Question about Sabre Televison & Video
Sabre tv hdmi hook up not working
Changed out cables no luck, replaced control board still not working. tv works good useing a different type cable to hook it to cable box.
tvtek
  • 1284 Answers
SOURCE: "No Signal" when DVD player is hooked up via component video
If you are using the same cables,same input and the cable box works ok. I would look into the settings of the DVD player. Such as is it a progressive playback and is progressive turned on. It is not turned on by default because not all TV's could handle progressive in.
Posted on Feb 08, 2007
SOURCE: Need help hooking up TV, BluRay, Home Theatre & cable box
I found that since the Panasonic TH50PZ80U TV has only 2 HDMI ports on the back of the TV, the best solution for me was to use component (red, blue, green) cables to connect the Home Theatre to the TV. I suppose I/you could connect the home theatre to the HDMI port on the front panel, but I don't want cables hanging out the front of the TV (personal preference). Unfortunately, I am no longer able to use the VIERA Link functionality available by connecting all Panasonic components to each other using HDMI cables, but I feel it's a small price to pay for the incredible picture quality acheived by using the HDMI cable to connect the HD Cable Box to the TV. I may yet be able to control everything using the HD Cable Box remote, but I haven't gotten that far yet but I've got Comcast coming on Saturday and hopefully they can let me know if this is possible: let me know if you have a solution.
So here are the components and the cable types used to connect:
  1. HD Cable Box to TV: HDMI cable & Optical Audio cable
  2. Home Theatre to TV: Red, Blue & Green component cables
  3. BluRay Player to TV: HDMI cable
I hope this helps someone else.
Posted on Nov 20, 2008
davy1144
SOURCE: problem conecting hp laptop to sony bravia 52" hdmi tv
u need 2 change ur pixels 2 1024 by 768 in display settings then click the screen with 2 on and extended ur display to it ,then open windows mobility center and click connect display this will open a screen with 3 options chose the bottom 1 use external display only or sum think like that this should work once u have ur display showing on ur tv then click connect display again and chose the top option and u should get ur display on both screen let me know if this solves ur prob it worked 4 me regards davy ps if u plug in and loose control of ur lap top i think uv already selected use external display only try changing ur pixel 2 1024 by 768 and try again if not u need 2 plug into different tv nd change this if u have any more probs with this let me know this prob had my head dun in 4 days tryed the tech guys nd they said my tv port was broke liers(there a wast ov time)
Posted on Apr 07, 2009
  • 57 Answers
SOURCE: No sound on my Samsung tv when I use a HDMI cable
hello..try to change the sound settings to HDMI..you say when you use other cables everything is fine so the TV reconizes the HDMi as a video only so your sound settings should be changed to HDMI
Posted on May 26, 2009
  • 57 Answers
SOURCE: Insignia TV no audio on non HD channels via HDMI cable.
have you tried to change the audio settings to HDMI on tv? when u have HDMI hookd up u have to change the audio to HDMI also
Posted on May 31, 2009
Vizio tv says no signal on any of the hdmi ports
Unfortunately, you fried the HDMI controller. Not necessarily part of the power supply "main board." (Not sure which board is the HDMI controller in your specific TV. It's usually a separate board by itself). Easiest workaround is to use the "Component" cable connectors. The downside is you only get 720P. However, most cable/satellite and _all_ antenna signals are only 720P anyway. Most people only see 1080P when viewing Blu-Ray discs. Aside from replacing the HDMI controller, the cheapest workaround for multiple source connections is to buy an HDMI to Component Converter A/V box, which allows you to connect multiple devices to one box with one set of Component cables connecting to the TV. Then select various "sources" via the box.
Mar 05, 2016 | Vizio E370VL 37 in. LCD HDTV
My sanyo tv picture wont come on except when you first turn it on then it goes off, the sound works
Have you tried using a different input like a DVD or Blu-ray player with a HDMI cable? If you get the same issue using a different device and a different input then it is possible the Input board in the TV is fried, lucky all the boards in LCD/LED TV's are real easy to replace and individually are fairly cheap.
Jan 02, 2015 | Sanyo Televison & Video
Hitachi L42S02A no sound through HDMI
I've had a few HD TVs that you could disable/enable individual ports on the TV in the Settings menu. Good luck.
Jan 28, 2018 | Hitachi L42S02A 42" Multi-System LCD TV
Digital noise when using ANY HDMI inputs or cables on Insignia 37" LCD TV
Most of the time it will involve replacing the entire board that connects to the HDMI and outputs associated with it--not a cheap fix and good luck finding any board for this brand set.
May 25, 2012 | Televison & Video
HDMI signal turns on and off while trying to watch tv. I've used 4 different HDMI cables still no change, but if i use a rca type cable its fine.
If you have more than one HDMI connection, have you tried using a different connection? Also, if you have another T.V. with HDMI, try connecting the device to the other T.V. and see if it works. Right now it could either be your T.V. or your device you're trying to hook up. If the device works on another T.V. then it's the T.V. that's bad, if it doesn't then it's probably the device that is bad.
May 04, 2011 | Televison & Video
HDMI failure Samsung HL-R5087W 50 in HDTV
After reviewing the service manual for this set, the problem is is in the DIGITAL BOARD. To get the right Digital Board you will need the Version number of the TV.
Good luck
N Sabre
Nov 09, 2009 | Samsung HL-R5087W 50" HDTV-Ready...
HDMi ( no signal, not supported) doesn't work with Dmr-Ez47v
Any HDMI cable manufactured in the last couple of years should all be HDMI 1.1 compliant, your problem is most likely the logic board in the TV itself or the HDMI connector on the logic board has a bad connection..
Have you tried hooking-up a standard DB15 VGA cable to the AKAI TV and your laptop?
If this works your problem is in the TV and will most likely have to be repaired to receive the HDMI signal since your Panasonic DVR and your laptop are not recognized by the HDMI input on the TV.
Ren
Jun 03, 2009 | Akai LCT2785TA 27 in. LCD Television
Samsung hlr4667 dlp \ no hdmi connectivity
No, when I bought my new plazma tv, and unhooked my old DVR box, I had to go to my cable provider and inform them. they sent a signal and WHAM I was back in Biz.
Nov 10, 2008 | Samsung DLP HL-P4663W 46" Rear Projection...
Televison & Video Logo
213 people viewed this question
Top Sabre Televison & Video Experts
Tom Chichester
Are you a Sabre Televison and Video Expert? Answer questions, earn points and help others
