Question about Vizio VW32L 32 in. LCD HDTV
Screw size for vizio vw32l hdtv20A - Vizio VW32L 32 in. LCD HDTV
5 Suggested Answers
drumbanger
  • 1199 Answers
SOURCE: VIZIO VW32L HDTV20A Cracked screen.
unless you have experiance in ekectronics i would not attempt this fix myself! and with the parts and labor added up it very well be cheaper to replace it! hdts are at an all time low right now!
Posted on Dec 11, 2008
  • 7 Answers
This can be replaced. You can do it yourself. Find the new screen, take the old unit apart and switch parts and remember the connections you undo to reconnect the new screen to the casing.
Posted on Jan 13, 2009
rylee_smith
  • 8619 Answers
SOURCE: my vizio vw32l hdtv20a no
Hi
Thanks for using FixYa. From what you have described it seems the issue is with the power board or the main board and we’ll need to check few things. When you open the unit up; take a look at the power board-the board where the power cords/plugs goes into. You might see some filter capacitors a little bulged up in the top-If this is the case-this is your defective part(you can try to replace them-but some soldering equipment is needed). If not, then probably the main board has gone bad. This is the other board-where all the inputs are going into. All this is only recommended if you have electrical expertise and know how to solder/re-solder components. Please note that the TV components consists high voltages even when in off position. Please do accept the solution if the issue is resolved or post a comment for further assistance.
Thanks
Rylee
Posted on Aug 28, 2010
SOURCE: vizio vw32L-HDTV20A-NO POWER :fuse and q101 q102
You can find these fuses at the Littlefuse web site and look for Part Number: 0215008 it will also give a list of distributers like Newark where you can buy them on line for about $1.00 each.
Posted on Nov 08, 2010
Anyone fixed a Vizio VP50 HDTV20A?
Possible T-CON PCB or a burnt out display module.
Oct 31, 2016 | Vizio Televison & Video
Why my tv won't come on? it's plugged inand no light or any thing is happening
Salvador, Could be a internal board issue or power supply, Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Official VIZIO Support
Fix Power Problems In 5 Easy Steps What To Do When Your Vizio TV Wont...
https://answers.yahoo.com/question/index?qid=20120504055328AAiBGKi
Oct 28, 2015 | Vizio Sanyo, Ssi320wf12 / Vw32l Hdtv10a...
Can't remove tv stand from vizio p50 hdtv20A
You have to unscrew the stand from the set, the screws are on the back. I believe there are a total of 8 screws. You will then have to lift the set off of the stand.
Dec 06, 2012 | Televison & Video
Its a VW32L HDTV40A how do i take the back cover off. And is there anything i should watch out for ?
screws all around the outside of the TV can be removed with Phillips screw driver, usually can leave it standing, but depending on the model, some of the stands need to be removed on the Vizio TV's.
Keep your screws organized so you know where to put them when you put it back together.
remove all the screws on the solid back piece, and it should pop right off.
Be sure to have it unplugged for quite a while before working on it, capacitors can hold charge that will give you a good shock..
Jun 07, 2011 | Vizio VW32L 32 in. LCD HDTV
Vizio vw32L-HDTV20A-NO POWER :fuse and q101 q102 bad
Oct 13, 2010 | Vizio L32 32 in. LCD HDTV
Pic size on vw32l cuts off top
you have to bring up the onscreen menu by hitting menu button then go into dettings, this should help,let me know if it works
May 19, 2009 | Vizio VW32L 32 in. LCD HDTV
Dec 11, 2008 | Vizio P2 42 in. HD-Ready Plasma Television
I have checked with my distributor of Vizio parts and the panel isnot offered as a replacement part. It may be available to authorized service centers. Call an authorized service center and inquire. Be prepared to find that the replacement panel cost may be close to a replacement set cost.
Dan
Dec 04, 2008 | Vizio L32 32 in. LCD HDTV
Vizio VW32L 32 in. LCD HDTV Logo
Top Vizio Televison & Video Experts
CoppellTVRepair.com
Computer Repairing
Computer Repairing
Are you a Vizio Televison and Video Expert? Answer questions, earn points and help others
