Question about HP Officejet 4315v All-In-One InkJet Printer
I just got this fax machine and with no instructions of course so i hooked it all up and tried to send a fax to a good fax number and it keeps telling me that thier is no answer, Please tell me how to set up the paper and the document i need to fax like does the plain paper go on the bottom and they doc, I want to fax go up top, Help please
  • 2,692 Answers
I'm trying to send a fax on my Canon Pixma MX340 . It rings when I dial the number, but just keeps coming back and telling me the line is busy. That shouldn't be happening at this hour. Is there...
Thank you for using fixya.........
The receiver is not receiving your fax, so the problem is coming.......
first you have to inform the receiver to receive the fax........
then try again...........
thank you......
Jul 23, 2011 | Canon PIXMA MX340 Wireless Office...
Faxing to america
may i know whats the brand and model number of the fax achine and what error does it display??
Mar 13, 2008 | Office Equipment & Supplies
Cannot send or receive faxes to one particular number, but is able to send and receive faxes with other numbers
"cannot send or receive faxes to one particular number, but is able to send and receive faxes with other numbers"
If your machine can receive a fax transmission from one number, it will receive from all numbers.
If your machine can send to all but not to one particular number, please check that there is a fax machine there to receive it.
You can try to send manually and listen for beeps from the other fax -if one is present- then push the START button to initiate transmission.
If their machine is in working order, the transmission should start. (After the initial 'handshake' of course.)
Jun 16, 2011 | Office Equipment & Supplies
My 575 fax won't send; it keeps printing "poor line condition". Is there something I can do? I am just trying to send a fax like I always do. It makes the noise at first like it does when it transmits,...
If this is happening to only one number you're trying to fax to, then the problem is most likely on their end, not yours. If it is happening with all the numbers you fax to, then I would suggest checking the telephone line hooked to the fax. Look for loose connections, or perhaps a bad cord from the phone outlet. The connection could be good enough to get a dial tone, but not secure enough for the fax to operate. If none of that holds true, I would suggest taking it to the shop and let a technician look it over.
Oct 23, 2010 | Brother FAX-575 Plain Paper Thermal
I don't understand the one touch dialing on the HP 2140
Hi Suzeo. Many HP fax machines have the function you are requesting. It is called the broadcast fax feature. Look in your owner manual for this feature. If I knew which model you have I would have researched it for you. IF by chance, your machine does not have this feature, it would be money well spent to replace your current machine with one that does. Depending on how many pages the daily fax is, I am estimating that you are spending an hour or more each day on this task. J.
Jul 03, 2010 | HP Office Equipment & Supplies
Can't send fax from Kyocera KM1650. It won't send a fax to a 202 area code, you get the start beep and then it's a steady tone that does not sound like a good fax noise. The fax will send if I use another...
Try turning off the ECM mode when sending to that number. The instructions are in the Fax user manual. If you dont have it go to and yo can get a link to Kyocera manuals.
Jan 20, 2010 | Kyocera Mita KM-1650 All-In-One Printer
Difficulty sending a fax
Hello. Please make sure your telephone line is plugged into the correct outlet.
Most fax machines typically allow you to plug the line (the cord that goes from the fax machine to the wall jack) and and a telephone (the telephone connects to the fax machine).
In order to fax correctly, you must plug the line into the jack with a block (looks like a 'T') marked on it. Do not plug the line into the jack marked with a phone hand set marked on it.
This shoulds in detail how to connect the line properly. For this printer the line cord must be plugged into the jack labelled "L"
This will show you how to actually send the fax. On your PDF View select page 42.
Feb 26, 2009 | Canon PIXMA MP780 All-In-One InkJet...
Cannot send faxes!
Take an ordinary phone and connect it to the auxillary port on the back of the fax. Call the number you are trying to fax and listen to see if it connects and the other fax picks up. Be sure you are using any prefix numbers required such as a 9, or a 1 and area code if required. HP recommends that you use a 2 wire phone cable, not a 4 wire (see how many metal connectors are in the jack to tell). Of course, if you are on a DSL line you want a filter installed for the fax. If this doesn't work, try a different phone cable. You could also have a bad modem in the fax. That would be last on my list. Good luck.
Jun 10, 2008 | HP OfficeJet V40 All-In-One InkJet Printer
Won't send faxes
did you put the originals page(s) in the machine FIRST to fax, then enter the number then press start?
If you enter the phone number 1st BEFORE putting your originals in the feeder, the machine thinks you want to make a copy.
The FAX Mode is the setting for incoming faxes.
Try that and let me know if it works.
There should also be a button called "Hook" or "speaker" or something that you hit and you will hear the dial tone.
Once you hear the dial tone, you can dial the number, (make sure the pages you want to fax is in the feeder.
Once you hear the fax high pitch noise, hit the start button.
Hope this helps.
Let me know if it does and also remember to leave a feedback and rating if I have helped you.
Thanks and good luck.
Mac =)
Feb 19, 2008 | Lexmark F4270 Plain Paper Inkjet Fax
Brother Intellifax 2820
It could be a compatibility issues between the two faxes. If the other fax is particularly old its communication speed could be too slow for your fax.
Also don't rule out the line on there end. Many times in my job I've had Telephone company's check the line remotely and say its ok but its not until they come out to site that they find an actual fault.
Do a manual reception. Put your fax reception mode from automatic to manual. When the fax rings in pick up the line with the hook or speaker phone button and then press the start button. This rules out a fair part of the line correction. If you can receive of course.
Feb 06, 2008 | Office Equipment & Supplies
HP Officejet 4315v All-In-One InkJet Printer Logo
42 people viewed this question
Ben Johnson
