Question about DCS WO-130 Stainless Steel Electric Single Oven
I need instructions on how to install new LCD display in DCS oven
DCS WO-130 SS single oven LCD display does not work. I ordered and was shipped a new one which I received today. There are no instructions on how to replace. Can you please help me?
Terry Mammenga
2080 Gregory Dr S
Billings, MT 59102
406-591-5711
4 Suggested Answers
SOURCE: DCS Single Wall Oven Model WO-130-SS
Order part #211708 from 1-888-281-5698 DCS Fisher@Paykel new Zealand. Only need philips head screw driver and twenty minutes. This part is a upgrade for lcd only. old part was a three part system, but no need for three parts only lcd screen.
Posted on Jan 08, 2009
milten1
  • 1304 Answers
SOURCE: need a service manual for wo-127ss DCS single wall
you can call dcs, they will be happy to send you a manual,
but mostly, this should be pretty simple, three small black phillips heads hold tthe console down, the are above the door when closed
from there the panel should tilt forward and off
becareful they dont leave much room. or very long wires
Posted on Oct 13, 2009
SOURCE: dcs oven display dim - need part #
Thanks Folks... saved me some $$$ on my DCS-WO-227BK !
Part ordered direct cost $87 vs. part ($140) + labor ($125) from service agency.
Turn off power (50 amp circuit switch in electical panel), removed some screws and replaced part #211696 (DCS EOC DOUBLE DSP) as outlined by duder999.
Posted on Jun 30, 2010
DCS WOS-130 oven won't turn off. I've turned the breaker off and back on but each time the oven starts heating without turning it on through the controls.
This sounds like a stuck relay on the control board or in rare cases a short to ground in the oven element itself. Test the oven element terminals to the case. If there is continuity then replace the element. If it checks Ok then more than likely there is a welded relay on the board. you can try tapping the relays on the board. Sometimes this jars the contacts loose and things work again. Be prepared to replace the control if this is the case.
Feb 12, 2014 | DCS WO-130 Stainless Steel Electric Single...
Dcs oven display dim - need part #
I just did this same repair...same part number as above (Part #211696 "Electronic Oven Control, Double).
to install you have to remove two screws on the top of the display section of the oven, as well as several screws on the bottom of it, and the screws holding the close pin/temperature probe socket.
Then you can pull off the whole top section (slowly) and remove the two connectors to the existing control unit.
Then release the ribbon cable connected to the control unit on the inside of the top section (press the two small pins inward and slide up the small front section of the black socket to release the ribbon connector.
Unscrew the old control panel, screw in the new one, connect the ribbon, and then reverse removal steps. Easy!
Jul 19, 2009 | DCS (WOTD-227) Double Oven
NEED HELP ON DCS WO-230 DOUBLE OVEN
there are 2 screws at the top outside and 2 or 3 on the bottom of the display panel. remove those and the panel should lift off the mount. remove the ribbon cable and 4 screws for the display and replace.
Oct 05, 2008 | DCS WO-230 Electric Double Oven
Display on our dcs oven is beginning to fade. can i fix it?
Hello just repaired my DCS wall oven. LCD screen is no good. part # lcd only is 211708. cost is $85.00 dollars with shipping. Took me twenty minutes to install. just need one philips head screw driver.Just call DCS Fisher@Paykel 1-888-281-5698 new Zealand.
Oct 03, 2008 | DCS WO-130 Stainless Steel Electric Single...
DCS over F7 error beeping
KEYPAD BUTTONS ARE REMAINING CLOSED FOR MORE THAN 32 SECONDS. REPLACE KEY PAD,DUE TO STERCHED PANEL MEMBRANE
Jul 25, 2008 | DCS WO-130 Stainless Steel Electric Single...
DCS elect wall oven LCD display
Had the same display issue with my DCS WOS-230. The display was fading and made it very hard to read clock and temp setting. Called DCS/Fisher Paykal and was told I need the Control system kit for $335.00 to fix the issue. After reading the input on this issue on this site I pushed them to sell me just the DCS EOC 211696 double display module 100-01095-00. Install took 10 minutes and everything works great. Thanks all for laying the groundwork as DCS will really push hard to sell you the more expensive kit that you do not need.
Jul 17, 2008 | DCS WO-130 Stainless Steel Electric Single...
Jul 07, 2008 | DCS WO-130 Stainless Steel Electric Single...
Dim LCD's on DCS Double Wall Oven
Had the same problem last week - called DCS (which automatically transferred me to Fischer-Paykel) and was able to order the part from them.  They knew exactly what it was, and shipped to me in CA from CA, it was less than $90.  Just installed it, and the new one works swell.  One suggestion - I drew with a Sharpie on one side of each of the three parts that plug into the board to help align the new one, and to install the wide ribbon cable (not really a cable, but you'll know what I mean), pull up on the two side pieces and the ribbon pulls right out.  Keep it up and slide the new one in and then push the black piece down.  That was the only part that took me a minute to figure out.
Jul 07, 2008 | DCS (WOTD-227) Double Oven
DCS wall oven F7 ERROR
I TRIED SOLUTION FROM SYMAR DATED MAR 14, 08 IT WORKED FOR NOW. I HOPE IT WILL CONTINUE WORK UNTIL SERVICING...COME MORNING.
Feb 09, 2008 | DCS WO-130 Stainless Steel Electric Single...
DCS WO-130 Stainless Steel Electric Single Oven Logo
Top DCS Ovens Experts
ashburton
Sal De
Joyce Nokleby
Are you a DCS Oven Expert? Answer questions, earn points and help others
