Question about Brother IntelliFax-4100e Fax
When I try to send out faxes, it always say the line is busy.
    Champion:
  • 320 Answers
Are sure that you have the right plugs plugged in? to the right jacks on the machine
Posted on Jan 20, 2009
Why won't the fax work?
My recommendation would be to hit the speaker button when sending a fax to hear why your fax wont go through.
When you hit speaker you should have a clean dial tone, then when you start dialing and the tone stops make sure you don't have any static or noise on the line.
There are several reasons you might get a NG error. One is the fax line you're trying to send to is busy. Maybe it's a phone line not a fax you're trying to send to. Maybe you need to dial a 1 or 0 for long distance, maybe your fax line has noise on it.
Using the speaker can help troubleshoot what the problem is.
Skelton Business Equipment Houston Copiers
May 08, 2014 | Sharp MX2610N Printer
Brother 7340 not sending or receiving faxes line busy
sounds like the modem on your printer has failed depending on how old it is most likely it would be cheaper to buy a new printer
Mar 24, 2014 | Brother MFC-7340 All-In-One Laser Printer
My Brother MFC7340 Fax Machine will not send faxes it has a busy signal always and a busy signal when someone tries to fax me.
You need to reset the memory, since previously you have dialed some number, which is not able to connect. So restart the printer. Unplug the printer for 10 minutes and plug back the power to the printer.
Hope this helps.
Shane
Apr 04, 2011 | Brother MFC-7340 All-In-One Laser Printer
I have a bother FAX4100E . It is newly installed. I can receive faxes but when attempting to send, no dial tone is immediatley heard. The fax always gets a fast busy. It is on the same line as my old...
Hi.
Check and eventually replace the phone cable.
The fax machine must be connected using a two-conductor phone cable such as the cable pictured below at the left:
Dec 13, 2010 | Office Equipment & Supplies
The fax machine will not faxes, it prints out as busy.
make sure the cable is in the LINE socket not the TEL socket as this will stop connection..
Jul 20, 2010 | Brother IntelliFax-2820 Laser Fax
Fax is always busy when sending, have the line into the phone line port and into the telephone jack, fax scans and dials and even redials but it never go through, prints out receipt that says busy/no...
Has it always done this, or did Fax once work? Sadly, Windows XP Fax has many shortcomings, not the least of which is that it won't work with many modems still in common use. Modem incompatibility is not apparent during installation or the initial setup. It only becomes apparent when you try to send or receive a fax. The Fax Service will dial or will answer an incoming fax but then fail with any of a number of unhelpful error messages such as "Line is busy," "There is no answer," or "Reception error." There will be nothing in Event Viewer to give a clue as to where the problem might lie.
These errors have been nearly impossible to track down. To do so requires enabling both PSS and debug logging of fax transmissions, both of which require fairly extensive registry changes. For the time being, the best advice is to attempt to use XP Fax only if you have a modem that is listed on the Windows XP Hardware Compatibility List and using the latest drivers.
Hope helps.
May 09, 2010 | Brother MFC-5840CN All-In-One InkJet...
When sending a fax I keep getting back a result "BUSY". I've tried a couple different numbers and always get the same thing. Faxes are coming in just fine.
The only thing that could stop you from sending a fax or not get a dial tone, would be the connection to the phone line. Make sure the telephone wire is plugged into the line jack and not ext jack of the machine, and should go straight to the wall, without splitters or extensions.
If you still cannot send a fax, try another wire or jack
Apr 05, 2010 | Brother MFC-7340 All-In-One Laser Printer
Receiving faxes
Certainly not your fax machine problem.
The client needs to verify your fax number.
Oct 03, 2009 | Panasonic KX-FL511 Plain Paper Laser Fax
Trouble faxing
Check the fax line with a regular phone and dial a fax number to listen for fax tones.
May 31, 2009 | Samsung SCX-5115 Fax Machines
Brother IntelliFax-4100e Fax Logo
103 people viewed this question
James Cagle
James Cagle
Samyfam
Samyfam
Victorman
Victorman
