Question about Miele Dishwashers
My Miele G1220 dishwasher has emptied onto my floor twice. F24, F40 and F70 have appeared when I've tried various programmes. Is this a fault I can fix myself?
Machine has emptied onto floor twice. F24, F40 & F70 have appeared when trying different programmes. Can I fix this fault myself?
  • 177 Answers
SOURCE: F70 fault error keeps appearing on my Miele
it is the float switch in the base of the unit, which registers a water leak. you are probably using too much detergent and it is overflowing into the base.
Posted on Jan 19, 2010
  • 177 Answers
SOURCE: fault code f70, drain pump keeps running, nothing else works
Yes. F70 is a flood in the base of the unit which activates the float switch and constantly activates the drain pump until the water has gone. Isolate the unit at the power switch and remove the bottom panel under the door panel. Dry up the water as best possible with a towel. You will see the float at the front. Run the unit again and check for any water leaks. You may just have over sudded the unit with too much detergent. Only use 2 teaspoons of powder. To start with while testing don't use any detergent. Good luck
Hope this helps.
Posted on Jan 25, 2010
  • 70 Answers
SOURCE: miele dishwasher had F85 on the screen
Hi
On that model to save water and energy water is sent to bottom and middle spray arms alternately. This is done via a shutter in the circulation motor. F85 mean this shutter is jammed,Most likely with debris,But is possible motor is faulty
Posted on Apr 28, 2010
  • 1416 Answers
SOURCE: What does the fault F70
hello,
The code is an indication of a problem on the washer
F67 means the input voltage on the microprocessor is incorrect. Code F70 indicates a problem with the water temperature sensor circuit. F76 means the NTC temperature for the cold water valve is over the limits.
thanks.
Posted on Oct 26, 2010
ginko
  • 19396 Answers
SOURCE: on my miele dishwasher G1220
Hi.
The slide shutter is part of the circulation pump assembly. Disconnect pump and check for blockage at pump hose. If that does not help replace the circulation pump.
Regards.
Ginko.
Posted on Feb 19, 2011
F70 plus not draining completely
check for obstructions in the pump, the hose and the drain.
Sep 25, 2012 | Miele Dishwashers
How to fix leak in miele dish washer g1202 svi has F70 fault and small leak into catch pan
The reason the pump keeps running when F70 fualt appears is that the water leak circuit has tripped which causes the dishwasher controller to empty the dishwasher to avoid flooding of the motor and pump area.
The sources of leaks could be many, to start with hoses and water inlet valve. If you feel you can handle such repairs then go ahead otherwise call a technician.
Make sure the mains power is turned off when you are working with the dishwasher internals.
Aug 10, 2012 | Miele Dishwashers
Miele g1220 dishwasher displaying F14
In my case, F14 appeared when the waste pump was not be able to exctract the waste liquids. This happened because lemon kernels (that I use to remove bad smells) has clog the non return valve and the circulation pump passage way. I followed the directions from manual to clean the valve. I found about 30 lemon kernels on the bottom of the dishwasher. After the kernels removal and valve cleaning and refitting, my dishwasher operated as usual.
Mar 11, 2012 | Dishwashers
Flashing F40
I'm sorry to say that this is a controller problem.
The program is interrupted and the drain pump is operated. The display shows. If you have a full alphanumeric display it will show Technical fault F40. Call the Service Department. The buzzer is activated for 2 minutes.
Cause:
The controller has a fault that cannot be repaired by the service department
Remedy:
Replace the controller.
Jul 26, 2011 | Miele Dishwashers
What does F24 mean on my Miele dishwasher readout?
f24 is no signal from the heater relay. at the start of a cycle the dishwasher runs the drain pump for 30 seconds. it will, at the same time send a power signal to the heater relay. if the computer doesnt see a signal back from the relay, it will stop the cycle and beep. Sometimes this happens almost as soon as you press the start button. Sometimes the relays are just bad, but it is usually caused by a voltage spike, or by using too much detergent. the excess detergent will oversuds the machine, and leak into the bottom pan. the soap will corrode the contacts on the relay and cause the f24 fault. the relay can be accessed by removing the bottom pan of the dishwasher with 4 t20 screws. it requires that the dishwasher be turned on its side.
Nov 19, 2010 | Miele Dishwashers
What does the fault F70 mean for a Miele G 1534 Sci dishwasher, please?
hello,
thanks.
Oct 26, 2010 | Dishwashers
Miele dishwasher had F85 on the screen
Hi
Apr 28, 2010 | Miele Premier-Plus Built-in Dishwasher
F70 fault error keeps appearing on my Miele G1220SC full dishwasher - any idea?
Oct 31, 2009 | Zanussi 24 in. DE6850 Free-standing...
F84 Error code Miele
This problem arises because the water inside the washer cannot get out.
Firstly......Make sure the salt cover if screwed on tightly (if you have one).
Then remove the filter(s) from bottom of the washer and clean.
Remove the drain pump cover and remove the one way valve (a ball bearing in a housing) and clean. Take note of rubber cover direction before pulling it out to clean.
Make sure the impeller (visible after you remove drain pump cover) is clean and spins ok. It will have a little resistance as you spin with your finger.
Make sure all is cleaned properly and it will all work fine again after replacing it all back in.
Jul 27, 2008 | Miele Premier-Plus Built-in Dishwasher
Dishwashers Logo
32 people viewed this question
Top Miele Dishwashers Experts
Mike
Are you a Miele Dishwasher Expert? Answer questions, earn points and help others
