Question about Flotec FPP5008 Overhaul Kit
Remove impeller from flotec fp5182-8 - Flotec FPP5008 Overhaul Kit
3 Suggested Answers
  • 104 Answers
SOURCE: finding Flotec impeller for a flotec pump modle FP4012
WW Graingers. Call them with model and serial #s. If you do not have an account with WW, These guys have what ever you need:
http://www.pumpagents.com/partpages/FlotecPumps/FP4012.html
Posted on Feb 07, 2009
h2oservices
  • 306 Answers
SOURCE: I have 2 flotec cyclone pumps. Both need impellers. Where can I get them? I don't need a whole repair kit. Just the impellers.
I believe you can find it at this website.
http://www.pumpagents.com/JabscoPumps/Jabsco-Impeller-Guide.html
Good luck
RJ
Posted on Nov 15, 2011
How do I replace the impeller on a 4022-10 flotec?
separate motor from wet end usually reverse thread on impeller screw then impeller unscrews normally hold back of motor from turning
Jun 10, 2014 | Flotec Pool & Spa
Need a owners manual for flotec pump At251001-01
All you have to do is remove the back cover loosen up the gray contact and hold the shaft with a 7/16 wrench. Scroll down on this website and follow pics. Good luck.
http://www.troublefreepool.com/is-this-impeller-broken-t22383-20.html
Tony
May 23, 2012 | Flotec Pool & Spa
Good luck
RJ
Nov 10, 2011 | Flotec 1/2hp Cyclone Pump
I have a broken sump pump, Flotec model # FPOF360AC
Same pump, same problem. H/D sells the pumps, but no parts. Here's a link to a vendor of Flotec parts. http://www.pumpvendor.com/Flotec_Parts_List.html
Apr 01, 2010 | Flotec Simer/Flotec/Omni 2105 Swimming...
How do I remove the impeller from my Flotec pump?
I called Flotec and they provided perfect instruction. Opportunity solved.
Dec 07, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
How do you remove the motor from a Flotec FPS5172, 1-1/2 HP.
The impeller screws on the motor shaft. First replace the through bolts in the motor. These are the long bolts, they will just cause headachs. On the back of the motor their will be a place to hold the shaft from turning, If you hold the shaft the impeller just unscrews. If you look in the center of the impeller it may have a set screw holding it to the shaft. If you have one of these it will be a left hand screw. Then you will need to break the impeller free as the brass that holds the impeller on will stick to the stainless steel of the shaft. Don't let how tight this is fool you when you put this back together it just goes on hand tight. Good luck
Nov 23, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
My flotec 4/10hp waterfall/utility pump was working fine for about 1 hour, now it's only humming and not pumping any water... ?
Clogged, Impeller loose and not turning. Remove strainer from bottom of pump and check for clogg and see if the impeller is turning.
Sep 21, 2009 | Flotec 4/10 Hp 3000 Gph Waterfall Utility...
Need to replace impeler on flotec pump
Contact flotec directly for impeller tollfree 1-800-365-6832
or they may have been acquired by Pentair so try
PENTAIR WATER
STA-RITE INDUSTRIES
200 Tate Street
Union City, TN 36261-024
(800)-800-468-7867
(FAX)-800-390-53
Feb 19, 2009 | Flotec 1 - 1/2 Sprinkler Pump Composite...
Finding Flotec impeller for a flotec pump modle FP4012
Nov 20, 2008 | Flotec Corrosion Resistant Shallow Well...
Flotec FPP5008 Overhaul Kit Logo
Top Flotec Plumbing Experts
Boyet Soriano
Boyet Soriano
Mike Carew
Are you a Flotec Plumbing Expert? Answer questions, earn points and help others
