Question about Miele Washing Machines
What is Technical Fault #53 on the Miele W1512 Washing Machine
After loading the washing machine with the desired amount of clothes, then selecting ther programme, the machine then displays "Technical Fault #53" and ceases to function
5 Suggested Answers
  • 249 Answers
SOURCE: Miele W487WPS Washing Machine
unplug machine, drain water manually by leaving the out let hose down gravity will let the wate out unless its blocked.Close Ire.ps. door should open .reset,and try again
Posted on Feb 25, 2008
  • 1572 Answers
SOURCE: Bosch washing machine WFT 8010
Some dryers have a "fluff" or "no heat" setting that spins the dryer with the heaters turned off. Check to make sure your cat didn't step on this button : ).
The most common failure modes include the main temperature regulating thermostat, overheat thermostat or thermal fuse, and heater elements. If you have a blown thermal fuse, check to make sure you don't have a lint buildup in the vent ductwork, especially right at the blower outlet. I've also seen problems with broken heater wiring and burned-out contacts in the heater control selector switch. The bottom line is that if gets to this point, you'll need to find the wiring diagram hidden inside the control panel, get an ohmmeter or continuity tester and start tracing the heater wiring.
Posted on Nov 18, 2010
Macmarkus
  • 2605 Answers
SOURCE: w1512 Miele washing machine I get
Hello, welcome to FixYa.
I will start by saying your post indicates it is a Miele W1512 washer,(if not please amend info provided) based on the info you provided it sounds like a bad hall sensor or also referred to as "rps sensor" (located under the unit to the right of the stator motor)
The F50 on these machines actually is meant to identify the motor stalled error, but as you may or may not have learned yet, it is most often associated with the sensor failure a very common problem with this model.
This error can manifest due to something jamming the basket from spinning such as an item of clothing stuck between the outer tub and basket, or a very worn tub bearing but if you can spin the basket freely by hand, that isn't likely.
Miele has since designed with a kit for the f-50 f-51 error code which includes a new control board,wire harness,and sensor. I would recommend contacting your local authorized Miele service provider, they should be very well versed in this issue.
Let me know anything further you can add and I'll try to help in any manner I can. Good luck.
Regards,
Macmarkus :)
Posted on Jun 12, 2011
richroth
  • 9472 Answers
SOURCE: 'washing machine miele w1714 lock on Message demo programme how i do unlock?
Demonstration Mode (Dealer Displays)
Initial requirements
- Switch off the machine.
- Close the door.
Note
Once you begin the access procedure, it must be completed within
10 seconds.
Accessing
1. Press and hold the Start Button while switching the unit on with
the On/Off Button.
2. As soon as the Start LED lights up, release the Start Button.
3. Immediately press and hold the Start Button, until the Start
LED turns off.
Deactivation
Repeat the accessing procedure.
Note
The Demonstration Mode is NOT deactivated when the power is
shut off with the On/Off Button, or by unplugging the appliance.
Posted on Nov 04, 2012
Miele washing machine W3725 is coming up with Technical fault F51 ?
F51: Pressure Sensor
Symptom
In the operating mode, the display indicates Technical fault.
The program is stopped, the water intake valve is closed, and the drain pump is
switched on for 120 seconds.
Cause
Electrical defect in analog pressure sensor (ADS). The values are out of range.
x
Note
The pressure sensor is integrated into the power/program electronic (ELP)
This will usually require a professional to repair.
Dec 10, 2016 | Miele Washing Machines
How to use Miele w307
its a washing machine so
all you have to do is
place washing {dirty clothes} into it
close the door tight
then add some soap {about a cup of powder}
you turn the machine on
select the proper program
and hit start
then some mins later you return
and decant the now cleaned clothes
its quite easy
Feb 08, 2015 | Miele Washing Machines
Bad smell from front load Miele washing machine
If you have a smelly front loading clothes washing machine, toss in a Finish Geltabs (the ones that are all liquid) and run the machine on a hot wash cycle, medium to heavy load (to get more water in the tub) with no clothes in the machine. You don't need to use much of a spin cycle so set it on low. The washing machine will come clean and even the moldy spots on the rubber gaskets will disappear. A second treatment may be needed if the smell is not completely gone. We tried everything from vineger to bleach to baking soda to borax to commercially available odor removers from Whirlpool and Tide. Nothing worked until I hit on this idea. It's cheap, easy and can be done anytime your machine needs a refreshing. I used the orange Geltabs but any fragrance would be fine. Keep the door on your washer open a bit when possible to air out to help preclude those nasty smells.
Nov 02, 2013 | Miele W4842 touchtronic series 27" front...
I've bought a Miele W310 front loader, which is secondhand, so i don't have a manual. i would just like to know how to do a short wash. There are buttons: 'Short' 'Prewash'...
The short cycle is only an option for Cottons. Make sure that you have set the desired program temp for a cotton cycle (95-30 degrees C). You should be able to select the Short cycle by pressing the button below the Soak light several times. (Note: this cycle is for small amounts of clothing which are lightly soiled - use less detergent (1/2 the amount for a full load).)
If it doesn't work when on the Cotton cycle, then the switch inside the control panel may be faulty.
The manual is available from Miele, http://www.miele.co.uk/customer/OperatingInstructions.aspx . Enter the type of appliance and then scroll down the list. The direct link to the manual for the W310 is http://www.miele.co.uk/Resources/OperatingInstructions/W%20310.pdf .
I hope this helps.
Jun 25, 2011 | Washing Machines
Miele front loader washing machine W3275- error code F53- what does this mean?
hi,
this is a tachogenerator fault or the drive motor brushes are faulty. you will need a Miele service tech or a Miele service agent to look at this.
May 21, 2010 | Miele W865 Front Load Washer
Need to know where to put washing liquid in my Miele G646 SC
Hi most washing liquids go direct inside the machine with your washing, if your using liquid there should be a small liquid device with the bottle that you also use to measure the amount of liquid and place direct into the machine drum.
Jul 19, 2009 | Miele W2203 Front Load Washer
Miele W864 Fault
I have a W844 and the exact same fault occured. I traced it to badly worn brushes on the motor.
Mar 11, 2008 | Miele W864 Front Load Washer
Washing Machines Logo
54 people viewed this question
Top Miele Washing Machines Experts
Gerry Harvey
Gerry Harvey
Are you a Miele Washing Machine Expert? Answer questions, earn points and help others
