Reinsalled xp and i have no internet
I reinstalled xp and now i have no internet and i tryed to reinstall the driver but nothing happend
  • 13 more comments
  • micloscrib Jan 12, 2009
    alright all of thats fine but when i go to device management i dont see any network adapters
    alright i have no light
    i really hope this help and i appreciate it even if it doesnt but i hope so
  • micloscrib Jan 13, 2009
    i dont know how to take it out
    i have a emachine t6520 theres no screws
    opening is not the problem i know where it is but its little like a box
    i cant pop it off
    ok thanks
    alright i did that but when i did the realtek one it says it cannot start
    but if i do the microsoft one already on there it says little or no activity
    no its not wireless
    but now i dont see any it use to say local area connection
    i did that and it still said that its unable to start code 10
    i did that and it says the page cannot be displayed
    the eithernet port on the tower still dont blink
    im using a dell inspiron 530 desktop that i like much better
    do you have im cuz it would go by way faster
    alright it still dont work i tryed to uninstall the microsoft drive and it said cant uninstall may be required for bootup
    and the realtek driver is not a self installation driver
    its weird man
    it dont install itself you have to install it and i did that but it said the wizard could not find a much better hardware than wat it already is
    its not compatible with my dell
    but i did it on the other pc nothing
    i only have a yahoo
    alright my email is micloscrib@yahoo.com
    but could we solve this tommorow i got to get up early
    wat tme would u be available
    its 10:00 over here
    ight cool man thanks
    i love cool people like u
    im here now
    did u find anything out
    Genius:
  • 1,102 Answers
Make sure your internet cord is plugged in
go into control panel see if your network shows if it shows but has a ? or ! mark then update the driver.if it shows with no marks then
right down what type of driver uninstall and restart should automatically pick up driver if not then in control panel add new hardware follow instructions.Let me know if this helped if not I have another solution to try
Posted on Jan 12, 2009
  • 14 more comments
  • DEKR
    DEKR Jan 12, 2009
    If the light is on- -on the back of your tower where you plug your ethernet in then go into control panel add new hardware
    click to add your network or scroll to the bottom and add new hardware
    If there is no light or adding new hardware does'nt work
    then I have another solution.
  • DEKR
    DEKR Jan 13, 2009
    Okay first make sure your cord is securely plugged in and all your modem plugs are securely plugged in and modem light is on.
    If the light comes on just a matter of a lose plugin
    OTHERWISE right these steps down and follow them carefully
    Sounds like a lot of steps but i've had to do this many times
    If all this is intact then what you need to do is shut down.
    Remove the tower casing and then find your lan card
    Unscrew the screw if any they carefully but securely hang on to it with both hands remove it carefully.
    Set the case on for a minute restart pc.Let it load then shut down again remove case and with both hands replace lan card in slot make sure it is in securely and tight.Then set case over it and restart.This should pick up the lan card sometimes after reinstalling windows you lose your lan card settings.PLEASE DO THIS STEP BY STEP IMPORTANT TO MAKE SURE ALL IS SECURE
  • DEKR
    DEKR Jan 13, 2009
    As far as I know you should be able to open your case
    I am sure you just need to replug your lan in it does happen after installing windows.
    I have never opened an emachine so I can't really explain how to do it without seeing it
    Some mdgs are made like that and the casing has to be popped off.
    Some small pc repair stores will open your case for you for nothing or under 5
  • DEKR
    DEKR Jan 13, 2009
    I'm gonna see if I can go see a emachine case so I can tell you how to open it
    Cause I am sure we can solve your problem
  • DEKR
    DEKR Jan 13, 2009
    kkk
    I'll go look at one my friend owns a pc repair store
    I'm sure he'll explain too me what to do
  • DEKR
    DEKR Jan 13, 2009
    I am going to get you the proper driver and setup then we will manually install it
    May take about 20 minutes then I'll get back to you
  • DEKR
    DEKR Jan 13, 2009
    Okay since you can't get on the internet we need to manually install this driver
    your driver is Realtek RTL8139/810xFAMILY FAST ETHERNET NIC NETWORK DRIVER
    you should write this down
    Okay now your going to open control panel
    add new hardware click next
    check hardware connected
    then next scroll down and if you see the network click on and proceed
    IF YOU DO NOT SEE IT SCROLL TO THE BOTTOM CLICK ON ADD NEW HARDWARE DEVICE
    CLICK THEN NEXT CHECK CHOOSE FROM A LIST SCROLL TO NETWORK ADAPTERS CLICK IT
    THEN NEXT AND YOU WILL FIND YOUR DRIVER SOMEWHERE IN THERE
    THEN FOLLOW INSTRUCTIONS TO INSTALL THEN RESTART YOUR PC.
  • DEKR
    DEKR Jan 13, 2009
    Let me know if you were able to manually install
    and if it's working
    thanks
  • DEKR
    DEKR Jan 13, 2009
    k
    thats a good sign is this a wireless connection
    whn you right click the internet icon in the taskbar and open network connections do you see two connections or one
  • DEKR
    DEKR Jan 13, 2009
    K
    make sure none of your plugs are lose
    I WANT YOU TO RIGHT CLICK MY COMPUTER THEN PROPERTIES
    HARDWARE
    THEN DEVICE MANAGER
    find your network and then reinstall the driver
    then restart let me know if this helped your internet is there just a matter of locating it.
    Once it starts again open your internet and type www.msn.com
  • DEKR
    DEKR Jan 13, 2009
    unplug your modem for minute
    go back to device manager uninstall the driver
    restart pc plug modem back in
    then open your internet icon and type
    www.msn.com
    I KNOW IT'S TAKING A BIT IF I WAS IN FRONT OF YOUR PC IT WOULD BE EASIER DON'T WORRY WE WILL GET YOU ON LINE WHAT PC ARE YOU USING FOR INTERNET
  • DEKR
    DEKR Jan 13, 2009
    we are going to reinstall the driver
    do you have a usb travel drive
    you can download the driver from the internet and instead of running it save it to your drive
    TYPE IN YOUR SEARCH
    network drivers for emachine t6520
    find the page that says emachines product supports and downloads
    open it
    choose your series
    scroll down click download and then scroll you'll see network adapter
    download and save
    then take to your other pc and download it on there
    then restart and open internet again www.msn.com
    This should do it
    Follow the instructions
  • DEKR
    DEKR Jan 13, 2009
    i have msn
    i would have to add you if this does not work and then i can send you the download i really want to help you
  • DEKR
    DEKR Jan 13, 2009
    do you have another cord to try
    and did you try and download the driver to a usb drive then install it on your other pc
    i would have to add you to im
    so hard when your not in front of the pc
  • DEKR
    DEKR Jan 13, 2009
    k
    i can add ya
  • DEKR
    DEKR Jan 13, 2009
    ofcourse we can do it tomorrow
    just send me a message when your ready
    in the meantime i'll do more research on your e-machine
    would be easier if i was sitting in front of it but don't fret
    we'll get it done
    TTYL
Driver not installing on xp service pack 2
ohhh i think u will have to reinstall the xp
cause that's happened with me too
i had the prob with the realtek s/w ..........
soo according to me there is only one soln reinstall XP
or download the driver from internet and try installing it hope it works
Jul 13, 2011 | Computers & Internet
I reinstalled XP and cannot connect internet
Most likely, XP does not have a copy of your network adapter driver and you will have to install it manually.
1. Get the make and model of your network adapter
2. Try DriverGuide to look for your driver if you do not have the CD for it
DRIVERGUIDE
Mar 15, 2010 | Acer Computers & Internet
Xp reinstallation cd only installs operating
you need to update it by internet, or purchasing it online
Feb 18, 2010 | Dell Computers & Internet
Can't install drivers on Lenovo T 60 after XP Pro reinstall
go to device manager, uninstall network adapter, reboot, windows should find and reload drivers.
Nov 02, 2009 | Lenovo Thinkpad T60 Notebook
W200 cause a blue screen
First of all: If you install SP2 you don't have to install SP1 over it. It already did. Secondly, don't install SP3, it destroys Windows XP.
Try reinsalling the PC with SP2, install the drivers and do nothing else, see if that helps.
If not, by all means post back here,
Yannick.
Jun 16, 2009 | HP WLAN MultiPort W200 802.11b Wireless...
Can't connect to internet after Windows XP reinstall.
Asus doesn't make it easy LOL. Here's the link you need to download the LAN files (and any other devices not working). When you click on the link, scroll down to XP and you'll get a list of drivers for this Motherboard. Best of luck to you!
http://support.asus.com/download/download.aspx?modelname=P5GD2-X&SLanguage=en-us
May 02, 2009 | ASUS P5GD2-X (610839128686) Motherboard
Hi I have a question about notebook Lavie C LC500/, this is very old notebook. So i have reinstall on it Windows XP SP3, and now i can't find driver for sound card :( I have tryed to instal Via Vinil sound...
try "conexant" audio device... or reinstall another xp windows, I had the same trouble with my presario 6111ea and I just change the xp with another one (www.isohunt.com) it was working smoothly! I didnt reinstalled any driver and automatically every worked!
Jan 08, 2009 | NEC LaVie S LS900/8E Notebook
Compaq presario m2000
try puting in an xp disk in and leave it to boot up if it dose the same you need to reinstall windows
Nov 12, 2008 | Compaq Presario Notebook
Wire less internet card not working after reinstalling windows xp
some time if you reinstall windox xp some application might loss but you need to do try to reinstall the wireless lan driver if you do this it will work am very sure
Jun 02, 2008 | Computers & Internet
Computers & Internet Logo
177 people viewed this question
David Payne
David Payne
