How do i open the door on a indesit iwme126 - Washing Machines
2 Suggested Answers
  • 6277 Answers
SOURCE: I can not take the
The following I pre-typed for another problem but contains the answer in the second option- I had great difficulty removing the tray when we borrowed our daughter's Indesit! It is necessary to actually watch what is happening from underneath the tray ;-0)
Follow the rest of the instructions on a regular basis and the softener will always be siphoned into your washer.
Remove the complete drawer. To do this you will have to do one of the following-
  • Top catch- push down the lip/catch at the middle rear and pull the drawer out (that's how our Bosch one is removed)
  • release the catches underneath (our daughter's Indesit) or
  • lift upwards on the tray as it is coming out to clear the lip underneath.
Once out identify which tray is for the conditioner- the others are simply 'chutes' and open-ended.
It will normally have some sort of cover over it which you must remove to expose the little stuck up pipe/tube. On some models there is just a small individual cap over the tube but on others the cover is part of the tray's plastic top. The tube is down which the conditioner and water should siphon. It is likely to be blocked by 'gunge'- a mix of powder and conditioner. The whole of the tray, particularly this pipe and the bit which fits over it, must be completely clean and clear for it to operate correctly. It is worthwhile checking fairly regularly.
If this has assisted you please consider a 4 thumbs up for the rating.
Thanks and good luck!
John C
Posted on Aug 22, 2011
Indesit model iwe7125b problem f06 what does it means?
F06 : DOOR LOCK fails to close/open, door lock triac open/closed, frequency signal fault.
Action: Switch off the device. Disconnect power. Wait about 3 minutes. Open the door, then close, reconnect device to the network. Start device
Dado
Dec 20, 2014 | Indesit Washing Machines
Indesit washing machine wie167 the word door came flashing up, the cycle has stuck and the door wont open
Ok the machine needs to be drained. Then switch the machine on again. The door should open.
Oct 06, 2012 | Indesit Door Handle Kit for W123, W133,...
I can not take the detergent drawer out to clean it out of my new indesit washing machine IWME126
John C
Aug 22, 2011 | Indesit W 123 Front Load Washer
The door handle on my Indesit W83 just broke off and I can't open the door... Any tips for getting my clothes out?? :/
same thing happened to me with my indesit w10.....so now i have touse a screwdriver to lever the door open (could always buy another handle, but hey...).
there should be a hole where the handle would lever the metal catch open...stick a screwdriver / spoon in there and lever it open...there's a technique to it but have a play around, you'll work it out... its easy enough!
Jun 27, 2010 | Indesit W 83
WASHING MACHINE WONT DRAIN OR SPIN
did you get a solution as i now have this problem
Jun 08, 2010 | Washing Machines
The door on my indesit wd12x washer dryer will not open. The machine has finished the cycle and was on the tumble dry mode when it finished. The handle feels loose like a spring has sprung. Any...
slide in a piece of string around the door. if lock is on the right, pull round the door til the pieces of string are at left of the door and pull left quite firmly.
Oct 17, 2008 | Washing Machines
Fixing broken door lock of Indesit W123X washing Machine
no easy way to open
disconnect from mains
take top off. feel down the front to where the door lock is and see if you can feel the door peg sticking thro the door interlock. force this with your fingers and with luck the door will open
if can't do this way, break handle off and lever peg with a small screwdriver
you can buy a handle kit complete. fitting this is not difficult - split the door and all will be revealed advise you make a carefull note of where springs go etc before you start stripping it down or take a few fotos if you have a digicam
Jul 10, 2008 | Indesit W 123 Front Load Washer
Washing Machines Logo
181 people viewed this question
Top Washing Machines Experts
