Question about Pacific Image PrimeFilm 2700 Film Scanner
2700 dpi Film Scanner diver - Pacific Image PrimeFilm 2700 Film Scanner
My PC only recognises this machine as a scanner not an all in one printer
download the correct divers for the machine and your problem will be solved
Dec 12, 2015 | Ricoh Aficio SP 204SN All-in-One Laser...
I have printer plus scanner epson l200. and I thought there is option for scanning a film. but it turned out the option is greyed out. I wonder if this type is available for scanning film or there is
To scan film, your scanner needs a light above the film. Not just a light, but a calibrated light. That is why the scanners who can scan film and transparent sheets, have a lit with a light in it. Your scanner does not have this, so scanning film is not possible. One of the cheapest (flat bed) scanners from Epson is the V600 and costs about $200, Epson Perfection V600 Photo Scanner
Feb 04, 2015 | Epson L200 All-in-One Inkjet Printer 27...
Code 2, 189,0
All scanners come with the scanning head locked to prevent damage to it during shipping. On the back of the scanner, where the power cord and wires connect, there will be a sliding switch, sometimes a turning type lock, with two positions, one with the icon of a closed [so locked] padlock and the other with the icon of a open [so unlocked] padlock. Every scanner I have bought describes this lock in the setup manual.
Oct 17, 2014 | Canon CanoScan 9000F Mark II Color Image...
Scanning Size
Do not try to change the scan size, change the resolution. The window that appears when you want to scan should have a resolution (DPI) area that can be changed. IE: 300 DPI to 800 DPI. This changes the picture size.
May 16, 2009 | BenQ ScanWit 2720S Film Scanner
When I find driver xp for scanner acer s2w 3300u
I've searched high and low and the best looking solution I can find for you is a program/drivers called VueScan.
http://www.hamrick.com/
It's release notes say it works with your scanner without the need for any benQ or Acer software.
Worth a try!!
Jul 26, 2008 | Acer Scan to Web 3300U Flatbed Scanner
COLORED SLIDES
do you have the optional film adapter? The optional Film Adapter (B81317) lets you scan negative film strips and slides
Jan 11, 2008 | Epson Expression 10000XL- Photo Scanner...
Scanner incorrectly reads frame position on film
Yes there is
Please do the following to scan slides or negatives in manual mode of the Epson TWAIN:
For scanning transparencies in HOME mode - for EPSON SCAN models, not Epson Twain/Manual mode models.
1) In the program you are working from, begin the scanning process. If working in FULL AUTO MODE as the scan begins click PAUSE or CANCEL, then change "Full Auto Mode" to "Home Mode".
2) You will now see all Epson Scan settings displayed. If the scanner has not previewed automatically, click the large preview button to get a visual of what is on the scanner.
3) Ensure the settings on the Epson Scan are correct for what you wish to scan. For example, the DOCUMENT TYPE for transparencies must be either "Color negative film", "B&W Negative Film" or "Positive film"*.
* FILM here indicates that the item being scanned is transparent to light; this setting is also used for slide scanning. Positive indicates that the image is in true colors (ie the grass is green and sky is blue), whereas negative indicates reversed colors, as produced in some photo finishing processes.)
If the DOCUMENT SOURCE is set for a flatbed related option, ie PHOTO, the scanner is looking for reflective items and will not activate the backlight in the transparency unit. If the DOCUMENT TYPES for "FILM" are greyed out or cannot be selected, close the Epson Scan, reseat the power/communication cable connecting the base of the scanner to the transparency unit, then reopen Epson Scan and try again.
NOTE for PROFESSIONAL MODE users: DOCUMENT TYPE should read TRANSPARENCY for film scans.
4) Ensure the other scanner settings are correct for the type of scan you are doing. For example:
IMAGE TYPE should be color photo for all positive or negative color transparencies, or BLACK AND WHITE PHOTO for monochrome transparencies.
DESTINATION is unimportant, however you should select a RESOLUTION appropriate to what you plan to do with the scans. (There are no hard and fast rules for DPI. As a general guideline, if you are saving scans at original size, a resolution ranging from 400-600 DPI should capture enough information to faithfully record the image. If the slide or negative will be enlarged, you will need to increase this DPI accordingly. We have no means to calculate what your exact needs will be in this situation; you will need to experiment and view the output to gauge the appropriate input DPI from the scanner.)
PREVIEW. If your scanner is doing a THUMBNAIL PREVIEW, the slides will automatically preview and appear in boxes on the left side. Here, you can select or deselect the slides you wish to scan.
If you recieve a message that the scanner could not find the film, or you see in the preview that part of the scan is cut off, click the down arrow next to the large PREVIEW button and click NORMAL, then PREVIEW again. In NORMAL PREVIEW mode, the scanner will capture all information on the flatbed; you will then have to manually marquee or crop the slides you wish to scan. Use the left mouse button (click, hold, drag) to lasso one slide inside a box made of dotted lines, then click scan. Only the selected area will scan. Repeat this process for as many slides or filmstrips are on the bed.
5) Click CLOSE once scanning is complete. The images will now transfer to the application in use.
Dec 10, 2007 | Epson Perfection V350 Flatbed Scanner
Pacific Image PrimeFilm 2700 Film Scanner Logo
27 people viewed this question
Top Pacific Image Office Equipment & Supplies Experts
Willem.
Willem.
Greg Cann
Greg Cann
Are you a Pacific Image Office Equipment and Supply Expert? Answer questions, earn points and help others
