Question about Denon Audio Players & Recorders
AVR-2307C1 - When AV and TV are turned on picture and sound on TV and AV Zone 1 flash on and off. Zone 2 music continues to play.
SOURCE: Zone 2 problem for AVR 3808
It doesnt down convert to zone 2 via hdmi.... must use analog audio or something else.
Posted on Jul 27, 2008
SOURCE: Denon AVR-3805 zone 2 no longer working
If no sound coming through Zone 2, steps that worked are below. Layout: Denon AVR-988 running in 5.1 mode with patio speakers designated as Zone 2: 1) check that patio speaker wires are connected to Denon's back surround speaker terminals, 2) check "Menu then "Manual Setup" and scroll to check that "Amp Assign function is set to "Zone 2". You won't get Zone 2 sound unless this is chosen in this instance. Also check the volume settings in the "Manual Setup" to ensure you haven't turned sound down by -40 DB or limited it. Now try turing on Zone 2 sound either on front panel or on rear of remote. If you still have no sound, what worked for me is there's a Zone 2/Rec Out pushbutton on front left top panel by round input knob. This must be set to "Zone 2 Source" and not "Rec Out Source".to avoid diverting the signal to the Rec Out jacks. Keep turning the input select button until it reads "Zone 2 Source". Then turn on and this should route the signal to your Zone 2 speakers. srhfish
Posted on Mar 04, 2009
SOURCE: Yamaha RXV661 Receiver has Zone 2 Vol Fix error message
i have the same problem. i have a rx-v661. i goto the zone 2 settings and try to change the volume and it says VOL FIX. I cannot hear anything out of zone 2. It takes the current volume that is in zone 2, but i cannot hear anything. it has been working fine for at least a year.
Posted on Jun 27, 2009
smarthome2
  • 1114 Answers
SOURCE: Denon AVR-2106 - Zone 2 shuts down system
Check your speaker wires on zone 2 and look inthe manual for speaker configurations with zone 2. you may have a speaker conflict. If you still have an issue, post a comment with your speaker setup and I'll help some more. Hope this helps
Posted on Jul 01, 2009
  • 53 Answers
SOURCE: Yamaha RX-V550 AV Receiver Stuck on Zone 2
You can always do a system reset. there should be instructions in the handbook
Posted on Nov 07, 2009
How to connect a denon avr-e400 receiver to a televion
If the DENON has an HDMI output, and your TV has an HDMI input, then use a HDMI cable. Then, use the TV's remote-control to select "source" (or "input") as 'HDMI 2' or 'HDMI 3' (assuming that you have been using 'HDMI 1' to watch TV).
Feb 08, 2015 | Denon AVR-E400 7.1 Channel 4K and 3D Pass...
Denon AVR - 2807 flickers in TV mode with picture & sound.
Change the hdmi cable and try. If not then you have an hdmi fault module.
Dec 15, 2013 | Denon AVR-2807 Receiver
Denon 1910 Zone 2 no sound
Typically, Zone 2 is for a different program than the one you're hearing in the main listening room. You can choose any source for Zone 2 EXCEPT a digital one.
Dec 29, 2009 | Denon AVR-1803 Receiver
Denon AVR 2308 ci. No sound when using TV (Niece changed setting
there should be a way to change a setting between.....analog, coaxial, optical 1 and optical 2..if everything is connected through rca jacks try analog
Nov 03, 2009 | Denon AVR-2308CI
Denon AVR-2309C1 will not play sound through
Turn off zone 2 then turn your receiver on the main zone on Radio, tune in a station and check for audio. Post a comment and let me know if audio works that way. If you don't have any audio, list your other equipment makes and models as well as how they are interconnected to your receiver (cable type) and I will help you troubleshoot
Jun 28, 2009 | Denon AVR588 Receiver
The Yamaha RX-V463 AV does not playsound from the blue ray player
"I am also having difficulties in try to display the yamaha set up menu on the tv."
According to the manual the display menu for TV will not work with HDMI hook up.
I also have a Panasonic HD TV and can't get TV sound through my Yamaha AVR on "TV Sound" mode.  Trying to use HDMI cable for this also.  Do I need a digital optical cable or do I not have something set right?
Apr 07, 2009 | Yamaha RX-V463 Receiver
time to reset the microprocessor. See page 87 in manual.
1) switch off the unit using the main unit's power operation (small power button)
2) hold the PURE DIRECT button and DIRECT button at same time and turn the main unit's power operation on.
3) wait for entire display to flash in 1 second intervals
now the speakers need to be set up again but zone 2 will be working. i suspect a power surge causes the microprocesser to be corrupted. i put a power surge protector and have not had problems (lately).
Dec 29, 2008 | Denon AVR-3805 Receiver
Jul 14, 2008 | Denon AVR 3808Ci Receiver
2 zone setup
Consult the user manual. If you don't have one, it can be downloaded free at Denon's website. Two of the speaker oututs serve multiple functions. Hookup and setup need to be checked. What you want to do is possible as long as you're only using a 5.1 setup indoors.
Sep 02, 2007 | Denon AVR-1507 Receiver
Top Denon Audio Players & Recorders Experts
 Grubhead
Grubhead
Are you a Denon Audio Player and Recorder Expert? Answer questions, earn points and help others
