Question about Hotpoint Washing Machines
Hotpoint wmf940 leaks from detergant compartment
  • 489 Answers
SOURCE: Washer Leaks from Detergent Compartment
Two things might be wrong with this unit.  One problem is there is a blockage inside the hose that sends water into drum.  Make sure that's clear.  The other problem is the dispenser assembly may have a leaking problem and will spray water at an angle that will cause it to leak through the dispenser drawer.  My recommendation is to have the dispenser assembly inspected and possibly replaced.
Posted on Apr 27, 2008
  • 97 Answers
SOURCE: Kenmore front-load. washer leaks out of the detergent compartment
try cleaning out detergent compartment if you can take compartment out the inside area may need to be cleaned out make sure the machine is not to full
and if there is mold you can try using pool shock about a spoon full on wash cycle by it self this well not hurt seals and is safer then bleach and also to control the mold use a pool algecide use litely two tbs to a spray bottle and keep door open after use
but it sounds like compartment door is not fitted properly i hope this helps
Posted on Nov 25, 2009
Testimonial: "Great...that seems to work! Top-notch advise...the hint to use pool shock was in particular helpful. Thank you so much!"
apart4u
  • 213 Answers
SOURCE: Hotpoint WD860
How to fit Washing Machine Drum Paddle Lifter
For all free video help on appliance Repairs visitour Video Tutorials
Here's our video guide to replacing a washingmachine drum lifter.
A broken agitator paddle can cause your clothesto tear. Don't let this happen when replacing one is relatively simple.
The plastic paddles in the drum on the later washing machines (WMA models) often come looseand come off altogether. They can be replaced. call them lifters. You usually insert a smallscrewdriver down one of the holes (it's the 3rd one on ) and gently press downwhile sliding the lifter out.
Washing trainers in a washing machine is reputedto damage the drum lifters and paddles inside the drum, particularly onnon-quality washing machines.
There are few types of drum lifter; drum Paddle lifters
On hotpoint, creda, Ariston ,indersit and someother makes see video
Posted on May 06, 2010
SOURCE: WMF940 Child lock will not deactivate?
unplug the machine completely and plug it back in. Wait a second & it should deactivate.
Posted on May 25, 2010
FitzOriginal
  • 842 Answers
SOURCE: hotpoint aquarius wmf940 wont spin or drain water
This is simply a problem with your empty pump filter being clogged. The empty cycle is timed and if it can't get all the water out in time because the filter is blocked and slowing the empty down, then it will fail safe and won't step on to the final spin cycle with excess water in the drum. Your repeat of the rinse/spin cycle is giving it extra empty time and then the spin works OK.
You need to locate and clean the filter. Depending on the model (not sure which with the model you mention) there is probably a round filter cap on the front of the machine at the bottom ( behind the clip on panel on the bottom) Many models of this design also have a small hose to the right of the filter cap that you can pull out, remove a plug from and drain off any water in the filter before you remove the filter and get your floor wet, so take a look for this before you remove the filter and get soaked. Ofter that, unscrew the round cap, remove the filter and clean.
If the filter is not there, you will need to access the debris trap from the back of the machine. If there is no filter at the front, pull the machine out and you will see a roughly oval panel at the bottom of the rear of the machine. Unscrew the 3 or 4 screws and unclip. Directly below the drum, you will now see a rubber "Cup" like bulge in the black pipe, with a plastic tube connected to a plastic pipe. The cup is held in place by a large jubilee clip. Unscrew the clip, pull off the rubber boot to expose the debris trap (A conical plastic cage with a ping pong ball in it) Take out the ball and the plastic trap, clean out the debris and replace the trap and the ball (Note that the cage may have a slot in it that locates in the rubber boot, make sure it lines up, or it won't reassemble correctly). Now push the boot back onto the fitting at the bottom of the drum where it came from and tighten up the jubilee clip, making sure that it is fitted correctly (it too may have a small slot out of it that fits around a protrusion on the bottom of the housing).
Posted on Jul 10, 2011
Water not going into machine wmf940
id say its the inlet valve faulty. easy replacement.
Mar 22, 2014 | Hotpoint Washing Machines
Hotpoint WMF940 Washing machine - 11 months old. The cycle times displayed do not represent the actual times. No 5 cycle takes over 3 hours. The other displayed cycle times are similarly not...
If it is indeed less than a year old, then I recommomend you contact Hotpoint direct as the washer will still be under the years guarantee,and you should get a call free of charge
Check with Hotpoint at the web address below.
They should be able to help you.
WWW.HOTPOINTSERVICE.CO.UK
Jan 03, 2011 | Washing Machines
I have a LG WM2016CW washing machine and recently I found the detergent leaks from the main wash detergent compartment. I notices the liquid drops below the compartment on the front surface. Please advise...
If no holes are in the detergent dispenser which shouldn't be hard to see if any exist then I would assume that you may be adding too much detergent. Also remove the detergent compartment and make sure there is no build up anywhere that may be blocking the flow of the detergent.
Oct 19, 2010 | LG WM2016C
May 25, 2010 | Washing Machines
Hi. My wma58 is leaking from the detergent drawer.I have cleaned away any residue which may stop drawer closing properly problem persists can anyone help thanks
I removed top panel of machine took out drawer and removed screws allowing me to pull drawer compartment back slightly from front panel. Here i found more detergent residue which i couldn't see before.after cleaning this and refitting everything problem was solved.
Dec 30, 2009 | Hotpoint WMA58 Front Load Washer
The Hotpoint Aquarius DF62 Dishwasher detergent draw has come off, how do you refit and which spring goes where
Help! how to you put the spring back on the detergent compartment on Hotpoint Aquarius DF 62, any help would be appreciaed,,,,
Oct 05, 2009 | Dishwashers
Hotpoint Dishwasher
The dispencer soilnord is broke , change the dispencer.
Nov 09, 2008 | Hotpoint 24 in. FDW60 Free-standing...
Completely dumb question
Hi, we have a hotpoint aquarius - the "fan" compartment on the left is for fabric conditioner, the blue thing is to save you measuring it out in the bottle cap. Number I is for prewash detergent (only if you're doing a prewash) and number II is the main detergent compartment, the one you would usually use. Hope this helps?
Jen
Jan 17, 2008 | Hotpoint Aquarius WD640 Front Load...
Washing Machines Logo
Top Hotpoint Washing Machines Experts
vince
Eric Taylor
ptpumpman
Are you a Hotpoint Washing Machine Expert? Answer questions, earn points and help others
