Question about Arris SBG1000 Wireless Cable Modem Gateway Router (493989-001-00)
I'm trying to connect an xbox 360 to the ethernet using a cable modem. We're having trouble. Is this possible? We connected the modem to the cable hook-up and connected the ethernet cable from the modem to the xbox360. Doesn't work.
  • 3 Answers
Make sure your modem or router is compatible with XBOX. I think Microsoft has a lost of working modems and routers. If this is all clear, connect the eth.cable to the modem/router. Power up the modem FIRST then the xbox. All this without any cd/dvd in the tray.
Usually as simple as that...
Posted on Jan 13, 2009
My xbox doesnt want to pickup the ethernet connection
There are two ways in which you can address this issue:
1) Attempt to connect wirelessly. You can access this feature via "Settings" on your XBox home page. After setting up your XBox to automatically connect to your internet router (by entering the password and name), you should be able to log into and play on XBox Live.
2) Connect via ethernet cable.
Although you've already tried this, it's possible there is an issue with your modem and not your XBox. Routers and modems usually have a shelf life of about 2-3 years-- if you have had yours for longer than that, it might be time to invest in a new one. Another issue could be a faulty ethernet cable-- they're usually pretty cheap (around ten bucks), so if the above fixes don't work go into a local electronics store, purchase one, try it out, and if it doesn't work return it immediately and you should get your money back.
Jan 31, 2012 | Microsoft Xbox 360 Console
Do u need a wireless adaptor to set up xbox live??
No, a Xbox 360 Wireless Adapter is not required to access, and set up Xbox Live, but you will need an internet connection. If you are close enough to a modem or router, you can buy an Ethernet cord, and plug it in to both the modem/router, and firmly into your Xbox 360 console. You will either need the Xbox 360 Wireless Adapter, or the Ethernet cord. Ethernet cords are very cheaper, much cheaper than a Wireless Adapter, but the Wireless Adapters are much or easier to reason with. So choose wisely with money.
Jul 06, 2011 | Microsoft Xbox 360 Console
How to connect Xbox 360 to modem
Hi Nacee..
Hope your r good there!
Anyways...First thing you should do is turn off your computer, cable or DSL modem and XBOX 360. Then you should hook an Ethernet cable from the cable modem to the Ethernet port on the back of your XBOX 360. Then power up your cable mode and then power up your XBOX 360.
BR
Alia
from
Twindi-online computer store
Feb 13, 2011 | Computers & Internet
I dont know how to set up my xbox live with an eathernet cable can you help?
Hi there
Turn off the Xbox 360 by pressing the power button on the front of the console. Afterward, shut off your modem by unplugging its power cord.
  • 2 Insert one end of the Ethernet cable into the Ethernet port located at the back of your Xbox 360 console. After that, insert the other end of the cable into your modem.
  • 3 Replug the power cord into your modem to turn it back on. Once it is active, press the power button on your Xbox 360 to turn it on.
  • 4 Navigate to "My Xbox" then "System Settings." Afterwards, select "Network Settings" then "Test Xbox LIVE Connection." You will be notified on-screen if the connection is successful.
  • Read more: How to Set Up Xbox LIVE with an Ethernet Cable | eHow.com http://www.ehow.com/how_6714462_set-xbox-live-ethernet-cable.html#ixzz0xBK8Zctz
    GOODLUCK!!
    Aug 20, 2010 | Microsoft Xbox 360 Console
    Not connecting to internet
    I am not that much clear whether you can change your Ip adress, but any queries regarding Ip-detais can be solved here, http://www.ip-details.com/
    Jun 07, 2010 | Video Game Consoles & Games
    I have a Cayman 3347w wireless router and I am trying to use one of the wired slots to connect my xbox 360 to the internet. the xbox will not connect. is this router xbox compatable?
    Please try the following steps below;
    To make a router connection to Xbox LIVE:
    1. Before you connect any cables, turn off your router, modem, PC, and Xbox 360 console. (Unplug your modem from its power source to turn it off.)
    2. Connect one end of an Ethernet cable to the Ethernet port on your modem and the other end to the Ethernet input port on the back of your router.
    3. With another Ethernet cable, connect one end to one of the router's Ethernet output ports. Connect the other end to your PC's Ethernet port.
    4. With the third Ethernet cable, connect one end to another of the router's Ethernet output ports. Connect the other end to the Ethernet port on the back of the Xbox 360 console.
    5. Turn on your modem, then your router, then your PC.
    6. Make sure your PC can access the Internet. If not, you may need to configure the router for Internet access. For help configuring the router using your PC, check the instructions that came with the router.
    7. Turn on your Xbox 360 console and sign in with your profile.
    8. If this is the first time you've turned on your Xbox 360 console, see Create Your Gamer Profile to get started with both the Xbox 360 system and Xbox LIVE play.
    If you're unable to connect to Xbox LIVE, you can try to diagnose the problem right on your console. Go to My Xbox and open System Settings, then select Network Settings (setup XBOX using Automatic Configuration DHCP), Test Xbox LIVE Connection.
    Hope this helps!
    Mar 28, 2010 | Netopia Cayman 3347W-Ent Wireless Router
    Im using my blackberry as a modem, and connecting it to my computer (obviously). but i have internet sharing on and connect directly to my xbox 360 to play live, how can i change my NAT settings to open by...
    you have to connect a ethernet cable to your phone and xbox 360 theres no possible way other then having a router connection from your phone to the computer.
    Dec 02, 2009 | Microsoft Xbox 360 Console
    Trying to hook up my xbox to the internet, I moved everything out of the spare bedroom to the living room. problem is the nearest phone jack to hook up the cable to the modem is in the kitchen, or do I...
    Hello noah757702
    In order to connect to Xbox 360 your modem would need both cable and phone jack, first ethernet cable connected from Xbox 360 to the modem and modem in turn should be connected to the phone jack to complete the connectivity set up, let me know if you need more info on this
    Nov 17, 2009 | Video Game Consoles & Games
    How To: USB hookup for computer while having ethernet hookup to Xbox 360.
    USB to PC is fine, make sure you have the original installation disk for it. Then you can connect the Xbox via network cable. There shouldn't be any problem as your modem can take 2 connections by the sound of it.
    May 21, 2009 | Westell Wirespeed LiteLine 6100...
    Why isnt my xbox connecting? i plugged the cble into the rouder and then put the other cable into the xbox and its not letting me connect.
    To make a router connection to Xbox Live:
    7. Turn on your Xbox 360 console with no disc in the disc tray.
    8. If you've already used your Xbox 360 system for offline play, the Xbox Dashboard will open to the Xbox Live area. Select the Xbox Live banner. When you see the Xbox Live Marketplace you'll know you're connected to Xbox Live.
    Jul 02, 2008 | Video Game Consoles & Games
    Arris SBG1000 Wireless Cable Modem Gateway Router (493989-001-00) Logo
    128 people viewed this question
    Top Arris Computers & Internet Experts
    Jerry
    Jerry
    bobkoure
    Level 1 Expert
    Are you an Arris Computer and Internet Expert? Answer questions, earn points and help others
