Question about Watches
Manual timex t78061 indiglo
Looking for manual for timex t78061 indiglo
SOURCE: How to change battery for Timex Indiglo WR 30M
I second the vice advice...the only thing that worked was to put it in a vice and crank it one more crank then you think is possible. You will hear a little "pop" when it snaps into place. It was the only thing that worked!
Posted on Oct 22, 2008
SOURCE: setting day and date on timex watch
Pull the stem out part of the way not all of the way. This will allow you to change the date quickly without the day moving.
Posted on Jan 06, 2009
escapement
  • 2334 Answers
SOURCE: Link removal on ladies indiglo timex
You may or may not have arrows inside bracelet. Arrows are pointing the way the pins must come out.
First you have to find out what sort of pins or even screws are used to keep links together.
Examine both bracelet sides and find the side where pin ends have a groove.
Start with a tiny screwdriver and unscrew one of the screws. If it turns, but doesn't come out, that means you have a pins instead.
For removing pins the best would be pin removing tool (approx.5GBP on ebay), but it's possible to do the job without it.
Take a hardened steel needle and blunt the sharp end to the approx. size of pin end diameter using any sharpening stone or sandpaper. Get an old towel and fold it to make a soft base for work (like small cusion). As you don't have a special bracelet holder you will need a pair of helping hands to hold the bracelet steady upright. You will need small hammer and pair of flat nose pliers as well.
NOTE: The pins MUST be driven split end out first, not vice versa. Make sure that the grooved pin ends are facing towel, not the needle and hammer!!!
Now place the watch on the folded towel, take that needle and smallest hammer you have and start driving the pin out using light blows. Do Not hit hard, as you will brake the needle, scratch your watch or even injure yourself. Watchmakers are using 45 gram hammer, so, calculate your strength of blows.
After a few blows check if the split end is coming out and when you see that the end is long enough to grab it with pliers, pull the pin out with pliers. When pulling, do NOT turn pliers, as pins tend to brake when twisted. Use firm grip and your strength to pull the pin without twisting.
After shortening the bracelet or adding extra link(s) make sure that the pins go back EXACTLY the same way as they came out- the blunt end first in the hole and the split (grooved) end last. Before doing that check remaining pins in bracelet to make sure that you put them back from the right side of bracelet.
It is recommended to use plastic hammer to drive pins back in or you will scratch or damage bracelet. If plastic hammer is not available use an old toothbrush handle (or some plastic item) as an absorber. Simply put pin into the hole as deep as you can with your fingers, put the toothbrush handle on split pin end and hit handle, not the pin.
Make sure that pin ends are flush with bracelet. If needed- hit few more times.
Job done!
If you do not want to do it yourself, any jeweler will do it in a matter of few minutes.
Don't forget to rate, please.
Posted on Aug 10, 2009
escapement
  • 2334 Answers
SOURCE: please provide me the manual or insturctions on
Find manual in my tips.
Posted on Feb 02, 2010
cmcduncand
  • 714 Answers
SOURCE: I have a Timex indiglo wr 30m wrist watch and I can't set the day
http://www.timex.com/info/Product_Instruction_Guides_Downloads
Use the numbers on the back of your watch and you will have a PDF version of your instruction manual.
Hope this tip helps
R/
David
Posted on Feb 10, 2010
How to set the time on timex WR30M watch?
hi Janet.
You may also need to change the time when traveling or to adjust for daylight saving time.
  1. What to Look For. Locate the MODE button, the SET/INDIGLO button and the START/STOP button on the side of your Timex Indiglo WR 30M.
  2. Setting the Hours. Press down the MODE button until "TIME" appears. ...
  3. Setting Minutes and Date
https://oureverydaylife.com/how-do-i-change-the-time-on-a-timex-indiglo-wr-30m-12421830.html
How to set the time on timex WR30M watch Google Search
Dec 13, 2017 | Timex Watches
Are instructions available online for how to set Timex Timex T025B Indiglo Color Changing Alarm Clock? Thanks for directing me!
I will advice you check manualsonline.com to search for the instruction manual of your Timex T025B Indiglo
Mar 30, 2011 | Timex Watches
Hello can you help me with a question about timex indiglo watch, trying to find a manual with info about it.
Just get the completemodel of your timex watch and download the manual from the link below.
http://www.manualsonline.com/manuals/mfg/timex/timex_watch_product_list.html
Nov 08, 2010 | Timex Indiglo Analog Watch
I have a Timex analog Indiglo watch and need to change the date
Click on my profile (escapement), then click on Tips and Tricks. There you will find link to all TIMEX watch manuals.Rate me, please.
Mar 28, 2010 | Timex Watches
Hourly chime
You can get instructions from the Timex web site "timex.com".
At the bottom of the screen click on "manuals/downloads", then on "product
manual download"
Enter your watch type in the search box and click on "search"
Feb 25, 2010 | Timex Indiglo Analog Watch
Hope this tip helps
R/
David
Dec 06, 2009 | Timex 27191 Wristwatch
I want to buy a Timex gents chronograph wristwatch immediately with alarm & indiglo.Please tell me various models available in this category so that I can choose one
Timex has a great selection of watches that fit your needs. Timex is Indiglo so all their watches have it. When it comes to chronograph your also looking at a large number of watches. Here is their website to help you narrow it down to more specifics.
http://www.timex.com/gp/node/n/238494011/190-6525554-2651024?ie=UTF8&timexBrand=core
Sep 19, 2009 | Timex Watches
I can't stop hourly chime in my Timex Indiglo
1-Place watch on hard flat surface.
2-Hit repeatedly with large hammer.
If you should need further assistance just ask.
Jul 24, 2009 | Timex 27191 Wristwatch
Timex indiglo. Indiglo feature died.
The indiglo technology is time limited (it dims over the years with use) and cannot be repaired - have you had the watch a long time? if so, I'm afraid it's time to get a new one. Sorry!
Dec 30, 2008 | Timex Watches
Watches Logo
Top Watches Experts
Ansel Alberto
Ansel Alberto
Are you a Watch Expert? Answer questions, earn points and help others
