Question about Saturn 2008 VUE V6 XR
2008 Saturn vue XR engine code 0496
Fails emissions test in Colorado
SOURCE: 2007 Saturn Vue passlock problem
Take it back to the Saturn Dealer, it is still under warranty.
Posted on Aug 16, 2008
emissionwiz
  • 76691 Answers
SOURCE: service engine soon light on 2003 Saturn Vue
Here is the definition of the code in GM manual:
P0128 - Coolant Thermostat Below Thermostat Regulating Temperature, this indicates the engine is running cold, u need a thermostat
Posted on Feb 12, 2009
rteemon
  • 578 Answers
SOURCE: Service Engine light on Green line 2007 Saturn Vue
take the ground line of the battery and press the brake for a few minutes and if the life is still on have the vehicle scann and clear code and have the emission components for the vehicle check
Posted on Sep 12, 2009
  • 39 Answers
SOURCE: 2003 saturn vue trouble code p1599
P1599 IS A STALLING ISSUE COULD BE BAD GAS / BAD FUELPUMP DIRTY FUEL FILTER
DISCONNECT BATTERY AND SEE IF THE LIGHT COMES ON AGAIN
U2107 HAS SOMETHING TO DO WITH THE COMPUTER LOOSING POWER AT THE BODY MOUNTS CHECK CABLES AND GROUND STRAP
Posted on Mar 02, 2010
SOURCE: remote start dont work in 2008 saturn vue and its
The hood latch has a switch in it. The hood latch does not move the entire distance when the hood is closed and the switch does not close so remote start will not work. Everthing else appears to be OK. I have had two hood latch replacements on my 2008.
Posted on Nov 11, 2010
How to remove the alternator from the engine compartment in a 2008 Saturn Vue XR?
https://s26.postimg.org/7hk4posg9/generator_1.jpg
Click on the link. Hope it helps.
After the gen is loose, you may have to turn it different ways to work it out of there.
Sep 14, 2017 | Saturn Cars & Trucks
Slow to start after fueling / also what is po496 code
code p 0496 refers to evaporative emission system-high purge flow===causes --wiring---EVAP valve ---mechanical fault
there is no accelerator pump in an EFI vehicle so pumping the pedal is a useless exercise
the accelerator pedal position sensor just tells the throttle position sensor when to put the throttle plate but the information is relayed to the ECM to set up the fault code
Sep 04, 2015 | 2003 Saturn VUE
When to replace 2008 saturn timing chain
Whenever manufacturer recommends. If the "chain"
[actually a belt] breaks, the valves punch thru the pistons. This because the cam doesn't let them get out of the way.
May 24, 2015 | Saturn 2008 VUE V6 XR
Had my car checked because engine light was on came up with PO496 What does this mean?
code p0496 refers to evaporative emission system--high purge flow===causes--wiring--EVAP valve--mechanical fault
check that the cap is on tight
change the purge valve.
Mar 11, 2015 | 2008 Saturn VUE
Failed emissions test
First step is to have the code or codes read.If the "check engine light" is on there will be a reason and should be a code or codes to be read.Once you have the codes,you can determine the correction needed to get that "check engine light" out and a valid emissions test completed.Get back to us with the codes found.
Apr 28, 2017 | Saturn Vue Cars & Trucks
Hello! I have a 2008 Saturn Vue...at the dealership (GMC) for two days. They said the emissions purge valve is broken but the error code and check engine light have gone off. I'm also at 37,000 miles and...
first dont worry you can buy the part for 31 dollars at the dealer 23 other places part number 214-2230 ac delco and all you have to do is pull it out un plug the wires and push the new one in plug the wires back in figure to have some one do it hour labor 100 dollars and 50 for the part it wont take an hour but expect to get charged an hour cause other wise its a job not worth doing like an oil change
Feb 22, 2011 | 2008 Saturn VUE
Sep 11, 2009 | 2007 Saturn VUE Green Line
Saturn 2008 VUE V6 XR Logo
Top Saturn Heating & Cooling Experts
Tom Chichester
Hank O
Level 1 Expert
David Ellis Rhea
Are you a Saturn Heating and Cooling Expert? Answer questions, earn points and help others
