Question about Heavy Machinery
Location of governor linkage and throttle linkage
This is actually a craftsman chipper/vac model # 987.799610 and engine model #143.955016. My problem is i don't know where to place the governor linkage and throttle linkage back to the proper place. Meaning which holes they go in and where they go. I forgot to write it down when i took it apart. Any help would be greatly appreciated. Thank you in advanced.
2 Suggested Answers
  • 437 Answers
SOURCE: location of governor linkage and throttle linkage
Try going to You can put in the engine number 143.955016 in the model search and it should give you a parts list and diagram for that engine.
Good Day.
Posted on Nov 06, 2009
Testimonial: "Thank you!"
Rpm maxes out and I can't bring it down
check that throttle linkage is ok and free, check that throttle plate is free to move and not jammed - check that srew in the throttle plate is not allowing plate to restrict and jamb throttle
check the governor springs and links are in the correct places and are free to move , check that governor is working ?
if its not migght be governor is adjusted wrong or slipped
or its flown to peices
if unit is ohv model have seen the the ocilating balancer
torque link rod break and cause a engine to go to full throttle
as sson aas the engine was started
please let me know model and type numbers off the engine in question and its make ie briggs etc
and will try help further
cheers paul
Aug 15, 2010 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Craftsman 22hp 7500 zero turn mower 3years old.
Be careful - running ungoverned will quickly destroy the engine. Look at the carburetor throttle lever. There should be two linkages attached -- one from the manual throttle lever, another from the governor. The linkage to the governor is usually a spring. Perhaps that came off or broke, or a foreign object is wedged in there.
Jul 15, 2010 | Craftsman 20 hp 42 in. Deck Yard Tractor
Sears Craftsman mower-Tecumseh engine 3.75 HP- wouldn't start-replaced air filter & spark plug; dismantled carburetor and cleaned it; now it will start but only runs for a couple of seconds and dies....
check the linkage for the governor, maybe on the wrong side,when off it should be pushing the throttle wide open, the governor brings it down after start up!
Jul 06, 2010 | Craftsman Garden
I have a 9hp Tecumseh engine on my Sears chipper vac. I rebuilt the carb and forgot how the governor and throttle linkage hooks up. Could you send me a diagram showing what holes these linkages go in? The...
I will try again here.
1 wire link from the top hole in the governor arm to the throttle on the carb. There should also be a wire link with a spring that goes from the Governor arm to the speed control handle.
Oct 21, 2009 | Craftsman 6.5 Hp Chipper Vac
Need a leaf bag for a chipper/shredder/vac
That is actually a good price. MTD wants $225.00
Oct 04, 2009 | Craftsman 4 Cycle Blower/Vac
Throttle doesn't work properly
try go to parts and enter your mod# from under your seat IE:358. and so on.
Look around for prompts and info for you mower from your entered mod#
May 24, 2009 | Craftsman 17.5 hp 42 in. Deck Lawn Tractor...
Carb linkage hook up
Hello rebel_auto:
>>Send me the Make, Model and Type or Spec Numbers Off the Engine, Please. With these I can Locate the Proper Manual and Better Assist you.
However, this File may Help.
**The Throttle Cable Attaches to the Throttle Control Bracket. The Cable Moves a Slide that Moves a Pivot. The Pivot has the Spring Attached to it and the Other End of this Spring Attaches to the Governor Arm. The Solid Link Connects to the Governor Arm and goes to the Throttle Shaft on the Carburetor. When the Throttle Cable is Moved it Moves the Pivot and the Pivot Pulls the Spring. The Spring Pulls the Governor Arm and the Governor Arm Moves the Throttle Shaft. Usually the Spring is in the Lower Hole in the Governor Arm and the Solid Link is in the Top Hole of the Governor Arm.**
Please, Do Not Hesitate, If I Missed Something or you Hit a Snag or this Does Not Correct the Problem, I am Here if You Require More Assistance.
Hope this Helps. Let me Know What Happens, Please. May the All Mighty Bless You and Yours. Be Safe and Be Happy. Thanks.
Good Luck
jbridger (John)
May 14, 2009 | Craftsman Garden
Good Day.
May 02, 2009 | Troy Bilt Walk Behind...
Heavy Machinery Logo
1,079 people viewed this question
Top Heavy Machinery Experts
Bill Boyd
Tom Chichester
ray gallant
Are you a Heavy Machinery Expert? Answer questions, earn points and help others
