Question about Tricity Bendix AW1000W Front Load Washer
Tricity bedix spin query
Tricity bendix aw 1053 w washing is still wet after cycle 4 i put it back on spin and it does the job can you help resolve this thanks
  • Tricity Bendix Master
  • 3,463 Answers
First of all make sure you have selected the correct spin speed if there is more than one setting.
Check and make sure prog 4 is mot a delicate wash prog, as it will spin at a lower speed if this is the case.
If it has a filter, locate it and remove to clean.
Plz rate my solution.
Thanks.
Posted on Jan 12, 2009
Tricity bendix washing machine won't work on any of the settings
Hi, mine is the same - it will literally go on forever and it wont seem to ever 'finish' like it wont drain properly either - is it the 800 model? quite and old machine with a button you push in and twist to select the cycle and pull out to turn it on? its just awful it wont give an indication whether its completed any cycle! did you get yours fixed?
Feb 25, 2016 | Tricity Bendix Washing Machines
Tricity Bendix AW1400W Loud noise when spinning
The turning tube's belt or bearing may have problem.
If you know how to tighting the drive belt, you may try.
If not, maintenance or service persone should to call.
May 28, 2017 | Tricity Bendix Washing Machines
Tricity bendix aw 1001 w is not draining,pump and
If you have checked all of these then the only other explanation is that the pump motor is faulty and needs replacing or there is a fault with the wiring or Programmer.
Apr 20, 2010 | Tricity Bendix AW1000W Front Load Washer
Tricity bendix BIW103W spins badly, clothes still too wet.
Hi, Your problem is very common and very easy to fix. You will first need to strip the machine down and remove the motor. Once you have done this then take off the motor carbon brushes, These are the little things in cases on the side of the motor casing. These should be at least 1" long! you will find that this is not the case and they will need replacing to resolve your problem. The parts should not cost anymore than around £20 for the pair.
Good luck any problems get beck to me............................
Mar 18, 2009 | Tricity Bendix WDR1040W Front Load Washer...
Manual spin
This may sound crazy. If your machine looks to be spinning out and draining fine it may be you (NO DISRESPECT INTENDED). I see this alot. Try cutting back to about a tablespoon of "HE' soap. Before doing this run some vinegar thru the wash cycle to clean out the machine.
Jan 26, 2009 | Tricity Bendix AW1000W Front Load Washer
Screw inbetween the drum and the outer shell
if you take the rubber empting tube off the bottom of the drum you can work the screw down to the bottom and out of the hole. ensure all electrics are un plugged obviously.
Jun 14, 2008 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix washing machine AW 1000 W
remove the rear panel 4 screws and you will see it on the lower of the drum.
Feb 09, 2008 | Tricity Bendix AW1000W Front Load Washer
Tricity Bendix 1000 washer
you need to replace the element. remove the rear panel and you can access it
Oct 22, 2007 | Tricity Bendix AW1000W Front Load Washer
My tricity bendix washing machine flashing and beeping end light
Hi, we had something similar happen just before christmas. Our machine seemed to finish a cycle and started making beeping noise with end light flashing. Then when I switched it back on to do another load it just started beeping with end light flashing no matter what cycle was selected. Engineer has been out and advised that it is a fault with the motherboard so has ordered another one. Hope this is of some help. Machine was tricity bendix aw1400w.
Dec 14, 2006 | Tricity Bendix AW1400W Front Load Washer
Tricity Bendix AW1000W Front Load Washer Logo
140 people viewed this question
Top Tricity Bendix Washing Machines Experts
Gerry Harvey
Gerry Harvey
Oloyede Monsuru
Are you a Tricity Bendix Washing Machine Expert? Answer questions, earn points and help others
