Question about Samsung DLP HL-P5663W 56" TV
Samsung HLP4663W color wheel replacement
I just replaced the color wheel in my Samsung HLP4663W DLp tv. Now the color is off and the picture in not clear like HD should be. What should I do to fix this problem? I have read that removing the "jumper" near the color wheel could solve this problem, is that true and how do I remove it?? I have shaded lines on my screen. it is directly related to the dmd panel and the heat sink. what is the thermal medium (with fiber in it) between the heat sink and the DMD
  • mattk1 Jan 27, 2009
    I fixed my problem. If you have dark shaded lines on the left or right of your screen, it is most likely the light tunnel assembly. Apparently the factory did not properly affix the four small mirrors in the tunnel assembly. It started with the vibration of the bad color wheel. It would move the mirrors slightly, causing the shaded area. Every time I took the light engine out, it moved the mirrors so when I put it back in it seemed like I was changing something. Today I got the new light tunnel($50+ship). One hour later, perfect picture.
  • Anonymous Jan 29, 2009
    I have a DLP HL-P5663W 56" TV that I just changed the color wheel on and the color and picture quality is all wrong. I read the post about pulling the black jumper, but can not see anything that looks like a hardruve as it was described. Where exactly should i be looking. More info would be a great help.
    Champion:
  • 240 Answers
Yes its true grt your self a pair of needel nose pliers and pull that jumper.
I had a tv set in my shop for weeks till i lerend that one
wat it was is that the new color weel motors are air cor and spin faster that the originals, so pull the black jumper it looks like a small hard drive just remove it
your set will auto ajust.
ther are sum small settings to add in the service menue to fine tune it.
but first pull that jumper..
seting can be found on google... i think i found it on tech assist.
and enterd model number.
Posted on Jan 12, 2009
No picture strange sound
Hi , I try to share my experience about no picture strange sound in DLP models,
If that sound from behind TV like friction sound it mostly from the color wheel.
Open rear cover, switch on your TV and listen , it it from angine not from speaker, that the color wheel problem. replace it.
Mar 05, 2011 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HLP-4663WX/XAA. Colors green after wheel replacement.
I have Samsung DLP HLP-5063WX/XAA. I have the same problem. I did change another color wheel, but not any help. Please help! I appreciate
Sep 10, 2009 | Samsung HLP4663W 46" Rear Projection HDTV
Color Wheel problem
Replacing the color wheel can sometimes switch Red With Blue. If you remove the jumper it could fix the problem.
Here's an article on it's replacement.
http://www.jangro.com/a/2006/07/24/samsung-dlp-replace-color-wheel/
Aug 27, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Color wheel or fan?
Sounds like the color wheel has shatterd, thats a fairly common problem with that model.
Jul 14, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
TV will not turn on, Have three blinking lights, lamp won't turn on, color wheel isnt spinning.
the color wheel wil need to be replaced soon if it is doing that. it could be then DMD board as will.
Jun 20, 2008 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung HLP4663W Color Wheel
 The color wheel that goes in an HLP4663WX/XAA is:
  BP96-00674A
 This is the correct color wheel.
Oct 20, 2007 | Samsung HLP4663W 46" Rear Projection HDTV
Samsung DLP HL-P5663W 56" TV Logo
383 people viewed this question
Henry  Thomas
Henry Thomas
