Question about Nintendo Wii Console
My wii is on standby mode (red light and blinking) and i cannot get it to go on (green light) it is a brand new wii and i have made sure that all the connections are correct!! plz help!!!
  • 344 Answers
The red light should NOT be blinking. Disconnect ALL of the wires for a few hours. I mean everything. Unplug the the power adapter from the wall and everything. about 3-6 hours later plug everything back in and try to power it up. If it doesn't work you need to contact Nintendo before your warranty runs out. Or you may be able to just take it back to the store where you purchased it. Good luck and thanks!
Posted on Jan 13, 2009
I buy new then i pluged power socket my progector indicat red light i start standby butten the progector return standbay mode and red light bliking
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices. http://electronicshelponline.blogspot.com/
Blinking codes details of many popular brand TVs are given. Surf the site with patience. If blinks continue without any pause, the main board is faulty.
Dec 02, 2015 | Televison & Video
Tv power on red standby red light then flashing green light ??
Aug 31, 2015 | Televison & Video
Green light flashes back red
These blinks [flashes] are fault indication (Error Codes).From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it.This will make repair easy.These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times.Count it carefully.If you wish to get some details, check the site linked here.It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.http://electronicshelponline.blogspot.com/
Blinking codes details to many popular brand TVs are given.Surf the site with patience.
Sep 22, 2014 | Sylvania LC420SS8 LCD TV
Why is screen not working? Red and green light both blinking?
Blinking codes details to many popular brand TVs are given. Surf the site with patience.
Sep 18, 2014 | Fujitsu Plasmavision P42VCA30EH 42 in....
Sony KDF-42WE655 Won't power on. Red Power/Standby light blinks 5 times
These blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit stage inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power led, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating, to many popular brand TVs and other devices. Viewing it in "Mosaic" will make surf easy.
Mar 21, 2014 | Sony Grand WEGA KDF-42WE655 42" Rear...
Runco flat panel tv displays solid green then blinking red light. What doe this mean?
How many times this standby/power light blinks at one time switch ON? Count it carefully. These blinks are fault indication, and known as blinking codes. From the number of blinks occur at one time switch ON; you can get an idea about the faulty circuit stage inside the TV. This will make repair easy. For more information, check the link http://electronicshelponline.blogspot.com/
Nov 14, 2013 | Runco Televison & Video
The "on" light is always green, even if turned off. Why?
It occurs when your wii in the Standby, but WiiConnect24 is enabled with Standby Connection is enabled. the content can also be received when the Wii is left in standby mode.
WiiConnect24 can be turned on or off via the setup setting. While the console is in standby, the power LED indicates the current status of the standby connection,
  • Red indicating Standby - wiiConnect is off,
  • Yellow indicating Standby - Connect mode is on. If you hold the power button for 3-4 seconds, the Wii goes into standby mode with Standby Connect off. and WiiConnect24 will not operate until the console is turned on.
  • Green ...
Jan 18, 2010 | Nintendo Wii Console
I just put the internet on my wii and now when i turn my wii off the light is yellow, not red, and the area where you put the disc in keeps blinking blue.
This is because you have wiiconnect24 turned on. wiiconnect24 keeps your wii in a standby mode so that you can receive messages when you are not playing the wii. When the disc tray is blinking blue this means you have a new message. If you want to turn wiiconnect24 off go into the wii settings menu then wiiconnect24. If you just want to turn the wii off fully then when you want to turn the wii off hold the power button on the wii down until it turns red.
Dec 30, 2009 | Nintendo Wii Console
No picture and no sound
Those blinks [flashes] are fault indication (Error Codes). From the number of blinks occur at one time switch ON, you can get an idea about the faulty circuit section inside it. This will make repair easy. These are called blinking codes. Make sure about the exact number of blinking of the standby/power LED, by switching On & OFF the set, for at least two times. Count it carefully. If you wish to get some details, check the site linked here. It has details about blinking codes, and fault locating procedure, to many popular brand TVs and other devices.
http://electro-medical.blogspot.com/
http://homenol.blogspot.com/
Mar 11, 2017 | Samsung Televison & Video
Nintendo Wii Console Logo
90 people viewed this question
Top Nintendo Video Game Consoles & Games Experts
Bee Santiago
Raj Patel
Julian Wainwright
Are you a Nintendo Video Game Console and Game Expert? Answer questions, earn points and help others
