Question about Electrolux AWF 1435 Front Load Washer
Electrolux washer says no water, draining and is beeping
3 Suggested Answers
  • 415 Answers
SOURCE: do I need 2" drain for frontload washer?
not nessarily if your draining system can handle a non-efficent washer the old top load style drain 42.3 gal of water evey time it fills and for a complete cyc on the h-3 washer only 14 for a complete cyc. When the unit is in the high spin all of the water is already drained and what little water is spun out of the clothing in nothitng to worry about
Posted on Aug 26, 2009
jnchahn
  • 252 Answers
SOURCE: have electrolux top load washer
It is your clutch on your motor.
Posted on May 07, 2011
E13 error code on my electrolux washer what does it mean
You didn't specify model of your washing machine.
For Electrolux that usually means water leaks (Maximum overall water fill time exceeded (sum of all water fills between one drain phase and the next to avoid exceeding the maximum volume).
Could be:
Drain tube improperly positioned; Water pressure too low;
Water fill solenoid valve faulty; Water circuit on pressure switch is
leaking/clogged; Pressure switch faulty.
Dado
Mar 03, 2017 | Electrolux Washing Machines
Just took my brand new Electrolux front load washer out of the box. Laid it on its back momentarily and noticed some water. Is this normal for a new machine to have this?
Good Afternoon Dodgerfan66, thank you for your post!
I understand that you received a new Electrolux washer and there was water inside of it. It is normal to have some water inside of your washer. Most manufacturers' test product prior to shipment and unfortunately it is difficult to drain every drop of water. I hope this information is helpful. -Matt
Mar 15, 2015 | Electrolux Washing Machines
My Electrolux front load washer does not fill with water in the rise cycle and beeps and displays "draining, no water"
If this is a brand new product, I suggest that you MUST call for warranty assistance from their depot.
This can be related to failure or error of the controller, fault in the inlet or water level sensor which must be done free of cost.
Feb 12, 2013 | Electrolux EIFLW50LIW 4.2 Cu. Ft. Front...
Problem with electrolux washing machine
draining pipe its too low. check this link:
http://applianceguru.com/washers/drain-min.jpg
Aug 26, 2012 | Electrolux Washing Machines
Electrolux washer door won't open
Hi.
Usually the door does not open because there is water inside the tub.
Disconnect power and empty the machine through the drain filter. With Electrolux front-loading washers the drain filter access is located in the front lower side of the machine.
Jun 11, 2012 | Electrolux Washing Machines
Hi Ihave an electrolux EWD 1477 washer/ dryer. It keeps showing up an error 20 (E20) and starts beeping and stops working? Any ideas what it could be? Thanks kindly
Drainage problem. If it is a new installation the possible causes can be:
- The drainage hose is too deep in the drain (can only be max. 10 cm. in the drain, and the drain height may be a minimum of 30cm and a maximum of 80cm from the floor);
The drainage pump may be blocked (clean it);
- The drain is clogged.
You will LOVE Electrolux for this... Go to:http://electrolux.co.uk/en-gb/Support/Troubleshooter/?Command=Detail&CategoryId=98&SymptomId=1412&DetailId=1412
....and click on START ANIMATION for a complete explanation of how you clean the filter on your machine
Jun 23, 2011 | Electrolux Washing Machines
My front loader is not working whirlpool
1 Beep/E10--Error: Water doesn't enter Cause: Water supply problem, Check kinks and faucets
1 Beep/E10--Error: Water leaks Cause: Water connections loose,household drain clog,oversudsing. Correct problems.
1 Beep/E10--Error: Dispenser drawer is open Cause: Washer will not operate if drawer is open.
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
3 Beeps/E30--Error: Drum overfilled. Cause: Inlet valve,pressure switch or control board failure.Select drain/spin to remove water. Restart.
4 Beeps/E40--Error: Door is open. Cause: Washer will not operate if door is open. Close door.
5 Beeps/E50--Error: Motor is overheated. Cause: Wait 30 minutes to cool down. Restart.
7 Beeps/E70--Error: Cold water doesn't enter. Cause: Hoses crossed,faucet problem.
15 Beeps/EF0--Error: Oversudsing. Cause: Too much detergent,or improper detergent for machine.
15 Beeps/EF0--Error: Hot water doesn't enter. Cause: Hoses crossed,faucet problem.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jul 01, 2010 | Whirlpool Duet GHW9150P Front Load Washer
Do I need 2" drain for frontload washer?
Aug 26, 2009 | Electrolux EIFLW55HIW Front Load Washer...
I am having problems with an electrolux 12680 W. PNC 914522501 2007 production yr. It was making a strange sound and not pumping out water. No problem, I removed the front plug and cleaned out around the...
the hose coming from tub to the pump has a filter in it.you need to pull filter out and empty it.E20 means that you have a slow drain,or clog.If the pump is noisier than ussual then you may need to replace pump.but check filter first.
Apr 20, 2009 | Electrolux EW1000i Front Load Washer
Electrolux AWF 1435 Front Load Washer Logo
392 people viewed this question
Top Electrolux Washing Machines Experts
Tim Whalen
Gerry Harvey
Gerry Harvey
Are you an Electrolux Washing Machine Expert? Answer questions, earn points and help others
