Question about Rohl Plumbing
How to adjust temperature on Rohl shower valve?
Hot water limit. remove cover to adjust?
4 Suggested Answers
  • 11 Answers
SOURCE: faucet issue
Sounds like it was installed upside down or the cartridge is installed improperly
Posted on May 07, 2009
  • 10 Answers
SOURCE: No hot water pressure on kohler bath / shower faucet
Try draining the system and apply air pressure (min 30psi) to each faucet. Open other hot water faucets to allow pressure to vent. Next try draining and cleaning the hot water tank.
Posted on Oct 24, 2009
SOURCE: Kohler shower valve (hot/cold switched)
Just had this same thing, on this exact faucet. If you still have the manual, it has instructions on how to rotate the valve for back to back installations where one shower has the hot/cold reversed. Our contractor got ours in backwards the first time and I had to call and have them come out and rotate the valve this morning.
Posted on Mar 13, 2010
Testimonial: "Thanks! That worked!"
How to turn up the temp. on a Rheem mod. 82v52-2 hot water heater
To adjust the thermostat, turn off the water heater. Then remove the access panel(s) and any insulation. The access panels are above the drain valve. Take a small flat blade screwdriver and rotate thermostat dial pointer. (The lower temperature settings are to the right.) Replace the access panel(s) and insulation and then turn on the water heater. Do not remove the protective cover on the thermostat.
Wait for water to heat and then check the temperature at various faucets. Make sure to adjust the anti-scald temperature limiter at any faucet that may be accessed by a small child or adult who might be injured by high water temperatures. (Just put a thermometer in the flowing water. Check the faucet installation information. The high temperature limiter will be under/behind the handle for single handle fixtures.)
I hope this helps.
Feb 21, 2015 | Rheem Water Heaters
Adjust handle stop on Metro high arc
Is it possible that you have installed the faucet incorrectly . Loosen it off and turn 90 degrees facing you so that one way is cold the other way hot.
May 08, 2013 | Hansgrohe Metro E Single Handle Deck Mount...
No hot water - thermostat not working
if u have a single handle shower unit remove handle and cover to access the water adjustments[scold protection] blue is cold red is hot faucets are shipped in coldest setting as a safety precaution need to adjust in the hot water
Dec 03, 2012 | Home
My shower water temperature is way too hot. How do I reduce it?
go to the hot water heater and turn it down 1\2 way a start from there
Jul 19, 2011 | Heating & Cooling
I have an emco equitemp shower valve and have recently installed a tankless water heater. I need to adjust the valve so that the hot water temperature is higher. The water heater heats at 140 degrees but...
You should have the ability to reach 185 degrees. As long as the Heater is capable of reaching 185 you should be able to process that extreme without a problem. The only reason you cannot get above 140 is because the valve is limited or defective. You may have to replace the shower valve to accommodate 185.
Feb 05, 2018 | Home
How do you internally adjust the hot water setting of a Symmons pressure balancing mixing valve?
  • To set the shower valve handle limit stop, remove the screw holding on to the handle and remove the handle.
  • Remove the round dome cover by turning in a counter-clockwise direction. At this point you will see a small slotted screw head that is visible in the valve cap.
  • Place the handle back on the valve stem (loosely) and open the valve turning the handle until the maximum desired position is reached. This may require turning the limit stop screw (T-34) counter-clockwise (see CAUTION above). To most accurately and safely verify the temperature of the hot water, place a thermometer in a tumbler of water filled from tub outlet.
  • Shut off valve and re-attach dome and handle.
  • Mar 02, 2011 | NRS Symmons Temptrol pressure balancing...
    Where do I find the hot water control on a reliance 501 electric water heater?
    You will find thermostat and limit switchs behind removable cover plates on front of heater. Remove four screws to remove covers. You will need to slightly part insulation inside to se thermostat. They are adjustable using ablade scredriver,Usually from 90-140 degrees. Temperature setting is set by turning screw which moves arrow pointer to desired setting. Be careful of touching any of the power wires. Hope this helps. Thanks
    Nov 12, 2010 | RELIANCE ELECTRIC WATER HEATER
    When turning on the hot water on dedicated hot water faucets, the water is almost scalding. However, when turning on the shower and tub that has only one faucet handle (mixes cold and hot) and put the...
    Pull apart the front of the valve and there is a limiter that is set to limit hte hot water, you need to adjust that limiter. I find many valves are shipped with teh setting too cold.
    Oct 09, 2010 | Delta & Single Handle Shower Faucet
    Wateris not hot enough, need to know how to adjust scauldgard on faucetto getmore hot water, and less cold.
    Assuming that you have sufficient hot water, you need to adjust the Scald-Guard valve. It's usually quite easy to do. The intent is to limit the amount of hot water that can be fed to to shower head or tub spout. On the 1300/1400 series faucents there is a disk behind the faucet knob/lever called the rotational limit stop. Remove the knob/lever, either by popping the cover off the knob and removing the screw with a Philips head screw driver, or removing the handle with an allen wrench. Next adjust the rotational limit stop disk clockwise to increase the limit on hot water flow. Delta claims each tooth you click past clockwise will increase the maximum water temperature by 6 degrees F.
    Delta has a great FAQ on their web site. As of Jan 30, 2011, this link is valid:
    http://www.deltafaucet.com/customersupport/faq/Water+Temperature/
    If the rotational limit stop disk is already turned to the maximum point (clockwise), then you may have a hot water flow problem (either with the cartridge or to or in the manifold). The cartridges require a little more know-how to replace. You'll need to shut off the main water valve prior to removing the old cartridge. There are a couple of places that detail how to replace and/or service the cartridges, including a short video on youtube. I can post more details on this if you find you need to replace the cartridge.
    Oct 06, 2010 | Delta & Single Handle Shower Faucet
    We have a home that is 3 years old. We never used the 3rd bathroom shower until today. We have a Moen single knobe shower/bath valve. To get water from the faucet you pull the knob out. To adjust the...
    Remove handle to gain acess to the temperature limit stop. Remove handle and pull out handle adapter kit and next there is a dail that can be adjusted to control the water to balance the temp. It could have been installed wrong, pay attention to where it is now and pull it back to it disengages out of the stem and move it counter clockwise a little and reinstall. Put handle on and test water for correct movement.
    Go to link below for a part's diagram if needed.
    TO ORDER PARTS CALL: 1-800-465-6130
    www.moen.com
    Aug 15, 2010 | Moen & Posi-Temp Single Handle Shower Or...
    Plumbing Logo
    467 people viewed this question
    Top Rohl Plumbing Experts
    obsteiner
    john h
    ray gallant
    Are you a Rohl Plumbing Expert? Answer questions, earn points and help others
