Question about Cooktops
HV CAP FOR SHARP R9H20 MICROWAVE
I CAN NOT FIND A HV CAPACITOR 0.37MF 2400 MVAC FOR MY SHARP R9H20 MIVROWAVE OVEN .
WHERE TO GET ONE?
THANK YOU
DABADEBO
My microwave keeps running
Thank you for your post, Lou!
From my understanding your Frigidaire microwave continues to run and when you press the second key your turntable will turn. This sounds like a potential issue with your keypad or control panel. I would recommend performing a reset on your microwave and you can do that by disconnecting power from it for at least ten minutes. This will help clear out any miscommunications within your microwave. If that does not correct your issue I would suggest seeking assistance from a professional technician for proper diagnosis and repair. This will help you avoid any unnecessary part purchases. Hopefully this is helpful. -Matt
Jun 05, 2015 | Frigidaire Gallery FGMV154CLF 1.5 cu. ft....
How do I change the internal lightbulb?
Your owner's manual should show how. No manual, try manualslib.com
My old sears microwave light bulb is in the upper front left hand with bulb top up and socket down but behind a screen. There are screws to remove the upper fan apparatus, which appears to make the side available to extract the bulb. Probably a very special bulb, so I would get one before going to that trouble. It might also be the switch that is bad rather than the bulb. That probably requires removing the outer surrounding cover.
Apr 11, 2015 | LG LMVH1750ST Over-the-Range Convection...
Why is there no power in microwave?
sounds like a blown fuse but water takes 20 minutes you must have had 10 gallon in it .
Feb 20, 2015 | GE 30" 2.0 cu. ft. Sensor Microwave Oven
What does error code E-13 mean
Hello there
Sounds like a 'gas sensor' (whatever that is) error. I recommend calling Samsung Support or a qualified Microwave Technician
SMH2117S/XAA Microwave Is Displaying An Error Code If your microwave is displaying an error code, such as -SE-, E-11, E-12, E-13, or E-14, or any other trouble code not listed here, cycle the power to the microwave by either unplugging the unit, or cycling the circuit breaker for approximately 60 seconds before restoring power.
If the above suggestion does not work,and the error code returns, your microwave will require service.
namo_fileview.jsp?type=nfs&pid=decisiontree&did=466719&cid=5uwnecasicas@namo.co.kr&sep=%7c
Sep 21, 2014 | Samsung SMH2117S 2.1 cu. ft....
Sensor pad has short according to the message on the G.E. sensor Microwave Oven
call service or bring oven back to store where u bought it if under one year old...to get it fixed free
Sep 23, 2013 | GE 30" 2.0 cu. ft. Sensor Microwave Oven
The microwave made a loud pop sound when starting to heat up something. Microwave continues to "appear" in working order, but does not heat anything at all. Over the range type. Model: GE Spacemaker...
Home owners should not try to repair there own microwave, you should call a professional to diagnose and repair
always unplug electricity before attempting to repair on any electrical appliance
Sep 21, 2017 | General Electric Ge Profile Profile...
Burnt on stains on the inside glass door of my kitchenaid oven
DeBruce Polish should remove those types of problems and also render the surface more "Cleanable". This stuff really works on glass anomalies.
Check out debrucepolish.com.
DEBRUCE METHOD on You Tube
Apr 11, 2009 | KitchenAid 32 in. KECC508 Electric Cooktop
Cooktops Logo
Top Cooktops Experts
Paul Carew
Are you a Cooktop Expert? Answer questions, earn points and help others
