Question about Hitachi 53UDX10B 53" Rear Projection Television
How do i get the front screen protector off to clean behind it?
    Champion:
  • 240 Answers
This is a removable lamp box inside unit
take off back panel and remove botem screws box should slide right out
thanks,
daniel.
Posted on Jan 12, 2009
Can the screen cover on a A Fitbit HR Charge be replaced
It can!
(6-Pack) EZGuardZ Screen Protector for FitBit Charge HR (Ultra Clear ...
https://www.amazon.ca/6-Pack-EZGuardZ-Screen-Protector-FitBit/dp/B00SVW2DPO
  1. Cached
Pack of 6 Brand New EZGuardZ™ Screen Protectors; Precision Cut for your FitBit Charge HR, NO Cutting Necessary; No worrying about sticky residue; Thin, ...
Screen Protector And How To Get Scratches Out - Fitbit Community
https://community.fitbit.com/t5/Charge-HR/Screen-Protector-And-How.../835469
  1. Cached
Jun 21, 2015 - If you have a Fitbit Charge HR, I highly recommend getting a screen protector. The plastic screen is not strong at all, and it is also very easy to.
Best screen protector brand for Charge 2. - Fitbit Community
https://community.fitbit.com/t5/Charge-2/Best-screen-protector...Charge.../1543173
  1. Cached
Sep 2, 2016 - Wendy ' California. Retired Classic, Ultra, Charge,Charge HR. In use One, Charge 2, Surge, Blaze, Alta and Aria ' Windows 10 ' Android Moto ...
Amazon.com: XtremeGuard™ Screen Protector for FitBit Charge HR ...
https://www.amazon.com/XtremeGuardTM-Screen-Protector-FitBit-Charge/.../B00SV...
  1. Cached
Buy XtremeGuardTM Screen Protector for FitBit Charge HR (Ultra Clear): Screen Protectors - Amazon.com ? FREE DELIVERY possible on eligible purchases.
FitBit Charge & FitBit Charge HR Watch Front INVISIBLE Screen ...
https://www.amazon.com/INVISIBLE-Protector-included-Protection.../B00UMAXNJS
  1. Cached
Buy FitBit Charge & FitBit Charge HR Watch Front INVISIBLE Screen Protector (Front Shield included) Military Grade Protection Exclusive to ACE CASE: Screen ... screen cover on Fitbit HR Charge Google Search
Nov 16, 2016 | Exercise & Fitness
Can the screen be replaced on a fitbit charge hr
  1. Cached
  1. Cached
  1. Cached
  1. Cached
  1. Cached
Iphone 4s shins
Step 1: Clean your workspace. Be sure to get a flat, hard surface without a lot of fabric, liquid, dust, etc.
Step 2: Lay the phone down and clean it well with the cleaning cloth provided. Do not use any kind of cleaning fluid or water, but try to be sure that all fingerprints are gone. Especially be sure no dust or lint particles are on the screen. Before proceeding be sure that there are not a lot of dust particles gathering near you, vaccum and clean the area up a bit more if need be. You want as sterile an area as possible before continuing.
Step 3: Being careful not to touch the sticky side of the screen protector, peel back the tab where indicated. Hold the screen protector only by the sides and line it up with the phone. If you touch the sticky side of the screen protector by accident do not try to clean it off, you will only make it worse. Line up and let the screen protector fall into place from the top of the phone to the bottom. Some people choose to use a credit card or thin piece of plastic to smooth out bubbles as the screen protector makes contact with their device, however this is usually not recommended by the makers of the screen protectors or the phone. The choice is yours, but bubbles are meant to smooth out over time, so take that into consideration.
Steap 4: Once the screen protector is on the device if it is straight and you can see bubbles but no lint or dust beneath it, you are successful, give it a few days for the bubbles to dissipate. If it is not on straight, you may be lucky enough to be able to lift it up and place it better without fault, however this is risky. If lint or dust has gotten between your phone and the screen protector you have likely failed, there is little recourse from here, other than removing the screen protector, cleaning the device, and trying with a new screen protector altogether.
May 24, 2013 | Cell Phones
Removing a screen protector on a Hitachi 57F10A
You might try Hitachi for the service manual with full breakdown.
Basically the entire front screen unit comes off from the front in one piece, then inner two screens come out--carefully! and then frame needs to be partly pulled apart to get out screen from rear as it is in a slot all around the frame.
Apr 10, 2012 | Hitachi Televison & Video
Scratched plastic screen protector
I have a rear projection TV that I thought had a scratch as well. Upon closer examination and several attempts to clean, I discovered that there was a spider web behind the screan in front of the color projectors. I carefully removed the screen and gently cleaned the spider web from the screen. Presto no more scratches.
Hope this is a viable solution for you as well.
Jul 02, 2011 | Mitsubishi WS-65809 65" Rear Projection...
SCRATCH ON SCREEN
front screen is a protector but also helps with the image quality. new screen runs about 190 dollars
Jun 02, 2009 | Akai PT61DL34 Television
Screen protector broken
The protective screen is part # 409088101 and is available from tritronicsinc.com for $103.01
Dan
Dec 15, 2008 | Sony KP-57WS500 57" Rear Projection...
Mitsubishi VS-6043 - 60 inch
These are fairly simple, remove the speaker cover and then remove the screws at the bottom of the screen, then the whole thing lifts up and off, be sure to unplug the front panel controls, this plug can usaly be found just behind the cover behind the speaker grill
Feb 07, 2008 | Mitsubishi VS-6043 60" Rear Projection...
Dirty Screen
You should be able to access the screen from behind after taking the back panel off.Also if you reach up inside the rear wall you can clean the mirror ad picture tube lenses. This will make a vast improvement on picture brightness and quality.
Jan 23, 2008 | Philips 51PW9303 51" Rear Projection...
Phillips hd 55 inch
It could be either place probably on the back of the screen itself. If it were on the picture tubes it would be big. You'll have to take the back off and check it. Stargazer
Apr 19, 2007 | Philips 36PT842H 36" TV
Hitachi 53UDX10B 53" Rear Projection Television Logo
48 people viewed this question
Top Hitachi Televison & Video Experts
Jaime Hernandez
Are you a Hitachi Televison and Video Expert? Answer questions, earn points and help others
