Question about Miele SBB 300-3 Parquet Twister Brush
Miele 6270 parquet twister brush has com apart - how to put back together?
The twister piece that connects the brush to the long handle was taken off brush and now i cannot get it back on. is there a way to do this?
  • Miele Master
  • 18,424 Answers
Brush not working, green light not lit. have taken apart and put back together but still not working.
Hi Carol, Many models have a reset button (breaker) on them to protect the motor that turns brush. Look for one of these on yours and reset it. Should be on the outside of the unit.
This could also be a missing or worn belt. If you forgot to look for this when you had it apart, open it up again and make sure there is a rubber belt running between the motor and the pulley on the brush. If it's there, try turning the brush while holding one side of the belt with your fingers, to see if the brush pulley slips easy under the belt. If is does, you need a new belt. Make sure it's not plugged in... : )
Hope this help....
Mar 01, 2016 | Vacuums
The brushes are not working.
We have a Max Extract 60 and when we turned it on the brushes did not work. My husband took the pieces for the brush motor apart and put it back together and then they worked fine. They must of been bound up or put together wrong. Works great now.
Dec 21, 2010 | Hoover F6055-900 SteamVac Maxextract LS...
Reset button or Fuse on my Infinity?
Ok, I took it apart, cleared the clog out, and put it back together. It wouldn't switch to "carpet". Got no answer on my question. Took it apart again, only I went further. Took apart the bottom - brush out, all inside bottom parts out, cleaned all that part of vac. No clogs down there. Ran the carpet/bare floor switch back and forth several times while I had it apart. Put it all back together and it worked fine. Still didn't find a fuse or reset button...
Jan 09, 2010 | Vacuums
I need to reassemble my rainbow e series electrified hose handle
Yes, it is a ground wire. When you put it back together, make sure that the two halves of the hose handle are holding the wire up against the metal. I just had one apart the other day for the first time and if I recall correctly, the wire goes near the center for reassembly. Hope this helps!
Mar 15, 2009 | Rainbow E series Canister Wet/Dry Vacuum
Miele Solaris height adjuster arm won't snap back in
Maybe this picture will help, put the pieces together, then it sits directly under where #230 in the pic.
Mar 25, 2008 | Miele S514 Solaris Turbo Plus Vacuum
New Miele Red Star - Powerbrush not working
Wish you had listed the model number of the vac and of the powerhead. The plug going into the cannister, is it pushed all of the way in, also same for the plug going into the hose end? You can hook up the powerhead plug to a/c and see if it runs, if it does, then it is ok. Unhook the hose and plug and hook up a/c to that plug end and see if the powerhead will run, if not maybe the switch on the hose handle has a problem. Otherwise you have a problem in the cannister. If this is brand new, then it has a warranty, take in for repair.
Feb 21, 2008 | Miele Red Star Bagged Canister Vacuum
Miele SBB 300-3 Parquet Twister Brush Logo
1,033 people viewed this question
Top Miele Vacuums Experts
Mack Baxter
Colin Stickland
Colin Stickland
Are you a Miele Vacuum Expert? Answer questions, earn points and help others
