Question about Tivo DirectTV Remote Remote Control
Westinghouse TV goes to setup when tivo remote FF Button pushed
2 Suggested Answers
  • 1335 Answers
SOURCE: I need to program my tivo remot to use with a
you can key in your units and get the most likely codes at
http://www.directv.com/DTVAPP/global/contentPageIF.jsp?assetId=P4380036#h:620.480
Posted on Nov 03, 2009
Westinghouse Setup wizard
westinghouse will not work with an APPLE remote
Jun 09, 2013 | Westinghouse Televison & Video
I can't link this remote from Comcast /Xfinity to my Westinghouse TV model EW24T7EW. Dose anyone know the codes as I tried pushing setup button and it blinks twice on tv and then I have tried (0000, 0
Some are 4-Digit and some are three Digit codes. I couldn't read all the codes you listed in the video description. I assume that these Comcast codes work for all Westinghouse model numbers. Hope this helped.
Sep 27, 2012 | Televison & Video
Need 4 digit remote code for LG LV5500 led Tv to input into TIVO remote as it's not listed in the TIVO library
Hello
Just do a code search process, and see whether it can help you. As there is no codes listed for LG with Tivo remote, this is the only thing to get it. If this does not help you to get any code, there is no other way than buying an other universal remote, which has codes listed for LG.
Code search process
If after trying "Direct Code Entry" your device does not respond, or if your brand is not listed, try doing a search of the code library for your code by following these steps.
  1. Manually turn on the device (TV, VCR, etc.) to be controlled.
  2. Press and hold the SETUP button until the red indicator stays on, then release the SETUP button.
  3. Press and release the desired Mode button (TV, VCR, etc.). The red indicator blinks once, then stays on.
  4. Press the CHANNEL UP button repeatedly (up to 300 times) until the device to be controlled changes channel. The red indicator blinks, then stays lit.
  5. Press and release MUTE to install the code. The indicator light goes off.
Most users will want to store VCR codes under the VCR button, Cable codes under CBL, etc. If you want to store a VCR code under CBL, etc., first follow the procedure for Direct Code Entry and press CBL in step 2 of Direct Code Entry, then enter ANY VCR code in step 3 of Direct Code Entry. Then follow the steps above for Code Search.
OK.
Oct 08, 2011 | Televison & Video
I need a remote code for an Olevia 232 s13 that will work for TIVO Premier Remote Control.
Hi
Please check this code 11610, if it works.
Please get back to us if you have further query or else please accept the solution.
Thanks for contacting fixya.com
Sep 11, 2011 | Televison & Video
Need code to use for the tivo remote
Push the TiVo button on the remote. Then push "Messages and Settings," followed by "Settings," and finally press "Remote Control." This will show you the three areas of the remote that are programmable. "TV Power, Volume and Mute," is one section. "AV Volume and Mute," is the second section. The final section is "TV Input."
Pick "TV Power, Volume, and Mute" by pushing right on the direction pad of the remote. This will open up a list of all the brand names of TV that exist. You will find most TV brands will be there.
Find your brand of television and select that option. If your brand is not there, simply go to the TiVo webpage and under "Setup and Support" you will find others who have experience this issue. There you will find a code for your TV. This happens sometimes when the TV is a lesser known brand.
Hold down the button you are programming (i.e. TV Power) for 5 seconds until the red light on top stays on. Then enter one of the codes on the screen.
Push the newly programmable button to test its functionality. If it does not work, repeat the steps with all the possible codes available. One of the codes will work.
Push "Live TV" at this point to watch television.
Use the manual which came with your TiVo in addition to this guide. In the front of the booklet will be a starter guide, which will lead you through the steps necessary to set up your remote for optimum use.
Mar 23, 2011 | Televison & Video
Comcast Remote requires 3 digits be entered to change channels
l. Push the "Menu button"
2. Push the "Menu button" again
3. Scroll to "Setup" and push "OK"
4. Scroll to "Guide setup" and push "OK"
5. Scroll to"No Auto Tune"
6. Click on arrow next to "No Auto Tune". This will change it to "Auto Tune".
7. Now exit, or just punch in any channel number.
You should now be able to go directly to a channel without entering zeros.
Nov 23, 2008 | Philips Tivo HDR812 80-Hours Video...
Tivo DirecTV Remote-Program AKAI LCT2721AD
Try this: On the Tivo remote press and hold the TV Power button and the Directv/TIVO button at the same time. Hold both buttons down for about 4 seconds or until remote light stays red. Then press the channel up button until the tv turns off. You may press the button over 100 times. You need to go slow. When the TV turns off press the enter button (or select button).
Dec 09, 2007 | Tivo DirectTV Remote Remote Control
Remote control code for westinghouse sk-19h210s television
I just tried a Sony code for my Westinghouse tv after reading other sites, and it worked. The code that worked for me was 10000
Oct 21, 2007 | Televison & Video
Tivo DirectTV Remote Remote Control Logo
19 people viewed this question
Top Tivo Televison & Video Experts
Henry  Thomas
Henry Thomas
Computer Repairing
Computer Repairing
Are you a Tivo Televison and Video Expert? Answer questions, earn points and help others
