Question about Dryers
The capacitor is burnt out but I can't get in to replace it. If I screw off the back and pull the drum comes out with it. Is there anyway to just remove the outside without having to interfere with t
  • Dryers Master
  • 8,220 Answers
Have you seen this Espares video?
Posted on Dec 09, 2012
4 Suggested Answers
aborcass
  • 2651 Answers
SOURCE: Need to replace the screws that holds the drum baffle in place
remove the scresw holding the door on, remove the door, the remove the 2 screws oppisite th edoor inge and the front panel will lift off. there will be 2 5/16 screws holding the top down to the frame of unit, the top will then lift up[ giving you acces to the outside of the drum to resecure the drum baffle
Posted on Nov 21, 2008
jumptrout51
  • 3361 Answers
SOURCE: Screw on outside of drum
It should be there to hold the tumble vane secure to the drum.
Tighten it.
Posted on Mar 11, 2009
Jahn27
  • 1554 Answers
SOURCE: How to I get to the drum
Access to the outside of the drum requires the removal of the front then the top panel. Disconnect power to the dryer prior to servicing to avoid the risk of electric shock.
Open the door and remove the four screws located vertically along the inside lip of the door opening. These screws hold the front panel to the front shroud assembly.
Once the four screws are removed, grasp and press in on the upper edges of the front panel posts then twist it inward to release the clips holding it to the cabinet. Tilt the top of the front panel and move it away from the dryer.
The top panel is held on each side of the cabinet by two hold down brackets. Locate and remove the 5/16" hex-head screws holding each bracket then swing the bracket to the outside and unhook it from the slot in the top panel lip.
Open the door then lift the front of the top panel and tilt it toward the rear of the dryer.
Rotate the drum until the screw holes appear at the top of the drum and screw the baffles back into position.
Reinstall the top panel and the front panel by following the removal steps in reverse order.
Note: This guide is for Maytag Sloped-Front Dryers.
Posted on Apr 20, 2010
How do I replace rear drum bearing
On most dryers you can use a screw driver with a piece of cloth so you will not scratch it and pry up the top of the dryer. It will swing up and away or come off. Then feel for screws on the bottom of the dryer. You will need a offset screw driver to undo these or lay dryer on the side. There are also screws on the back. Pull the back away and off. Remove the belt remembering how it was threaded to the motor. Then lift up on the drum and pull out. If it is wore it will come right out. Unbolt the holder on the back of the dryer and the back of the drum. Replace and reassemble.
Oct 17, 2014 | Miele Novotronic Premier 500 Front Load...
Dryer works but squeeks the back is solid no inspection panel how do i get acess to grease bearing?
Greetings, The first step is to UNPLUG dryer:
The front has to come off to service your dryer.. The door comes off by removing screws from hinge..The door pulls out and you then grab the front panel and pull it towards you. This gets you into the drive area..Its most likely the drum rollers or belt pulley thats making noise..There is no drum bearing on the dryer.
The drum support assembly has to be removed to replace rollers or at the ;least lube them. I suggest going thru this labor to just replace parts then lube them. There are four screws that hold this front on..Two screws on each corner. Remove paying attention to how the tub rides on the front to make it easier on install...The belt can come off and the whole tub can be removed.
The belt goes back a certain way, so be careful to take note of how it fits back on drum and around belt pulley..At this time you can replace your rollers in back( the front has two rollers as well) and replace your belt pulley.
Jan 31, 2011 | Maytag Neptune MDE5500AY Electric Dryer
Kenmore 90 Series, 10 years old; Dryer was making funny noise and stopped in the middle of a cycle. There was a burnt smell when it stopped. Cannot turn drum manually either. What are possibilities?
OF COURSE SOMETHING BURNT INSIDE THE SYSTEM. YOUR MOTOR MIGHT BE BURNT. 90 SERIES, YOU MUST HAVE THE LINT FILTER ON TOP CORRECT? TAKE FILTER OUT, UNSCREWS THE TWO SCREWS, PULL TOP PANEL TOWARDS YOU AND LIFT UP. DISCONNECT LID SWITCH CONNECTOR, UNSCREW TWO SCREWS HOLDING FRONT PANEL ON, REMOVE FRONT PANEL, TAKE DRUM OUT AND CHECK THE UNIT. GOOD LUCK
TIMOTHY DO 714-334-1998
Aug 04, 2010 | Kenmore Dryers
I have a canon imagerunner 1630 had a paper jam and had to pull drum to get it out, now can not get it back in correctly, display reads check toner/drum crg
Before reinstalling the drum make sure the Developer unit is correctly attached to the drum unit. The two clips ( Blue slides on top ) keep the two items together. Canon had two screws that were to added make sure the two stay together when removing the drum. Anyway make sure the drum is squarely installed with you insuring the rear is pushed all the way down. The sensor is located below drum near the entrance to the fuser. Good Luck
Apr 06, 2009 | Canon imageRUNNER 1630 Copier
Hotpoint 1300 washer / dryer. No Heat when in drying cycle. Air being pushed into drum but not being warmed, burnt out heater element? Is there some kind of solenoid switch needs checking?
HI,
you do need a new motor.you need to take 2 screws out of top where lint filter goes. take top up and their will be 2 screws one on each side take screws out and pull upward and forward and the front panel will come off. you will need to remove belt and tub then you will see motor. you will need to be able to grab back side of motor that attaches to blower and front shaft of motor and turn opposite way to come loose from blower. you will then take back clip off and front clip and unplug motor and pull out. good luck hope instructions helped.
anu further question let me know.
thanks,
Mar 28, 2009 | Hotpoint Washing Machines
PYE2300AYW Dryer how do you remove the drum?
Once you loosen the screws from the spindle or axle, you should be able to pull(gently) the drum out. Be careful not to damage the rubber wheels. My question is why do you need to pull the drum anyway? It has nothing mechanical or electrical to it. Are you wanting to put a belt on?
Jan 28, 2009 | Maytag PYE2300AY Electric Dryer
Help!!!
Further dissassembly is required. You'll want to do this anyway to inspect the heating elements. Some of what I say my not apply to your model (because you did not list a model number). 1. Disconnect power to dryer. 2. open door and remove screws going up into the dryer top. (two or four) Usually these are phillips screws, but you may find tri-wing phillips or T-15 torx. 3. swing top back, allowing access to remove the two screws holding the front panel to the side panels. (near the top) 5/16 hex or twin drive (phillips / #2 robertson square drive) 4. tilt front panel forward, lift off and swing to the side. You don't have to remove the door switch wires if you don't want to. 5. Pull drum forward a few inches. (it's a tight fit to get it past the dryer sides) 6. release dryer drive belt. 7. Finish removing the drum.
8. inspect coil heating elements. If one or both have a break in them, you can replace just the coils, you don't have to get the entire big metal part that holds them. 8. Clean and reassemble. (check the teflon rear drum sleeve bearing and the front drum support slides. now's the easiest time to replace them if needed.) 9. put the drum back in, then the belt back on by reaching your thin arms way back to the belt tensioning pulley. The grooved side of the belt touches the drum and goes down directly to the motor drive pulley on the left, then around the tensioning pulley. 10. Put front back on dryer. 11. turn drum by hand several revolutions to make sure the belt is not twisted or comes off. 11. Finish reassemble, connect power and test. You're done !
Aug 31, 2008 | GE Dryers
Replacing the belt on my Whirlpool awz7303 tumble dryer
You definitely need circlip pliers to get the fan off though.. It's a bit tricky without them. Othere than that it's a fairly easy job.
Jun 02, 2008 | Dryers
Kenmore 90 seies belt replacement
you have to remove the top and front panel,if you have a top lint filter remove the two lint screen filter screws,pull the top toward you and up,lint screen inside,most pull forward and up,so you might have to remove the two console head screws(one on each side,flip up and remove 4 more screws,now disconnect the door switch,now remove the 2 screws on the front panel top 1 on each side,now pull up and off,remove any other wires that might go to the door,now pull the drum out,now look down at the motor pulley wheel and the idler wheel,the belt goes around the drum,now put the drum back in place,now put the belt under the idler wheel and up onto the motor pulley,replace everything and your done-mike
Apr 05, 2008 | Kenmore 65924 Electric Dryer
Replacing the fins on Duet whirlpool washer
most paddles are removed by grabbing hold of the paddle and pull towards the front of the washer which should release them youll need to lift it out when you have pulled on them love
Sep 12, 2007 | Washing Machines
Dryers Logo
37 people viewed this question
Top Dryers Experts
Dan Webster
Dan Webster
