Question about Ariston Technologies Ariston FO98P Stainless Steel Electric Single Oven
The oven won't workeverything looks okay but a red key appaeared
I tried turniing it off and on, holding down the child lock looked through the manual but nowhere does it show a picture of the red key just beside the blue bit by the mode bit the red key appears over the time energy box everything seems to be okay but the oven won't start can't get any reaction from the buttons, anybody got a clue
How do I unlock my oven on an edesa electric oven? I've tried turning the electric on & off on the trip switch but this doesn't resolve the problem
Sounds like the child lock is activated.
Have a look in your manual, I can't help any further as you do not divulge type and maker.
Jul 18, 2017 | Ovens
When I try to turn my oven on, it says LOC. I don't know how this happened or how to reset it. Stove was in the house when we bought it a few months ago.
That message is normally visible when cleaning the oven at high temp. Or it is the child lock. Did the owners ask if you wanted to buy it and you said "No thanks" :>)
Try removing the power plug at the back for 30 seconds and reconnect. If that doesn't work Google
make model manual
Removing the child lock often just involves holding two or three keys for a few seconds.
Apr 22, 2016 | Ovens
I have a Bosch oven with the "key" sign constantly lit and the oven won't function at all. Re set it at wall etc.
the key sign shows that the child lock is engaged. to unlock, usually you push and hold the lock button for a few seconds. the correct button is usually a dual function and so marked. if you need more help, go to manualsonline.com and look up your model number for your manual. good luck
Dec 27, 2015 | Bosch Ovens
Why is it showing a key symbol, an error code f10 and the door is locked?
usually a key symbol means that the appliance is safety locked. usually by holding down a button for 3-5 seconds to lock and holding down the same button to unlock. a child lock safety feature.
Jul 20, 2015 | Gaggenau EB 270/271 Electric Single Oven
I get a red lock and cant use my oven.
Depends on your brand, but look in your owners manual and follow the instructions on getting it out of "Child Lock".
Mar 17, 2015 | Ovens
My zanuzzi inbuilt ovn model zob k92 qx product number 949711644 has gone in to safe mode , do you know how to get it to work again ?
The child safety function
In order to avoid that children engage oven, it is possible to lock the oven controls. Press the two keys (as shown) and hold them for at least 3 seconds. The beep and "SAFE" on the display indicates that the child safety function is activated and it is not possible to select the temperature or a function of the oven.
To unlock the oven press the two keys (as shown) and hold them for at least 3 seconds. You will heard beep and indication "SAFE" will be disappear. Now you can operate the oven.
Dado
Feb 22, 2015 | Zanussi Ovens
Bottom oven stopped working there is a key symbol showing on the panel what is wrong ?
There are a few reasons for this. One is the most obvious and that is the child lock switch needs to be engaged to unlock.Some models call it panel lock.
Turning the panel lock on and off:
To turn the panel lock on, press and hold the Panel Lock key for four seconds. The Panel Lock symbol will appear in the display.
To turn the panel lock off, press and hold the Panel Lock key for four seconds. The message in the display will disappear.
Oct 04, 2014 | Bosch HBL 5056 Electric Double Oven
CHILDLOCK WONT SWITCH OFF ON BOSCH OVEN
Aug 05, 2014 | Bosch Ovens
Child lock code -5- has appeared.
Here is what worked for me.
Turn left to light on, then off
on/off (light)
on/off
on/off
(4-5 times)
do not run through the complete cycle of options
just to the light and back off.
Ken
Aug 16, 2008 | Neff U1661 Double circotherm super...
Ariston Technologies Ariston FO98P Stainless Steel Electric Single Oven Logo
47 people viewed this question
Top Ariston Technologies Ovens Experts
ashburton
Dan Webster
Dan Webster
Are you an Ariston Technologies Oven Expert? Answer questions, earn points and help others
