled Mower
Troy bilt tuff cut 210 low idle - Troy Bilt 5.5hp Self Propelled Mower
  • 68 Answers
SOURCE: lawn mower
It's possible the rope came out of it's pulley groove and is jammed inside the engine housing.
Posted on Apr 26, 2009
#1 Taper
  • 1041 Answers
SOURCE: troy bilt mower won't stay running to cut lawn
You may want to check the gas cap to see if it clogged with dirt. If the gas cap is clear, you more than likely have a carburetor problem. If you need tips on carb. cleaning, feel free to ask.
Jim
Posted on May 30, 2009
  • 59 Answers
SOURCE: idles low, power loss, not enough power to cut grass.
check the spring on the carb
Posted on Jun 23, 2009
freetek
  • 5568 Answers
SOURCE: Our Troy bilt lawn tractor wont start. It seems like a short
Unless something catastrophic has happen internally, fuel and spark are about all you need. If you are sure of the fuel supply, pull the spark plug lead and let it arc to ground so you can check ignition health. You should have a bright blue spark visible. If you do, then pull the plug and replace it; the insulator may be cracked and robbing some of the high voltage. If it still doesn't start, you may have flooded it and when this happens to me, I make sure no spilled gasoline is present but I then pull the plug and use a charcoal or fireplace lighter and place it in front of the sparkplug hole. It should pop and help exhaust the excess fuel.
Posted on Aug 14, 2009
  • 18 Answers
SOURCE: troy built riding mower runs at low speed and
Probably an engine problem.
Does it run at max rpm with mower deck disengaged?
Posted on Apr 18, 2010
How to replace fuel line on troy bilt tuff cut 230 lawn mower with B&S intek engine
The easiest why is to remove the carb, usually the gas inlet on the carb is between it and the engine, the other end is beneath the gas tank, once again it is easier if you take the tank off the mower.
Aug 01, 2014 | Briggs & Stratton Garden
Replace starter handle for troy bilt tuff cut 210
most homedepot and lowers stores stock them or order threw sears parts online
Apr 23, 2012 | Garden
Have a troy bilt 200 tuff cut mower. roughly a 2004. It wont start. worked fine the other day. pulled cord and nothing. tried starter spray etc. no luck. Also where can i download a manual for this
#1 CHECK THE OIL ! .#2 check for spark you may have flooded the motor. THESE WILL NOT RUN WITH LOW OIL .. or with water in the gas
Jun 06, 2011 | Garden
Need a fuel tank for a Troy Bilt mower
You won't find the fuel tank on MTD's site because it is part of the engine. MTD makes the mower, Briggs and Stratton makes the engine. Get the model and type number off the engine and search Briggs and Stratton's site or post it here and I will tell you the part #. Dwain
May 21, 2009 | Troy Garden
Lawn mower cable won't pull to start engine. troy bilt 210 self propelled mower.
Apr 25, 2009 | Troy Bilt 5.5hp Self Propelled Mower
Troy Bilt 5.5hp Self Propelled Mower Logo
Top Troy Garden Experts
Jim Parker
Jim Parker
Matt Olenzek
Matt Olenzek
DROPNDEAL
DROPNDEAL
Are you a Troy Garden Expert? Answer questions, earn points and help others
