Question about Canon PIXMA MX310 All-In-One Printer
Have never been able to set up fax
My adult son and I each tried to set up fax using the manual--it never worked. Now, I've just moved and can't find the manual, but I NEED the fax! Can you tell me how to set it up, or direct me to understandable instructions?
  • kandysansom Jan 13, 2009
    I need the entire set-up procedure for the fax from start to finish, both sending and receiving.
    I have no idea how to begin--it was several months ago when I gave up on it. I've moved to an area where I have to pay $1.20/page for a fax. I have about 20 pages right now that I need to send,etc.etc...Can you first just get me started on the right track??
    Sergeant:
  • 221 Answers
 basically, you run a phone cable from your wall to the line port on the printer, you can run a line from the phone port to an analog phone if you choose. You put your job face down or up on the printer to scan, dial your number, and hit send.
Some complications:
  1. You may need to dial 9 to get out on a company network.
  2. Digital phone systems, DSL, and IP phones don't play well with Fax lines.
  3. In an All-In-One solution, you may have to hit a FAX button to be in "Fax mode
also:-------# Press the <FAX> button to enter Fax mode.
# Press <Menu>.
# Press the right or left arrow button to select [Receive mode settings], then press the <OK> button.
# Press the up or down arrow to select the receive mode that best suits your needs(you probably want "FAX ONLY" When you want to receive only faxes automatically with your machine, or have a dedicated telephone line for FAX use only), then press <OK>.
# Press <Stop/Reset> repeatedly to return to fax standby mode. also set :--------Try setting your fax machine to DRPD (distinctive ring pattern detection) -Press menu > receive mode settings > ok > scroll down to DRPD > ok > back
thanks.
Posted on Jan 12, 2009
  • Canon Master
  • 19,396 Answers
To set the fax install all software, then open Start >> Program >> Canon >> Printer tools and set the fax.
on how to install the software see:
How can I install the InkJet Multifunctional driver and software for Windows Vista?
Regarding connections do the following:
Connect Wall Socket to line socked (with L
) on Fax machine
Connect External phone socket (the one with a picture of a phone) to phone handset.
The rest of setup is quite straightforward.
Regarding the manual, that is not available online, here is manual for MX300, that has exactly same functionalities.Check from page 32 and follow step by step instructions:
Quick Start Guide.
    Brigadier General:
  • 5,158 Answers
What exactly is not working for you... and i presume that you have plugged the phone line in the proper hole... some people mistakenly plug it into the usb port
  • 10,515 Answers
    Genius:
  • 2,920 Answers
What all do you need to know?
Hi I've just got my son a relisys tv model
I thought they only made computer monitors, but you are right they make televisions as well.
relisys tv model Google Search
Apr 01, 2017 | Video Game Consoles & Games
Are there special toddler beds just for boys? I'm moving my son out of his crib soon and wanted to make it fun for him.
Toddler beds are really just a mini version of our adult beds. But you can definitely buy themed beds these days and get your son something very funky if you have the budget. Check out this website that sells themed beds and has some really fun ideas for boys. http://www.toddlerbeds.com/themed-toddler-beds/971+4295112676.cfm
Aug 14, 2012 | Baby Gear
Unable to receive fax on 4100e
Sorry, but you have to be more specific on what are you trying to achieve and what you have done so far.
Do you want the unit to automatically answer a call and receive the fax? If so, make sure that you have switched it to FAX mode (press the MODE button repeatedly until FAX is shown on the display). You can also set it to FAX/TEL mode, whereby the machine will answer the calls and signal (ring) if it is a voice call not a fax.
The default setting is for the machine to answer after 4 rings, refer to the manual if you want to change this value (you can download the manual here: http://welcome.solutions.brother.com/BSC/public/files/dlf/doc002079/FAX4100e_UsaEngUsr_B.pdf
If you want to manually receive a fax after you've picked the phone up yourself, then when you hear the other side fax beeping, simply press the START button.
Jul 21, 2011 | Brother IntelliFax-4100e Fax
I have a B&L Model 4000 ,which I've never used, but wish to use it now w/my son;I need the instruction manual, which I dont have...can I access a copy via email or fax, or whatever? Thanx
No this scope is no longer manufactured-- sorry. However it is called an SCT like the one on this page:
http://www.telescope-service.com/Celestron/SCT/SCT.html
Jun 13, 2011 | Optics
How do we change the date on the fax machine? Someone has walked off with our manual
Hi there!
You can follow these steps to set the date:
1. Press the right navigation key and press 7.
You should see "SET MODE 1-8" "ENTER NO. OR "V ^"
2. Press 1 for
You should see "1. User Parameters?" "PRESS SET TO SELECT"
3. Press Copy/Set Key
You should see "DATE & TIME" DD-MM-YYYY HH:MM
4. Enter the new Date & Time. You can use the dial pad to enter the values & move the cursor using the navigation keys. If you make a mistake, use to move the cursor over the incorrect number, then overwrite it with a correct one.
5. Press copy/set Key then press the STOP Key
Hope this helps! Please rate if it worked.
Thanks
You can also download the manual here: http://www.retrevo.com/search/v2/jsp/mytrevo/myTrevo.jsp?page=man
Hope this helps
Mar 30, 2011 | Panasonic UF-590 Plain Paper Laser Fax
Wont accept faxes
Sounds silly, but since you moved have you updated your phone number with those who are faxing? Are you sure the phone line is plugged into the correct jack? Have you tried calling the number yourself? Does it ring? Have you tried manually answering? Do you have DSL- are you using the proper filter??
Dec 31, 2008 | Brother Multi-Function Center MFC-240C...
Faxes sent from PC do not delete from print queue.
its in the fax preferences option...on the fax icon right click and go to properties..somwhere in the preferences should be an option to select automatically delete sen faxes..or something like that.
Aug 30, 2007 | Brother IntelliFAX 5750e Laser Fax
How to use seat belt with seat
Here is the link to the product page for the seat; http://www.evenflo.com/Default.aspx?tabid=203&productid=2b49c217-5716-4e6a-bf7a-0895dd0fe596 click on "demo" and you get a few videos showing how to install etc. Check this link for FAQs about the model; https://plweb.evenflo.com/faqs.aspx?catid=9&subcatid=806 and this link for the full user manual; https://plweb.evenflo.com/replacement_parts.aspx Basically what evenflo say is that if you can't teach the child not to climb out, you need a different type of booster with a traditional restraint. if thrown forward as described the belt should function as usual for an adult, assuming the belt is correctly positioned on the child. Contact evenflo on; http://www.evenflo.com/Home/ContactUs/tabid/175/Default.aspx if you have any doubts at all. They can also point you towards a qualified installer who can verify the safety or otherwise of your setup. Sorry if not great news, hope it helps keep your son safe :)
Jun 27, 2007 | Evenflo Big Kid Deluxe - Fairbanks
Resetting the phone number currently displayed on the top of the page
It is called 'Station ID', press Menu/Set 1 then 3 then put in your number.
Jan 24, 2007 | Brother FAX-575 Plain Paper Thermal
Canon PIXMA MX310 All-In-One Printer Logo
20 people viewed this question
old marine
old marine
